Venerable Jazzman Posted July 20, 2006 Share Posted July 20, 2006 I've been given a Brother Artemis model, and I want to convert him into an Inq scale Death Co with jump-pack. I've ordered the helmet, second arm and chainsword from GW, but I can't find a bolt pistol or jump-pack anywhere. Anyone seen anything helpful before? If I can't get a bp I'll probably just make him with the bolter and chainsword, seems appropriate though not 100% fluffy :wub: For the jump-pack I'm thinking of hacking up some deodorant bottles and plasticard, but all sugesstions welcome. .. Link to comment https://bolterandchainsword.com/topic/92144-inquisitor-scale-jump-pack/ Share on other sites More sharing options...
Broon1 Posted July 20, 2006 Share Posted July 20, 2006 You can make a BP from a scout heavy bolter, or a chaos one. What do you mean you've ordered a second arm? Link to comment https://bolterandchainsword.com/topic/92144-inquisitor-scale-jump-pack/#findComment-1059066 Share on other sites More sharing options...
Blindhamster Posted July 20, 2006 Share Posted July 20, 2006 firstly... second arm?? theres a new arm model for Artemis?? *thinks maybe its time to get back to work on his model* there used to be a bolt weapon sprue, if you ask in store they should be able to order it for you, alternatly there are a couple of other models in the range that have bolt pistols, so you could just get one of those. Link to comment https://bolterandchainsword.com/topic/92144-inquisitor-scale-jump-pack/#findComment-1059083 Share on other sites More sharing options...
pinkbunny Posted July 20, 2006 Share Posted July 20, 2006 INQ bolt pistols: 9947139901107 9947139903504 <slightly chaosy, but i like it 9947139900702 <drum fed BP(i think) 9947139905404 <needs hand removal, but you could swap it with the bolter 9947139905405 <same as above thats all i found Link to comment https://bolterandchainsword.com/topic/92144-inquisitor-scale-jump-pack/#findComment-1059104 Share on other sites More sharing options...
millest Posted July 20, 2006 Share Posted July 20, 2006 theres no Inquisitor scale jump pack if you want one you will have to convert one! millest Link to comment https://bolterandchainsword.com/topic/92144-inquisitor-scale-jump-pack/#findComment-1059630 Share on other sites More sharing options...
Venerable Jazzman Posted July 21, 2006 Author Share Posted July 21, 2006 Sorry, the second arm is for the plain shoulder pad, as I don't want the Deathwatch iconography on the left pad. Thanks for the bits codes, I used GW searchy but it came back with nothing. Link to comment https://bolterandchainsword.com/topic/92144-inquisitor-scale-jump-pack/#findComment-1060016 Share on other sites More sharing options...
hendrik Posted July 22, 2006 Share Posted July 22, 2006 you could use empty gw paint s as those big cilinder thingies where the flames come out? Link to comment https://bolterandchainsword.com/topic/92144-inquisitor-scale-jump-pack/#findComment-1061088 Share on other sites More sharing options...
Penitent Dreadnought Posted July 22, 2006 Share Posted July 22, 2006 You could try the engines off a model Fairchild Thunderbolt II. Link to comment https://bolterandchainsword.com/topic/92144-inquisitor-scale-jump-pack/#findComment-1061095 Share on other sites More sharing options...
GeneralStukov Posted July 23, 2006 Share Posted July 23, 2006 Im glad someone else was thinking of this idea, its an interesting conversion as is but you might be better off converting the BP it comes with, with alittle Plastic tubbing and adding abit of odds and ends for the Backpack to make it look more, "Jump pack esque". IMHO The Brother Art. model as is doesnt need converting at all.. since its an amazing model but Im curious as to how you'll make the Non-Deathwatch shoulderpad... if you ordered 2 right arms you'll be sorely dissapointed as the model's shoulderpads dont come off, now doing alittle chopping and repositioning will be needed and alot of GS work will be required as well.. There are many different bolt pistols in the accessory sprue. I believe there was a guide on how to make old style jump packs in the forums. That'd be a nice guide to look at for making your jumpack, Hope it goes well tho, Im always looking forward to seeing new inquisitor models 8) Link to comment https://bolterandchainsword.com/topic/92144-inquisitor-scale-jump-pack/#findComment-1061168 Share on other sites More sharing options...
Legion commander Argonas Posted July 23, 2006 Share Posted July 23, 2006 @ bolt pistol, chop up the bolter? ;) Link to comment https://bolterandchainsword.com/topic/92144-inquisitor-scale-jump-pack/#findComment-1061458 Share on other sites More sharing options...
Graywolf Posted July 23, 2006 Share Posted July 23, 2006 Didn't Barpharanges do an inquisitor scale jump pack? Okay, found it...it's a resin forgeworld display scale marine, but he scratch built the jump pack... http://www.geocities.com/barpharanges_1/Re...ult_Marine.html Link to comment https://bolterandchainsword.com/topic/92144-inquisitor-scale-jump-pack/#findComment-1061796 Share on other sites More sharing options...
Venerable Jazzman Posted July 24, 2006 Author Share Posted July 24, 2006 Ok, thanks to everyone and Argonas for their help. Graywolf, thanks for the reminder, I've got Barph's site bookmarked and had forgotten about that mini: cheers.. Gen Stukov, sorry to disagree, but I'm really looking for a regular DC trooper, and I just dont think the Deathwatch pads fit, either from a fluff or aesthetic point. I realise the second pad's going to be a cut and paste job, but there's going to have to be quite bit of GS stuff on that arm anyway. re the jump-pack, I will probably use the existing back-pack as the base for the new build, unless I screw it up completely and throw it away.. :unsure: Penitent and hendrik, those are both good ideas: I don't want to spend all my cash on a complete Warthog kit, so any ideas on sprues and scales? I guess 1:72 is too small, so we're looking 1:24 or 1:32? I made a really nice jet exhaust last year for my Orks using the ring from a ball deodorant bottle and a sports-cap from a water bottle, I'll try to get pics up for c&c before I go on holiday tomorrow. Link to comment https://bolterandchainsword.com/topic/92144-inquisitor-scale-jump-pack/#findComment-1061847 Share on other sites More sharing options...
Penitent Dreadnought Posted July 24, 2006 Share Posted July 24, 2006 Just buying the engines? No place I know of, since most model aircraft mods I'm familiar with are just armament kits. I was thinking, if money/buying an unnecessary model kit wasn't an issue, you could also try the engines off other kits, like the Galaxy or the Viking, at another scale... Link to comment https://bolterandchainsword.com/topic/92144-inquisitor-scale-jump-pack/#findComment-1061851 Share on other sites More sharing options...
hendrik Posted July 24, 2006 Share Posted July 24, 2006 i think deodorant bottles will be to big,atleast the ones they have in belgium here will be too big:p i did some sceth work over the picture of the marine backpack from the online store with paint jetpack here ya go the black lines (and the blue) are the gw paint bottles,the red are plates you make from plasticard or other stuff,and the green are cables:) Link to comment https://bolterandchainsword.com/topic/92144-inquisitor-scale-jump-pack/#findComment-1062414 Share on other sites More sharing options...
