  • 3 months later...
  • 2 months later...
Haven't posted anything in here yet, so here is some.
My most recent work (which is still months old).
Work in progress found here. If I ever expand the Consecrators, that's where they'll be.
These pics are older, so not such great shots (there also among some of the first models I painted)...
Deathwing
Old School Predator
Homemade Resupply Drop pod
Yes, the "hinges" are pencil tops.
Old metal Dread
Rhino
Edited by EPK
  • 2 weeks later...
Hi Guys,I just thought I would share some of mine. This is part of the 4th company. the Land raider is part of an on going project to make a LAND RAIDER PROMETHEUS.
I'll try and get into my loft at some point and photo the whole 4th coy and support elements
Hope you like them.
Edited by wacca
Hello all its been a while since I have posted something and I have never posted any pictures of any of my models and since my painting skills have come a long way I just finished my Belial with TH/SS. I have converted my own TH as you can see as well as the SS.
  • 1 month later...
  • 1 month later...
  • 4 weeks later...
  • 4 weeks later...
  • 3 weeks later...
  • 1 month later...
  • 2 weeks later...
As per CPT S's request here is my entire Ravenwing Battle Force
http://i293.photobucket.com/albums/mm71/pueriexdeus/RavenwingBattleForce.jpg
Total Body Count is 90, but that Includes both Sammies.
Command Section;
Both Sammies, 2x Chaplains, 1x Librarian, Demi Command Sqd PF, 2X PG's, and HB-AB, Unattached MM-AB
Combat Team Alpha; 3X Ravenwing Assault Squadrons;
1X PF,2X PS, PP, MB's, 4X MG's, 2X PG's, 3X ABw/2X MM, 1X MB, 3X LSw/ AC,HB
Combat Team Bravo; 3X Ravenwing Assault Squadrons;
This Team will need much more wortk. Two RAS are built with 4X DV RW sets, they are not intended to work this way, as you can see I have two, too many SGT's. I'll probably see what the upcoming RW Box set looks like and see if I can strip out the extra Sgt's add a couple more Squads to the Battle Force.
Some of you may notice Paldrons on opposing shoulders. I accidentally put them on the LS's backwards. Oh, well, something else to fix later.
1X PF,2X PS, PP, MB's, 2X MG's, 2X PG's, 2X Flmr, 3X AB w/1X MM, 2X HB, 3X LSw/ 2X AC, 1X HF, 3X HB
HS Typhoon Section;
3X LS w/TML, 2X MM, 1XHB
And last but not least
Company Team Alpha RW Detachment;
These are my original RW models 2nd ed. Prior to C:DA 4th ED we could field squadrons of identical Landspeeders, 3X LS Tornadoes on a flank were awesome, called em the Snow Shovel. The unpainted metal LS was intended to replace the lone Green Plastic that I re-painted in Black for this Vow. But with the inclusion of RSS in 4th Ed C:DA I shelved him since my 3X LST would not be legal.
Libbi (He was a White Scar of some sort), PS, MG, PG, MM-AB. 3X LS AC/HB you will notice the one unpainted LS here, it is the only unpainted RW model I have left to do.
Total Points = 4575
Edited by pueriexdeus
  • 2 months later...
  • 4 weeks later...
  • 2 months later...
  • 2 months later...
  • 2 months later...
  • 5 months later...
Register a new account
Sign in
