simison Posted July 31, 2016 Share Posted July 31, 2016 (edited) This calculator operates best when using the most comparable canon unit/wargear to compare to. I divide the calculations into three broad fields: Attributes, Wargear, and Special Rules Attributes 5 points (base cost) - Weapon Skill, Ballistic Skill, Attacks, Leadership 10 points (base cost) - Strength, Toughness, Wounds, & Initiative Wargear Weapon Attributes 5 points (base cost) - Strength, Armour Penetration, and for every 6 inch difference in range (E.g. To add 12 inches to a ranged weapon should cost 10 points)Weapon Special Rules 5 points - Grants Blast (3'), Master-Crafted, Pinning, Shell-Shocked (-5) points - Inflicts Specialist Weapon, Two-Handed 10 points - Grants Blind, Barrage, Concussive, Deflagrate, Duelist's Edge, Hammer of Wrath, Interceptor, Large Blast (5'), Missile Lock, Murderous Strike, Rad-Phage, Sudden Strike, Sweep Attack, Torrent, Twin-Linked (-10) points - Inflicts Cumbersome, Gets Hot, 15 points - Grants Force, Haywire, Ignores Cover, Lance, Melta, Poisoned, Template (-15) points - Inflicts Unwieldy 20 points - Grants Armourbane, Fleshbane, Graviton, Instant Death, Shred, Sniper, Soul Blaze, Sunder 25 points - Grants Destroyer Weapons, Special Issue Ammunition, Wrecker 30 points - Grants Vortex Special Rules Source can be either from a piece of wargear or a characteristic of the model/unit 5 points - Grants Adamantium Will, Counter-Attack, Deadly Aim, Precision Strike, Precision Shot, Rage, Skyfire, Stealth, Strafing Run (-5 points) - Inflicts Bulky 10 points - Grants Chosen Warriors, Deep Strike, Fear, Fateful Descent, Furious Charge, Fury of the Legion, Gun Them Down, Hatred, Jink, Night Vision, Onslaught, Rampage, Repel the Enemy, Sentry Defence System, Shield Wall, Shrouded, Split Fire, Strikedown, Sudden Strike, Supersonic, Tank Hunters, (-10) points - Inflicts Slow and Purposeful, Support Squad, Very Bulky 15 points - Grants Crusader, Fearless, Feel No Pain1, Fleet, Hit and Run, Monster Hunter, Outflank, Power of the Machine Spirit, Rending, Sabotage!, Smash, Stubborn, Vector Dancer 20 points - Grants Daemon, Fatal Strike, Implacable Advance, Infiltrate, It Will Not Die, Move Through Cover, Preferred Enemy, Relentless (-20) points - Inflicts Damned, Extremely Bulky 25 points - Grants Command Tank, Psyker (Level 1), Eternal Warrior, Marked for Death, Skilled Rider, Scout, Veteran Tactics, Zealot 30 points - 35 points - 40 points - 45 points - Grants Ferromantic Invulnerability Protection 5 points - +1 Cover Save 10 points - +1 Armour Save 15 points - +1 Invulnerable Save, Hardened Armour Vehicles 5 points - +1 Armour Value2, Grants Inductor Charges (-5) points - Inflicts Lumbering Behemoth 10 points - +1 Hull Points 15 points - 20 points - Grants Atomantic Shielding [To be updated later...] 1 Additional adjustments of either increasing or decreasing the FNP save should be 5 points for every point of difference. For example, a FNP (4+) would cost 20 points, instead of 15 points. 2 This number is obviously doubled when upgrading Side facings, since that is adding a total of 2 to the vehicle's armour value. *Note all Attributes are on a progressive, not static, scale. Instead, all attributes operate on a D3 scale with the first two 'levels' equal to base cost. The next two 'levels' incur an additional 5 point cost. The two levels beyond that adds another 5 points for a total of a 10 point cost added to the base cost and so forth. For example, to create a special meltagun with Strength 10 would add 10 points to its typical cost. However, to make a Strength 8 boltgun would cost an extra 30 points to create. The upgrade to Strengths 5 & 6 would cost 5 points apiece for a total of 10 points. But the costs to upgrade to Strengths 7 & 8 would cost 10 points apiece for a total of 20 points plus the 10 points for levels 5 & 6, leading to a total of 30 points. This also affects any Special Rule that operates on 'levels' such as Feel No Pain, Rending, etc. ~~~~ Rule-crafting R/D This is what I learned when I did a survey of the canon legions: "Okay, what's interesting is that half of the unique wargear are specifically built upon or given as an option to the more standard weapons. Anyway, that finished my run. Most common prices are 5 pts, 15 pts, and 20 pts. The Word Bearer's Burning Lore is the single 30 point example." For relics, the range is 35 points to 50 points. Mode is 40 points. It's some food for thought as we move forward. TS/RG - 35 points DA/EC/IW/SWNL/IH/UM/DG/WB - 40 points AL - 45 points WS/IF/BA/WE/SoH/Sal - 50 points Every legion, canon or noncanon, have three fixed points: one relic, one Primarch, and two Rite of Wars. Beyond that, are three different areas that can vary widely from legion to legion: unique units, heroes, and wargear. What I did was come up with a slot system: "1 - 2 - 2, is the basis, format being wargear, units, and characters with an additional 4 slots available." Now, I have a minimum established for each of the three categories based on how the canon legions are arranged. So, every canon legion has at least one unique wargear. Every legion has at least two special units and so on. The extra three slots go where you want them to go to help establish an underlying aspect of your legion's identity. For example, my legion, the Halcyon Wardens, have an underlying theme of 'Strength through Unity', while we're not a tech-heavy legion. So, I spent my slots on having more unique heroes and units and only have the single piece of wargear. Calculator Template Unique Unit/Character Comparison Base: Canon Unit/Character being compared to (0 points) Attributes [Example: +1 Weapon Skill (WS): 5 points] [Example: -1 Ballistic Skill (BS): (-5) points] Total: 0 points Wargear [Example: Close Combat Weapon with Master-Craft: 5 points] [Example: Close Combat Weapon with Specialist Weapon: (-5) points] Total: 0 points Special Rules [Example: Unit has Counter-Attack: 5 points] [Example: Unit has Bulky: (-5) Points] Total: ? points Total cost: [Add all points from Attributes, Wargear, and Special Rules] 0 points Recommend overall cost: [Add total cost to the canon unit/character point total.] 0 points Notes: [This is for explanations behind the various aspects of the created unit/character and to ask questions about things one is unsure about.] Edited November 28, 2017 by Lord Thørn Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/ Share on other sites More sharing options...
Teetengee Posted August 1, 2016 Share Posted August 1, 2016 I am intrigued... Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4454689 Share on other sites More sharing options...
Hesh Kadesh Posted August 1, 2016 Share Posted August 1, 2016 (edited) Things like this can be broken though; ie. Praetor, Power Maul, Refractor Shield WS7, I6 = +15pts Destroyer = +25pts AP2 = 10pts Eternal Warrior = 20pts Include a Ghost Razor ability cost on there, and you've got an instagib anything for 200pts. You need to be I7 or higher to stand a chance of winning. He's hitting first on 3's, rolling on Destroyer Table for wounds/hull points, ignoring armour saves, and if by some miracle you do survive, reduced to Initiative 1, and having to try and put 3 wounds on a 2+/5++ Eternal Warrior. I know it's only a use for a quick matrix, but guys, please don't see this as a character creator, this was simply Simison's private matrix to judge homebrew characters off; mine is very different, for example Weapon Skill is around +15pts. +1 to hit is +17% extra attacks hitting. On a duellist, that extra accuracy is necessary. Edited August 1, 2016 by Hesh Kadesh Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4454711 Share on other sites More sharing options...
MikhalLeNoir Posted August 1, 2016 Share Posted August 1, 2016 (edited) On 8/1/2016 at 2:32 AM, Hesh Kadesh said: Things like this can be broken though; ie. Praetor, Power Maul, Refractor Shield WS7, I6 = +15pts Destroyer = +25pts AP2 = 10pts Eternal Warrior = 20pts Include a Ghost Razor ability cost on there, and you've got an instagib anything for 200pts. You need to be I7 or higher to stand a chance of winning. He's hitting first on 3's, rolling on Destroyer Table for wounds/hull points, ignoring armour saves, and if by some miracle you do survive, reduced to Initiative 1, and having to try and put 3 wounds on a 2+/5++ Eternal Warrior. I know it's only a use for a quick matrix, but guys, please don't see this as a character creator, this was simply Simison's private matrix to judge homebrew characters off; mine is very different, for example Weapon Skill is around +15pts. +1 to hit is +17% extra attacks hitting. On a duellist, that extra accuracy is necessary. Good thing is: if it is broken, we have you as next instance to point it out. But now we are able to at least make some "designs" By the way, I will use your "design" for my char kelenteil^^ Edited August 1, 2016 by MikhalLeNoir Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4454730 Share on other sites More sharing options...
Doctor Perils Posted August 1, 2016 Share Posted August 1, 2016 On 8/1/2016 at 2:32 AM, Hesh Kadesh said: Things like this can be broken though; ie. Praetor, Power Maul, Refractor Shield WS7, I6 = +15pts Destroyer = +25pts AP2 = 10pts Eternal Warrior = 20pts Include a Ghost Razor ability cost on there, and you've got an instagib anything for 200pts. You need to be I7 or higher to stand a chance of winning. He's hitting first on 3's, rolling on Destroyer Table for wounds/hull points, ignoring armour saves, and if by some miracle you do survive, reduced to Initiative 1, and having to try and put 3 wounds on a 2+/5++ Eternal Warrior. I know it's only a use for a quick matrix, but guys, please don't see this as a character creator, this was simply Simison's private matrix to judge homebrew characters off; mine is very different, for example Weapon Skill is around +15pts. +1 to hit is +17% extra attacks hitting. On a duellist, that extra accuracy is necessary. Yeah, we know some combinations will be overpowered of course, and a good part of getting points that work is very much on a unit-per-unit basis + playtesting and more playtesting. However, it's good for some of us (read, me) to have at least a basic idea of where to start. So, yeah, thanks, Simison, for starting this up, and thanks Hesh for pointing out some of your own ways of doing it too :) Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4455260 Share on other sites More sharing options...
Apothecary Meros Posted August 1, 2016 Share Posted August 1, 2016 I like this calculator. I may use this myself - I have a chapter of my own design in the works which would greatly benefit. Thank you, Lord Simison. What of custom or unique rules? Do you think there could be a fair way of devising a calculator for these kinds of rule? For example, I have a rule for my work in progress of Meros which is as follows: Iron Stomach: Any wounds caused by a weapon with the Melta or Lance special rule will never cause Instant Death against Meros. A system of fitting a rule such as this into a category, such as 'survivability' in this instance with a particular points value is the first thing to come to my mind. Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4455288 Share on other sites More sharing options...
Slips Posted August 1, 2016 Share Posted August 1, 2016 Well, that rule is essentially a very specific "Eternal Warrior" so just take whatever Eternal Warrior points up to be and reduce it appropriately. Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4455289 Share on other sites More sharing options...
Apothecary Meros Posted August 1, 2016 Share Posted August 1, 2016 Fair enough. Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4455295 Share on other sites More sharing options...
simison Posted August 1, 2016 Author Share Posted August 1, 2016 I'm aware of the limitations of my matrix. As you rightfully pointed out, Hesh, it operates in a vacuum, focused on the tactical as opposed to the strategic view. That's why I like to hear your opinions. Still, it serves a purpose for easy calibrating, so long as it's used more like guidelines as opposed to hard rules. Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4455405 Share on other sites More sharing options...
simison Posted August 8, 2016 Author Share Posted August 8, 2016 I've added the D3 system. Is the explanation simple enough to understand? Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4461609 Share on other sites More sharing options...
Apothecary Meros Posted August 8, 2016 Share Posted August 8, 2016 It looks good if you ask me. Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4461615 Share on other sites More sharing options...
simison Posted August 8, 2016 Author Share Posted August 8, 2016 I've added a few more rules and a section devoted to saves. Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4461644 Share on other sites More sharing options...
simison Posted August 9, 2016 Author Share Posted August 9, 2016 Alright, I've added most of the core rulebook's special rules (except for the likes of ATSKNF, Swarm, and a couple of others), and most of the special rules I found in HH books 1-3 & 5. How does it looks? Is there a special rule that should be here? Did I miss anything? Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4462569 Share on other sites More sharing options...
Doctor Perils Posted August 9, 2016 Share Posted August 9, 2016 That's really great simison, thanks :) Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4462634 Share on other sites More sharing options...
Apothecary Meros Posted August 9, 2016 Share Posted August 9, 2016 Indeed, truly marvellous. I believe a rule for the Leman Russ tank is Lumbering Behemoth - which if I remember correctly limits a vehicle to 6" per turn. Speaking of which, you could if you wanted, add points values for armour values and hull points if one were to want to create their own vehicle unit. Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4462653 Share on other sites More sharing options...
simison Posted August 9, 2016 Author Share Posted August 9, 2016 Did you know that none of the 30k Leman Russes have that rule? I've started a vehicle section and will put in Lumbering Behemoth along with Induction Charger later when I have more time. I came up with the pointages by comparing the Contemptor Mortis with a normal Mortis and a Leman Russ Strike Squadron against a Leman Russ Assault Squadron. Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4462716 Share on other sites More sharing options...
MikhalLeNoir Posted August 9, 2016 Share Posted August 9, 2016 Do you plan to make a point calculator for units as well? Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4462718 Share on other sites More sharing options...
AlphariusOmegon108 Posted August 9, 2016 Share Posted August 9, 2016 On 8/9/2016 at 9:05 PM, MikhalLeNoir said: Do you plan to make a point calculator for units as well? want Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4462764 Share on other sites More sharing options...
simison Posted August 11, 2016 Author Share Posted August 11, 2016 I've added Inductor Charges & Lumbering Behemoth. On 8/9/2016 at 9:05 PM, MikhalLeNoir said: Do you plan to make a point calculator for units as well? What would be the difference? Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4464540 Share on other sites More sharing options...
MikhalLeNoir Posted August 11, 2016 Share Posted August 11, 2016 You are the point calculator here. You tell me^^ So i am able to create a whole unit with it? Do I need to count the points for every single marine in the unit or do we have a group price? Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4464606 Share on other sites More sharing options...
simison Posted August 11, 2016 Author Share Posted August 11, 2016 Hmmm, most of the special rules seemed to be bought once for the group as a whole, if I'm remembering how GW does it. The attributes would be on an individual basis, while some special rules, like Eternal Warrior, would be outright banned from groups. Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4464670 Share on other sites More sharing options...
MikhalLeNoir Posted August 11, 2016 Share Posted August 11, 2016 Just imagined a special unit consisting of eternal warriors. Uuuhhhh. So much power.....(lost) Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4464705 Share on other sites More sharing options...
Apothecary Meros Posted August 11, 2016 Share Posted August 11, 2016 On 8/11/2016 at 7:08 PM, MikhalLeNoir said: Just imagined a special unit consisting of eternal warriors. Uuuhhhh. So much power.....(lost) Well, with Matt Ward back at GW, it's only a matter of time until that's a reality... a truly horrifying reality. Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4464753 Share on other sites More sharing options...
MikhalLeNoir Posted August 11, 2016 Share Posted August 11, 2016 Why can't they try to get Amdy Chambers back? Why Matt Ward???? Wwwwwhhhhhhhyyyyyyyyyyyyy!!!! Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4464763 Share on other sites More sharing options...
Grifftofer Posted August 11, 2016 Share Posted August 11, 2016 It's fine we'll just have to get there first. We can put Eternal Warrior on a unit Reveal hidden contents of one wound models http://image.bolterandchainsword.com//public/style_emoticons/default/msn-wink.gif Link to comment https://bolterandchainsword.com/topic/324327-rules-point-calculator/#findComment-4464769 Share on other sites More sharing options...
