Brother-Chaplain Kage Posted August 9, 2017 Share Posted August 9, 2017 (edited) Greetings, brothers! Has GW neglected one of your favorite character models for years? *cough*Abaddon, Phoenix Lords*cough* Has GW given you an unsatisfactory character model? Did they never make one? Even if it's none of the above, do you think you can do a better job of it or not want to drop the cash? Then have I got the challenge for you! Beginning September 1, 2017 and running until October 1, 2017, I will be hosting a conversion challenge to build your own version of a special character! Rules, which I have shamelessly stolen borrowed from some of Grotsmasha's earlier challenges, are as follows: 1) The finished model is not to be painted and the conversion should be bare plastic/resin/metal though the odd painted piece stolen from a previously painted model is OK.2) WYSIWYG applies here, so all relevant gear needs to be on the figure. 3) Maximum of 25% existing Character model:---25% consists of the following combinations;--- Head- 0% can be from any existing model---1x Arm- 12.5%, 2x Arms- 25% either from the same or separate models---1x Leg- 12.5%, 2x Legs- 25% either from the same or separate models---Torso- 25%---Things like FW's Red Scorpion upgrade pack DO NOT count toward the 25% limitation. ---If the character never had a model, this part applies to any existing character model you might want to use parts from. This is a conversion challenge after all! 4) Green Stuff/Sculpting putty is fine, from small details up to a full sculpt if you think you can pull it off.5) 1 calendar month build time; September 1st 2017 until October 2nd 2017. 6) Multiple entries will be accepted provided you finish your first entry. 7) You must declare participation a minimum of 24hrs prior to declaring completion! 8) Characters must use their most recent rules, whether from one of the indexes, or their respective codex if it is available. But what if you want to make a counts-as for a character that's no longer with us? Grukk Face-Rippa, Nuadhu Fireheart, Sly Marbo, Most of the Dark Eldar characters, Captain Cortez, and Old One-Eye being just a few examples. Well, you can do that to, but the above rules still apply. If you're interested, start gathering ideas and bits and a sign-up thread with signature banners will follow in a few weeks. Edited September 11, 2017 by Brother Chaplain Kage Aqui, Vairocanum, Kizzdougs and 5 others 8 Back to top Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/ Share on other sites More sharing options...
Cryptix Posted August 9, 2017 Share Posted August 9, 2017 Past, Old One Eye has rules. You likely either meant the Parasite of Mortex or the Doom of Malantai. Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4849922 Share on other sites More sharing options...
Brother-Chaplain Kage Posted August 9, 2017 Author Share Posted August 9, 2017 I meant One-Eye but I didn't think GW was making rules for models they no longer produced. Oops. Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4849949 Share on other sites More sharing options...
Kizzdougs Posted August 9, 2017 Share Posted August 9, 2017 Sounds like fun! Now I just need to decide on a character... :) A quick question: "3) Maximum of 25% existing models in Metal/Finecast, and any Plastic Independent/Named Characters: What does this mean, exactly? When you say "existing models" do you mean the GW sculpt of the Character that we are making our own version of, or all GW models? Is the 25% limitation only applicable to the stock GW version of the character that we are converting? Take Calgar as an example: If I built him using only parts from the plastic Terminators box set would that be okay? Or could I build him using <25% of the stock Calgar model (the torso or two arms eg.) and the other 75% from the plastic Terminator kit? Or would I only be able to use 25% from the stock Calgar model, 25% from the Terminator kit and the other 50% of parts would have to come from a minimum of two seperate kits/models (25+25=50)? ---25% consists of the following combinations;--- Head- 0% can be from any existing model---1x Arm- 12.5%, 2x Arms- 25% either from the same or separate models---1x Leg- 12.5%, 2x Legs- 25% either from the same or separate models---Torso- 25% Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4849950 Share on other sites More sharing options...
Brother-Chaplain Kage Posted August 9, 2017 Author Share Posted August 9, 2017 (edited) I forgot to paste the updated version, which is fixed now. So a max of 25% of the original character model and the rest can come from other sources. Edited August 9, 2017 by Brother Chaplain Kage Kizzdougs 1 Back to top Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4849957 Share on other sites More sharing options...
Kizzdougs Posted August 9, 2017 Share Posted August 9, 2017 (edited) I forgot to paste the updated version, which is fixed now. So a max of 25% of the original character model and the rest can come from other sources. Excellent! I assumed that was the case, but just wanted to make sure Edit: Also, you mentioned the Dark Eldar characters. GW never released official models for several of those characters (the Barron, Duke etc.), so is it okay to convert a character that has/had rules but never a model (Saul Tarvitz, Lias Issodon, Inquisitor Valeria etc.)? Edited August 9, 2017 by Kizzdougs Brother-Chaplain Kage and lionofjudah 2 Back to top Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4849961 Share on other sites More sharing options...
Brother-Chaplain Kage Posted August 9, 2017 Author Share Posted August 9, 2017 Yup! I would love to see a Duke Sliscus or some of the many HH characters that never got made. Kizzdougs 1 Back to top Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4849972 Share on other sites More sharing options...
rednekkboss Posted August 9, 2017 Share Posted August 9, 2017 I still have to do my version of Lucius (among others) I'm definitely in on this one. Brother-Chaplain Kage 1 Back to top Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4849990 Share on other sites More sharing options...
rednekkboss Posted August 9, 2017 Share Posted August 9, 2017 One question: When you say 25% of existing character model, you mean the current model ? Or any character model? Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4849991 Share on other sites More sharing options...
Brother-Chaplain Kage Posted August 9, 2017 Author Share Posted August 9, 2017 I'll be entering something, maybe a third Phoenix Lord, but I'll be exempt from winning the challenge as the event runner. rednekkboss 1 Back to top Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4849993 Share on other sites More sharing options...
Aasfresser Posted August 9, 2017 Share Posted August 9, 2017 (edited) I'd join with my current Huron project, if it is ok that I already started. Edit: Just saw the event starts in September, narf. Edited August 9, 2017 by Aasfresser Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4850006 Share on other sites More sharing options...
Sagentus Posted August 9, 2017 Share Posted August 9, 2017 I need to sort my schedule out because after reading the new renegade tactics on warhammer community. The tactics for fabius bile in a bezerker squad are to good to pass up Brother-Chaplain Kage 1 Back to top Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4850248 Share on other sites More sharing options...
The Traitor Posted August 9, 2017 Share Posted August 9, 2017 Is there a limit for subscription? This seems like an event in where I would like to participate, but I have a tournament the 16 of september and need to get a damn lot of models ready for then, so I doubt I'll be able to start anything before... @Sagentus: tried once pre-codex using 20 berzerkers buffed by Fabius bile, a sorcerer to cast warp time on them and a chaos lord on bike to give them re-rolls. Y got the +1 attack boon and only two berzerkers died to Fabius "gifts". They managed to kill a rhino, 5 melta chosen, 5 havocs with misdile launcher a chaos lord and left a daemon prince with one wound before dying... Not too recommendable though, if it had been a more competitive game they would all have most probably died before getting to attack. Brother-Chaplain Kage 1 Back to top Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4850526 Share on other sites More sharing options...
Sagentus Posted August 9, 2017 Share Posted August 9, 2017 @Traitor - Hmm, I will remember that when/if i play games. I normally just build armies for fun and make sure i stick with the codex's just incase i do get a game. Plus he would be a great idea for this conversion challenge :) Currently looking at referance pics to see what bits i could use ;) Brother-Chaplain Kage 1 Back to top Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4850560 Share on other sites More sharing options...
Capt. Jack Posted August 9, 2017 Share Posted August 9, 2017 (edited) I might just have to take part in this challenge! Edited August 9, 2017 by Capt. Jack Brother-Chaplain Kage 1 Back to top Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4850565 Share on other sites More sharing options...
Claws and Effect Posted August 9, 2017 Share Posted August 9, 2017 I will definitely be taking part in this. Kayvaan Shrike's official model looks ridiculous. Based on the pose they put him in, it appears the hills are alive with the sound of Ravens. GREY88 and Brother-Chaplain Kage 2 Back to top Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4850582 Share on other sites More sharing options...
Torvak Kyre Posted August 9, 2017 Share Posted August 9, 2017 So does it have to be characters that have rules or could you do someone like Raldoran? Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4850790 Share on other sites More sharing options...
Aasfresser Posted August 9, 2017 Share Posted August 9, 2017 So does it have to be characters that have rules or could you do someone like Raldoran? Good question. I wanted to build my own version of Khayon for a while now. Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4850807 Share on other sites More sharing options...
Brother-Chaplain Kage Posted August 10, 2017 Author Share Posted August 10, 2017 Is there a limit for subscription? This seems like an event in where I would like to participate, but I have a tournament the 16 of september and need to get a damn lot of models ready for then, so I doubt I'll be able to start anything before... There's no entry cut-off date so you'll be fine. The one entry stipulation is that you must pledge your entry at least 24 hours before completion. So does it have to be characters that have rules or could you do someone like Raldoran? Hmmm, I hadn't thought about that. Ummm... I'm going to say that to be eligible for the judging and winning it had to have rules at some point in time but if you want to enter a non-competition entry that never had rules, feel free! Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4851135 Share on other sites More sharing options...
Grotsmasha Posted August 10, 2017 Share Posted August 10, 2017 One question: When you say 25% of existing character model, you mean the current model ? Or any character model? It would be 25% from the original model of the character you are doing. Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4851238 Share on other sites More sharing options...
Biohazard Posted August 10, 2017 Share Posted August 10, 2017 I may be up for this. I have. Lucius to build and possibly. Huron Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4851280 Share on other sites More sharing options...
rednekkboss Posted August 10, 2017 Share Posted August 10, 2017 One question: When you say 25% of existing character model, you mean the current model ? Or any character model? It would be 25% from the original model of the character you are doing. Well there goes my Lucius idea. Hmmmmm ....maybe Cap'n Badrukk. That big lump of metal is not fitting a Warboss. Or I could join the many Abbadon conversions. Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4851285 Share on other sites More sharing options...
Brother-Chaplain Kage Posted August 10, 2017 Author Share Posted August 10, 2017 Just to make it 100% clear, you DO NOT have to use the original figure at all. If you want to make a completely new figure for your character without any part of the original, that's fine. rednekkboss 1 Back to top Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4852418 Share on other sites More sharing options...
Sagentus Posted August 10, 2017 Share Posted August 10, 2017 Okay, so say for example I wanted to use a dv chosen figure as a Base for said model. Can I only use the 25% of that figure as stated? More of a clarification question so I can keep my options open. Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4852428 Share on other sites More sharing options...
The Traitor Posted August 10, 2017 Share Posted August 10, 2017 Is there a limit for subscription? This seems like an event in where I would like to participate, but I have a tournament the 16 of september and need to get a damn lot of models ready for then, so I doubt I'll be able to start anything before... There's no entry cut-off date so you'll be fine. The one entry stipulation is that you must pledge your entry at least 24 hours before completion. Ok great to know, there's no way I'll sculpt a model in less than a day though, so no worries on that :P! I don't know what I'll do, maybe my army could benefit from one of those new exalted champions... Link to comment https://bolterandchainsword.com/topic/337844-bcks-character-conversion-challenge-announcement/#findComment-4852541 Share on other sites More sharing options...
