Fajita Fan Posted November 5, 2018 Share Posted November 5, 2018 I just realized how much easier it is to glue in Knight arm sockets without the top armor piece on there... Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5185874 Share on other sites More sharing options...
Mendi Warrior Posted November 5, 2018 Author Share Posted November 5, 2018 Absolutely, I left the carapaces unglued so far. Just be watchful when gluing the heavy stubber or melta to the carapace as there is not a lot of room if you want to position them nicely and be able to remove the carapace afterwards for painting (dry fit, as for every AT pieces, helps) Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5185891 Share on other sites More sharing options...
Fajita Fan Posted November 5, 2018 Share Posted November 5, 2018 And my hands shake as I try to jam that little stubber in, its kinda worrying. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5185993 Share on other sites More sharing options...
Mendi Warrior Posted November 5, 2018 Author Share Posted November 5, 2018 this also happens sometimes when I'm too tired or too stressed, just leave it for later, maybe with a pair of pliers to improve control on the tiny bits I use one for the cables of the reaver. I encountered a little issue when adding them to my latest reaver. I went for the right leg positioned with an angle slightly over 90 Noserenda and Brother Dallo 2 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5186150 Share on other sites More sharing options...
Fajita Fan Posted November 5, 2018 Share Posted November 5, 2018 (edited) Nice! That's a good idea joining two buildings like that, much easier than what I tried to do... Edited November 5, 2018 by Fajita Fan Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5186158 Share on other sites More sharing options...
Mendi Warrior Posted November 5, 2018 Author Share Posted November 5, 2018 Oh, that is just a mock up, not planning on actually joining them like that but that could definitely work (adding debris and stuff) Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5186168 Share on other sites More sharing options...
Fajita Fan Posted November 6, 2018 Share Posted November 6, 2018 It’s an easier way to make a building that’s being stepped on, like its collapsing in on itself. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5186226 Share on other sites More sharing options...
Mendi Warrior Posted November 11, 2018 Author Share Posted November 11, 2018 True, I hadn't thought of that, that is a great idea I added a couple of magnets to my warlords, I should have done it earlier but I delayed it hoping for more info on the additional weapons, eventually I decided to go ahead with some anyway So I started adding 4x1mm magnets for magnetising the heads, I drilled so as to have at least 1mm depth to fix the magnet, I didn't drilled through as the plastic there is sufficiently thick. Once this was done I proceeded with the legs - torso joint. As you can see in the pics I haven't glued the torso's base (the part with the railings) yet, it definitely helps for achieving what I wanted. I took a couple of measures to determine how best to do it. First step there was to insert 1mm thick plasticard (measuring 17x13mm) to have a base on which to glue the magnet for the torso (see picture). Then I added a second 1mm layer of plasticard on which I glued a 4x1mm magnet. This leaves about 3mm from the magnet to the edge of the torso. The thickness of the torso's base is about 3mm too. And this allows to arrive nicely at the same level as the edge of the upper part of the "pelvis". As the "pelvis" is hollow, I filled it with some insulation foamboard to which I glued a little piece of plasticard (1mm thickness) on which I glued a 4x1mm magnet. The magnet should not be higher than the edge (if it is, the insulation foamboard can be compressed a little bit). The 4x1mm magnets are sufficient imho, especially if you don't plan to suspend your warlord upside down and shake it. I would probably not go for smaller ones. Brother Dallo 1 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5189323 Share on other sites More sharing options...
Fajita Fan Posted November 11, 2018 Share Posted November 11, 2018 I strongly considered magnetizing my Warlord torsos like that and it's still possible given they're separate for painting. A good place to do it would've been under the gankplank and on either side of the pelvis but I've already glued that. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5189329 Share on other sites More sharing options...
Brother Dallo Posted November 11, 2018 Share Posted November 11, 2018 Nice to see some progress on your Warlord. One thing I've found interesting is the multiple different ways Fraters magnetise their Titans. Â Was there a reason you chose 4mm over 5 mm? Â Keep up the good work. Â Dallo Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5189439 Share on other sites More sharing options...
Captain Semper Posted November 11, 2018 Share Posted November 11, 2018 Good progress there Mendi - the Warlords magenitzation looks good. And once more the Reaver legs present problems. Truth being said, if you go for very dynamic poses it’s bound to create some inconsistneces. These are supposed to be huge machines so go for dynamic posing at your risk! I faced similar issues with the Warlord...:rolleyes: Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5189457 Share on other sites More sharing options...
Mendi Warrior Posted November 11, 2018 Author Share Posted November 11, 2018 (edited) Thanks guys No particular reason for using 4x1mm magnets over 5x1mm ones other than having more 4x1mm magnets available than 5x1mm ones and saving the remaining 5x1mm ones for the upcoming additional warlord weapons. They do the job and once the legs are painted the thin coat of paint adds some thickness which makes it fit tighter. Just put together a couple pics to help visualize the measures I was talking about. Inside of the torso you ave about 6mm between the edge and the interior of the recesses foreseen to fix the small lateral armour plates on the torso (see steps 28 - 29). I took a pic of step 17 of the instructions as this was much quicker than anything else (especially with the torsos being assembled). If I am to build an additional warlord, I'll also prepare the various components for adding magnets before assembling (when individual components are concerned) or right after completing a specific sub-assembly (e.g. the weapon support parts) like I did for my latest 2 reavers. Dynamic posing is great but there are quite a few constraints to take into account. And you'll learn them by doing or by reading what others experienced. Assembling the reaver's legs properly is probably the sub-assembly I spent the most time on, constantly checking the instructions, dry-fitting, checking the 360° view on GW website, … Based on what I already experienced and saw in other posts or elsewhere I put together a quick visual help. Please review it and let me know if there are errors or things that are unclear. Again, checking the instructions, dry fitting and checking the 360° view on GW website are a good help. I hope this will be useful. Edited November 11, 2018 by Mendi Warrior Sandlemad, Brother Dallo, shandwen and 1 other 4 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5189546 Share on other sites More sharing options...
Brother Dallo Posted November 11, 2018 Share Posted November 11, 2018 I think your idiot proof guide for Reaver legs will prove very useful in future Reaver builds. Â Thanks for taking the time to put it together. Â Dallo Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5189550 Share on other sites More sharing options...
Mendi Warrior Posted November 11, 2018 Author Share Posted November 11, 2018 I was forgetting about the front and back pistons which are very important constraints. Also, don't forget the legs' armour plates. Dry fitting them is key to avoid bad surprises. I definitely hope it will be helpful, again please review and let me know if there are mistakes or things that are unclear. Brother Dallo, shandwen, Captain Semper and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5189551 Share on other sites More sharing options...
Captain Semper Posted November 11, 2018 Share Posted November 11, 2018 This is indeed very helpful. And thorough... In fact one of the issues I experienced with the Warlord, was the leg pistons that run outside their guides due to the positioning of the lower leg. And it didn't seem all that dynamic a pose to begin with which makes think there is little tolerance on the posing... Â Now I can't wait to start on my Reavers - thanks man! :D Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5189578 Share on other sites More sharing options...
librisrouge Posted November 13, 2018 Share Posted November 13, 2018 Because why just play a game when you can lose your entire soul to it!  I applaud everything on this blog and look forward to it continuing. Mendi Warrior and Parweke 2 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5191054 Share on other sites More sharing options...
Chaeron Posted November 13, 2018 Share Posted November 13, 2018 Really helpful guides Mendi Warrior - thanks for those! Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5191148 Share on other sites More sharing options...
Mendi Warrior Posted November 14, 2018 Author Share Posted November 14, 2018 Thanks guys.  I think the new weapons' sprue for the warlord answers my questions for magnetizing the weapons. A 5x1mm magnet at the top of the "arm" piece should be sufficient, no need to magnetize at the joint between the "arm" and the weapon (unless of course you want to switch them from right to left and vice-versa at will). Still debating doing it or not Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5191502 Share on other sites More sharing options...
RipOffProductions Posted November 14, 2018 Share Posted November 14, 2018 Thanks guys.  I think the new weapons' sprue for the warlord answers my questions for magnetizing the weapons. A 5x1mm magnet at the top of the "arm" piece should be sufficient, no need to magnetize at the joint between the "arm" and the weapon (unless of course you want to switch them from right to left and vice-versa at will). Still debating doing it or not well, so far every arm weapon has come in sets of two on the sprue, except the power claw, but that thing would likely require a lot of work with vary tiny magnets to make reversible, what with the thumb and any other little bits that help distinguish the left or right handedness of the claw. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5191795 Share on other sites More sharing options...
Chaeron Posted November 15, 2018 Share Posted November 15, 2018  Thanks guys.  I think the new weapons' sprue for the warlord answers my questions for magnetizing the weapons. A 5x1mm magnet at the top of the "arm" piece should be sufficient, no need to magnetize at the joint between the "arm" and the weapon (unless of course you want to switch them from right to left and vice-versa at will). Still debating doing it or not well, so far every arm weapon has come in sets of two on the sprue, except the power claw, but that thing would likely require a lot of work with vary tiny magnets to make reversible, what with the thumb and any other little bits that help distinguish the left or right handedness of the claw.   That's true - you might be able to make that work with a pipecleaner/paperclip, so it could be bent back and forth to the correct position, but appreciate that isn't ideal. A ball magnet to replace the bottom of the thumb would most likely be the best option if that was a serious thought - I think it'd be great! Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5191803 Share on other sites More sharing options...
Mendi Warrior Posted November 15, 2018 Author Share Posted November 15, 2018 For the reaver I have thought about magnetising the power fist at each joint but that would indeed be a lot of work. Still debating doing it or not, maybe I'll do it for one or two, but most likely not for each and every one. Â For the arioch claw, 1x1mm magnets for the fingers/claws could probably do the trick. Probably only the thumb is absolutely required if you go that road. Â The cables would likely be the trickiest. I thought about maybe using electric wire (I have leftovers from when I refurbished my apartment) but they are smooth. Idea is to drill holes into th carapace/body where the cables go, as it is typically hollow just have the wire length's long enough for the most extended pose. Â Anyway, so far this remains theoretical ideas. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5191942 Share on other sites More sharing options...
Sandlemad Posted November 15, 2018 Share Posted November 15, 2018 That guide is wonderful, thank you Mendi Warrior. My paralysing fear of assembling these reavers has something to work with now. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5191965 Share on other sites More sharing options...
Mendi Warrior Posted November 15, 2018 Author Share Posted November 15, 2018 Thanks a lot. Seeing how many of us at some point struggle with assembling the legs it seemed a good idea to share this. Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5191968 Share on other sites More sharing options...
Mendi Warrior Posted November 16, 2018 Author Share Posted November 16, 2018 A quick addition to my terrain, modular, work-in-progress, using foamboard to save a few civitas imperialis components, with details to add A while ago I posted a little teaser of a Cities of Death component I cut into several pieces. So, what did I do with these? I added some foamboard to fill in the aquila part. Then I took some cardboard and drew many lines after taking some measures. I then glued the aquila, the top of the "wings" and the tail into place, and added triangles of cardboard to start building the structure. It remained so for a couple of days until I figured out a solution for the structure. I built the left and right sides of the torso in cardboard, in a similar way to the wings. Then again inspiration took a few days to arrive, and after gluing the torso and wings, I finally covered them with coffee stirrers. fisheyedbunny, Brother Dallo, Cpt. Bannockburn and 2 others 5 Back to top Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5193055 Share on other sites More sharing options...
Chaeron Posted November 16, 2018 Share Posted November 16, 2018 Simply brilliant Mendi Warrior - I love the Aquila. Fantastic work! Link to comment https://bolterandchainsword.com/topic/350487-mendi-warriors-adeptus-titanicus-project-log/page/3/#findComment-5193063 Share on other sites More sharing options...
