HighMarshalAmp Posted December 19, 2020 Share Posted December 19, 2020 It doesn't say on the Relic Terminator datasheet that the models have any special kind of armor. So if I had Cataphractii equipped according to the NON-Relic Terminator Datasheet, I could just run them as Terminators without paying a CP, right? Link to comment https://bolterandchainsword.com/topic/368230-cataphractii-as-non-relic-terminators/ Share on other sites More sharing options...
Karhedron Posted December 19, 2020 Share Posted December 19, 2020 Sounds fine. As long as the models are a fair representation of the unit you are fielding then go for it. The only time it could get awkward is if you are also running an actual squad of relic Terminators. As a rule of thumb, if your opponent can tell which models on the table are a particular unit from your list, it should be fine. BLACK BLŒ FLY and Aarik 2 Back to top Link to comment https://bolterandchainsword.com/topic/368230-cataphractii-as-non-relic-terminators/#findComment-5646136 Share on other sites More sharing options...
Iron Lord Posted December 19, 2020 Share Posted December 19, 2020 (edited) I'm pretty sure Cataphracti don't "cost extra CP" the way other units with the word Relic in the name do, because they don't have "Martial Legacy". It's "Martial Legacy", not "Relic", that makes a Relic Contemptor from the Forgeworld book, for example, cost extra CP to include in your army. The "relics of the Chapter" in the main SM book, are items, to equip characters with, and you don't need to spend CP on the Relic Of The Chapter stratagem to include Relic Terminators. I'm guessing 30K Forgeworld Cataphracti would be the sorts of things you'd want to include, as "Cataphracti-armoured regular terminators". Guys with hammers and shields, or cyclone launchers, or assault cannons, that sort of thing? Edited December 19, 2020 by Iron Lord Link to comment https://bolterandchainsword.com/topic/368230-cataphractii-as-non-relic-terminators/#findComment-5646148 Share on other sites More sharing options...
TheNewman Posted December 19, 2020 Share Posted December 19, 2020 Yes, as long as your Terminators are armed according to the data sheet and you aren't fielding another squad of the same Terminator models that actually are Relic Terminators you should be fine. Link to comment https://bolterandchainsword.com/topic/368230-cataphractii-as-non-relic-terminators/#findComment-5646153 Share on other sites More sharing options...
Gederas Posted December 19, 2020 Share Posted December 19, 2020 I mean, now it's down to Wargear. So if there's Cataphractii with thunder hammers and Storm Shields? Clearly just an Assault Terminator squad, because Relic Terminators can't take those The issue is Cataphractii with dual Lightning Claws or Combi-Bolter/Heavy Flamer/Power Fist/Chainfist as those are loadouts that are shared between Relic Terminators and the normal Terminator squads. Which is why in those cases you give the Sergeant a Volkite Charger or Plasma Blaster :lol: Link to comment https://bolterandchainsword.com/topic/368230-cataphractii-as-non-relic-terminators/#findComment-5646203 Share on other sites More sharing options...
