Jolemai Posted August 8, 2015 Share Posted August 8, 2015 (edited) So I decided to make a terrain plog...Right folks, to those that don't know me, I usually spend my time over in the Blood Angels sub-forum slowly working on my Blood Angels. So having a log in the wider forum view is something new to me...As it happens I have a few Fortifications and a bunch of scenery (mostly comprising of the second edition card stuff) that needs sorting, constructing, painting and in some cases, refurbishing. As it's not BA-specific, this work will appear here and it's something I plan on doing between projects with my Blood Angels, so I'll update it when I can.I'm pretty sure that at least one of you will think at some point, "Why doesn't he just throw it away?" and to be fair, that is a valid observation/question. You see, the card scenery is what was available when I got into the hobby, so it's nostalgic and something I have a sense of attachment to. Not only that but having finally stopped working on my house, I can now work on getting a gaming table ready and given my lack of available funds, I can only work with what I have available.With that in mind, I'll be after advice and opinions - especially as this is my first time doing something like this - so feel free to comment at any time and thanks for reading.Completed tasks Tanglewire Edited December 4, 2021 by Jolemai GodEmperorOfMankind and Dolchiate Remembrancer 2 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/ Share on other sites More sharing options...
Jolemai Posted August 8, 2015 Author Share Posted August 8, 2015 (edited) Tanglewire Something simple to start with, I've inherited/acquired these: Now, they are really flimsy so I'm looking at putting them on a base. Which looks best? (Another alternative would be to use three square bases made to look like concrete posts) Edited August 8, 2015 by Jolemai Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4141351 Share on other sites More sharing options...
Quixus Posted August 8, 2015 Share Posted August 8, 2015 I like the rectangular base best. If you flock the bases, the round and bike bases will probably look weird. No if you had something like a longer bike base under the whole wire, that would look just as good, maybe even better, because it looks similar to other 40k bases. Exilyth and Jolemai 2 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4141361 Share on other sites More sharing options...
Jolemai Posted August 8, 2015 Author Share Posted August 8, 2015 I could probably make a "stretch" bike base no problem. As for basing it, I suppose I'll do it similar to my Blood Angels (stoney/clay mud, green trims - will add a picture later), but I could always do something different/neutral. As most of my scenery is ruined (no pun intended), I'm trying to do something which looks old and reclaimed by the land, but war torn (if that makes sense), so ideally, it should be something which fits with that. Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4141393 Share on other sites More sharing options...
Quixus Posted August 8, 2015 Share Posted August 8, 2015 (edited) How about using an irregular piece of plasticard, MDF or similar material? Slap some crackle medium and/or paint on it and put some static grass in the cracks. Edited August 8, 2015 by Quixus Jolemai and Exilyth 2 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4141400 Share on other sites More sharing options...
Jolemai Posted August 8, 2015 Author Share Posted August 8, 2015 Sadly, I don't have any of that to hand. For the moment, I can only work with what I have... Here's a close up of my current BA base style: Not sure how well it will lens itself to the scenery bases (of which I'll be doing a lot). I've got enough 25 mm square bases to "stretch" a bike base, so that could work well once I've filled the join with a spot of green stuff. Wondering if I should bother pinning the fences to something like a lollipop stick beforehand for extra stability... Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4141668 Share on other sites More sharing options...
Charlo Posted August 8, 2015 Share Posted August 8, 2015 I think rounding them off works best, if anything just to look a bit more uniform. They'll look great amidst the rubble like on your current bases dude! Jolemai and Quixus 2 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4141710 Share on other sites More sharing options...
Jolemai Posted August 10, 2015 Author Share Posted August 10, 2015 (edited) Stretched base WIP: Stretched base size test: Now for some greenstuff... Edited August 10, 2015 by Jolemai Exilyth 1 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4142939 Share on other sites More sharing options...
Jolemai Posted September 10, 2015 Author Share Posted September 10, 2015 Current update: Been busy with a holiday and other things so this update is later then planned, but with the green stuff done I've pinned the wire the the base. I'll be basing it at the same time I do my RTS Vow, so the next update should be next week at the earliest. After that, I'll be undercoating the model in black and starting the paint :) For rust, is it best to apply Tin Bitz straight onto Chaos Black with some silver highlights, or to use a silver basecoat, then apply the rust, ink/shade, apply another rust coat and then highlight? Exilyth, GodEmperorOfMankind, Quixus and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4168130 Share on other sites More sharing options...
Charlo Posted September 10, 2015 Share Posted September 10, 2015 Big fan of those! Keep it up :D I too am curious about rust... Jolemai 1 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4168159 Share on other sites More sharing options...
Jolemai Posted September 10, 2015 Author Share Posted September 10, 2015 Maybe one day I'll even find out what they originally were... Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4168162 Share on other sites More sharing options...
SW1 Posted September 10, 2015 Share Posted September 10, 2015 They're looking mighty fine! I find the main trick with scenery is to keep everything uniform, so you can plonk it down anywhere on the board and it won't look out of place. By the way it's good to see another scenery blog. Consider it followed. :D Jolemai 1 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4168200 Share on other sites More sharing options...
evildrcheese Posted September 11, 2015 Share Posted September 11, 2015 Looking good so far Jolemai! Care to hint at what else is in store for the future? I know how you like to be cryptic and all :) D Jolemai 1 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4169476 Share on other sites More sharing options...
Jolemai Posted September 11, 2015 Author Share Posted September 11, 2015 Looking good so far Jolemai! Care to hint at what else is in store for the future? I know how you like to be cryptic and all :) D I'm going to try and get an Aegis Defence Line done before February. After that it's all ruins and something that involves a plasma ball... CaptainHelion 1 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4169490 Share on other sites More sharing options...
Adeptus-Alaska Posted September 15, 2015 Share Posted September 15, 2015 terrain threads are my favorite threads! besides, you know, blood angels threads....... Charlo and Jolemai 2 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4171812 Share on other sites More sharing options...
Jolemai Posted October 26, 2015 Author Share Posted October 26, 2015 Another small update: Finally found time to get the undercoat on. Now to paint; any recommendations for rust? I'm also after any suggestions for painting an Aegis Defense Line. I'm thinking of an urban scheme (so bone on a grey base), but I really haven't a clue. Just after something neutral (i.e. non-BA). Tanglewire and quad gun: Tanglewire close up: Probably should fix that crack at some point... Charlo 1 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4207125 Share on other sites More sharing options...
MaliGn Posted October 27, 2015 Share Posted October 27, 2015 Maybe one day I'll even find out what they originally were... Looks like the barbed wire in my daughter's green army men toys. Lord Raven 19 and Jolemai 2 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4208645 Share on other sites More sharing options...
GodEmperorOfMankind Posted November 1, 2015 Share Posted November 1, 2015 Loving the start you've made here mate Jolemai 1 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4212982 Share on other sites More sharing options...
Noctem Cultor Posted November 1, 2015 Share Posted November 1, 2015 It's a good start, I'd recommend getting some hobby Razor wire/barbed wire so you can add it to other bits so it all blends in. Also you can weave some on the plastic sets so the don't look so flat. I look forward to seeing more. Jolemai 1 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4213019 Share on other sites More sharing options...
Jolemai Posted November 5, 2015 Author Share Posted November 5, 2015 Maybe one day I'll even find out what they originally were... Looks like the barbed wire in my daughter's green army men toys. Well, I got a plastic green tank with it so maybe ;) Loving the start you've made here mate Cheers! It's a good start, I'd recommend getting some hobby Razor wire/barbed wire so you can add it to other bits so it all blends in. Also you can weave some on the plastic sets so the don't look so flat. I look forward to seeing more. Actually hadn't thought about that. Forgeworld do this which I could coil around it, but is there another suitable (and/or cheaper) choice out there? Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4216607 Share on other sites More sharing options...
Jolemai Posted March 2, 2016 Author Share Posted March 2, 2016 With no BA project to do until the ETL, I've got a bit of time for this blog again. Here's the 3D test for the Tanglewire using the GW brass etch listed above: Look OK? I'm trying for an ad hoc look... Honest! Dolchiate Remembrancer 1 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4324673 Share on other sites More sharing options...
Jolemai Posted March 11, 2016 Author Share Posted March 11, 2016 (edited) With paint! Will likely highlight with chainmail but not sure where else to go other than call it a day. They seem like they are missing something? Edited March 11, 2016 by Jolemai Pearson73, Dolchiate Remembrancer and Exilyth 3 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4332977 Share on other sites More sharing options...
SW1 Posted March 11, 2016 Share Posted March 11, 2016 Once you tidy up the edging with grey or something it'll look a lot more finished. It's little things like that that can really finish off things. Jolemai 1 Back to top Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4333183 Share on other sites More sharing options...
Jolemai Posted March 12, 2016 Author Share Posted March 12, 2016 Will probably just do that for now. It's been suggested that I add some ragged cloth and maybe some grass tufts but I want to move onto a different project prior to the ETL. Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4333599 Share on other sites More sharing options...
Jolemai Posted March 25, 2016 Author Share Posted March 25, 2016 (edited) Edged the posts on the wire. Will run a line of rust washed off on the base below the wire and call it a day - just need to regenerate my Chestnut Ink first... Meanwhile: Aegis Defense Line Moved onto something different by trying to complete my Aegis. When I think if Adamantium, Plasteel, etc, I think of a cold, grey/bone colour. I first worked on this paint scheme with my house Delaque gang and have since used it on my bases; now for some models. The first picture shows my progress onto the second coat. Stage one was a black undercoat followed by a rough coat of Codex Grey. Second coat is the edges painted with Fortress Grey and I plan on drybrushing the inner bits. After that will come Bleached Bone and some weathering. Not sure if to paint or just highlight with the Bone yet... Edited March 25, 2016 by Jolemai Link to comment https://bolterandchainsword.com/topic/312111-jolemai-attempts-fortifications-scenery-and-terrain/#findComment-4346274 Share on other sites More sharing options...
