Volcatus Posted October 28, 2011 Share Posted October 28, 2011 (edited) Introduction Missile Launchers are a popular and effective choice for Devastator Squads, as we all know. Buying them, however, isn't always practical. Here's a simple method for converting Tactical Marines and all of those HK missile bits that you have lying around into proper Missile Launchers Devastators.In the following images, the converted HK Missile is on the left, and a Tactical Squad Missile Launcher is on the right. Required Items Tools:-Hobby knife with a brand new, very sharp blade-Pin vise with 1/8" (3mm) drill bit-Files-Sculpting toolParts:-One complete Tactical Marine, minus Bolter-One complete Space Marine Hunter Killer Missile-0.060" (1.5mm) plasticard-Suitable power cable. I use the 0.065" from Dragon Forge Design.-Green Stuff or equivalent Modify and Assemble the Launcher Begin by removing any flashing and clean all mold lines, as best as you can. Next, drill a 1/8" (3mm) hole in the rear end of the launcher tube.In order to imitate the look of the Tactical Squad Launcher, the optics box must be moved to the other side of the launcher assembly. To achieve this, start by removing the cabling section (denoted by the red arrow in the following picture) between the launcher muzzle and the optics plate. At this stage, you will also need to shave the skull from the side of the launcher tube. If you're careful, you can retain the skull and glue it to the opposite side.Glue the muzzle to the launcher tube, and the optics plate to the optics box. Glue the optics box to the side of the launcher tube, aligning the face of the muzzle with the face of the hood of the optics plate.Cut the following shapes (carrying handle and power cable connection point) from plasticard:Use the Tactical Squad Launcher as a guide for the dimensions of each piece. Glue the plasticard pieces and the power cabling to the launcher, fill in any holes with Green Stuff, and allow everything to dry before proceeding. Final Assembly In the preceding picture, the launcher has been attached to a standard Marine Bolter arm. The only modification involves cutting off the hand at the wrist, and gluing it to the launcher assembly. Cut off the forearm, just above the elbow pad. Reattach the forearm, so it is in the right position to match up to the hand, and allow the launcher to rest on the shoulder pad. Once everything is dry, you can glue the launcher and arm together, and attach the power cable to the gap between the arm and shoulder pad. Green Stuff the wrist joint, using the sculpting tool to create the folds in the joint.The left arm is more challenging:Again we're using a standard Tactical Marine Bolter arm. Begin by scoring the hand, palm side, across the top of the palm. Score again across the middle joints of the fingers. Carefully open the fingers to create a flat, open hand as seen in the picture. Cut the hand away from the arm. Cut the arm again at the elbow, above the elbow pad.Green Stuff the gaps in the backs of the fingers, and attach the hand to the side of the launcher. Attach the shoulder to the Marine's torso. Glue the forearm piece between the shoulder and the hand. Green Stuff the wrist joint, using the sculpting tool to create the folds in the joint.NOTE: The arm portion of the build is a bit of a balancing act. Dry fit as much as possible before gluing to ensure proper alignment.Thanks for reading. I hope that you find this tutorial to be helpful. Please post or PM any question you might have. Edited October 28, 2011 by Volcatus Greylocke and Kierdale 2 Back to top Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/ Share on other sites More sharing options...
red_starrise Posted October 28, 2011 Share Posted October 28, 2011 Very nice. I've used these myself for my Long Fangs since GW in their infinite wisdom saw fit to only give us 1 freakin missile launcher in the devastator box. How cruel is that? Â Sorry again about the other day, maybe I can get a raincheck for a game sometime. Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/#findComment-2910922 Share on other sites More sharing options...
Volcatus Posted October 28, 2011 Author Share Posted October 28, 2011 Very nice. I've used these myself for my Long Fangs since GW in their infinite wisdom saw fit to only give us 1 freakin missile launcher in the devastator box. How cruel is that? Sorry again about the other day, maybe I can get a raincheck for a game sometime.  Yeah, I'll never understand some of GW's modelling decisions.  And don't sweat it bud. We'll get that game in. :) Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/#findComment-2911117 Share on other sites More sharing options...
tiny sam Posted October 28, 2011 Share Posted October 28, 2011 Very nice. I've used these myself for my Long Fangs since GW in their infinite wisdom saw fit to only give us 1 freakin missile launcher in the devastator box. How cruel is that? Sorry again about the other day, maybe I can get a raincheck for a game sometime.  Yeah, I'll never understand some of GW's modelling decisions.  And don't sweat it bud. We'll get that game in. :(   it's simple you'll have to bought 4 box! :) Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/#findComment-2911229 Share on other sites More sharing options...
Venemox Posted October 28, 2011 Share Posted October 28, 2011 4 boxes... or a set of various sized plastic tubing ^_^ Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/#findComment-2911265 Share on other sites More sharing options...
Crimson Fisting Posted October 28, 2011 Share Posted October 28, 2011 Very nice. I've used these myself for my Long Fangs since GW in their infinite wisdom saw fit to only give us 1 freakin missile launcher in the devastator box. How cruel is that? Â $$$$$$ Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/#findComment-2911409 Share on other sites More sharing options...
Jayz Posted October 31, 2011 Share Posted October 31, 2011 Great tutorial should I get around to making the Blood Angel army I will use this for my guys! They look a lot bulkier and more Devestator like using the HK missiles then the normal ones your see one each Dev sqaud now a days Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/#findComment-2912893 Share on other sites More sharing options...
Hyaenidae Posted October 31, 2011 Share Posted October 31, 2011 *facepalm* Genius! Thanks for the tutorial, Volcatus! Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/#findComment-2912900 Share on other sites More sharing options...
WeaponAdept Posted October 31, 2011 Share Posted October 31, 2011 Looks much better than the standard one! Nice work. Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/#findComment-2912997 Share on other sites More sharing options...
Volcatus Posted October 31, 2011 Author Share Posted October 31, 2011 Thanks guys. :) Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/#findComment-2913080 Share on other sites More sharing options...
death_incarnite Posted December 6, 2011 Share Posted December 6, 2011 Kudos, long fangs every where howl your praise. Also as a marine player i find the amount of multi meltas very agrovating. But im happy to say leman russ MM plus HB/PC stock can make a very convincing conversion. :) Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/#findComment-2938310 Share on other sites More sharing options...
Ming Posted December 6, 2011 Share Posted December 6, 2011 And comparing the weapons systems, I'll rant that marine missiles of all kinds should have a 60- or 72-inch range....not the limp 48... Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/#findComment-2938338 Share on other sites More sharing options...
DarkKnight44 Posted December 21, 2011 Share Posted December 21, 2011 Yeah, that's GW again changing things. The Missile Launcher used to be 72". Its been a long time since I've played, but I know the 1st Ed. was 72" for ML and 60" for the Lascannon. I'm with you Ming, 72" is what it should be again. Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/#findComment-2948946 Share on other sites More sharing options...
Paulochromis Posted March 21, 2012 Share Posted March 21, 2012 just seen this, very nice. btw couldn't you simplify things by making a left-handed missile launcher? Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/#findComment-3020697 Share on other sites More sharing options...
Volcatus Posted April 2, 2012 Author Share Posted April 2, 2012 just seen this, very nice.btw couldn't you simplify things by making a left-handed missile launcher? Â I find it easier to do it right-handed, due to the availability of left arms with open hands. It's much easier to swap the targeter box to the other side of the launcher, than it is to sculpt open right hands. Â Additionally, one of the goals was to make them look as similar as possible to the standard ML from the Tac Squad box. Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/#findComment-3030953 Share on other sites More sharing options...
Ironfoe Posted April 16, 2012 Share Posted April 16, 2012 That looks better than the standard missile... Â great work. Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/#findComment-3040377 Share on other sites More sharing options...
elmo Posted September 1, 2012 Share Posted September 1, 2012 Thanks - tried this and it has worked out great.  It also allows different positioning of the launcher  http://i814.photobucket.com/albums/zz66/jonbrooks_photo/B%20and%20S%20WIP/DA%20painting%20challenge/CIMG2567.jpg http://i814.photobucket.com/albums/zz66/jonbrooks_photo/B%20and%20S%20WIP/DA%20painting%20challenge/CIMG2566.jpg Kierdale 1 Back to top Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/#findComment-3163861 Share on other sites More sharing options...
SCOTT_FRANCIS Posted May 4, 2014 Share Posted May 4, 2014 Another simple but effective conversion tutorial. Thank you. I also agree it looks much better than the GW version. Link to comment https://bolterandchainsword.com/topic/241037-tutorial-hk-missile-to-missile-launcher-for-devastators/#findComment-3674100 Share on other sites More sharing options...
