Salamander Terminators
Psythu
I like the heads. One way or another.
If you want them to look like real heads, they are great.
If you want them to look like helemts you could try to add some extremely thinned glazes of boltgun/chainmail/mithril or any other metallic colour you like so that the flake will give the heads a metallic sheen (gold maybe because they are elites :tu: ). I have seen this a few times and it looks pretty good in person. The problem is that it is hard to photograph... so you will have to try it out yourself or find someone who paints this way in case you want to see examples :blush: .
Another possibility would be mixing the metal colours with your normal colours (i.e. green, red...). My brother did this while he was trying to come up with a paintscheme for his necrons, and it looks surprisingly well (and it looks completely different than inking...).
Maybe metallic eyelenses would add to the appearance of a helmet (even though i don't really like the idea myself :pinch: )
Ah well, I like what you have done. And there is no need to change anything if you are happy yourself with the way they look.
Another update! Finished terminator number 3 late last night, so here it is for you all.
http://img461.imageshack.us/img461/5855/squadmalleopipmontage4ftl6.jpg
Base is a little messy, might tidy that up later. None of them have the lenses on their shoulder mounted... things... painted yet; I'm going to do them all at once when everything else is done.
Ekkanus; Thanks for the compliment! Clicking a member's name takes you to their profile, under profile options is "view member topics" which'll take you to a spiffy page like this
they look great, the constrasting bone shields and the dark red head/helmets make a difference. Like all im not really sure about the heads but keeping in mind the Salamanders are masters of the forge, I dont think its hard to believe they could pull it off... There has been 'weirder' stuff around these forums :(
Last one done, although despite being the serg he's my least favourite. I don't see any point showing you the sides/back, you already know what they look like. There'll be a post in Hall of Honour later with these, including group shots.
http://img131.imageshack.us/img131/1396/squadmalleopip19forumskd8.jpg
  • 11 months later...
Scales:
-Use thinner GS layers.
-Try to use only or as many 5 and 6 corner scales as possible as those are the natural shapes and not 4 corner scales.
More corners is not "natural" but looks more organic then 4 corners.
-After the scale pattern is done but before the GS cures use something flat like a knife blade to carefully "flatten" the scales. It will make the finished scale look less "bumpy".
Examples of my greenstuff scales using these techniques:
Forgot to "de-bump" the scales on this part and thus they look to rough:
http://img.photobucket.com/albums/v231/Pyriel/Greenstuff/7.jpg
Also to rough scales on this shoulder:
http://img.photobucket.com/albums/v231/Pyriel/1st%20comp/TERM2.jpg
Although still to thick green stuff layer flattening them will produce more smooth scales like these:
http://img.photobucket.com/albums/v231/Pyriel/Greenstuff/termie-shields.jpg
Painted up:
http://img.photobucket.com/albums/v231/Pyriel/1st%20comp/DSC00232.jpg
Finally, thin and flattened out greenstuff scales with many corners will produce the best results like on my vet sergeants:
http://img.photobucket.com/albums/v231/Pyriel/Greenstuff/1CM.jpg
http://img.photobucket.com/albums/v231/Pyriel/Greenstuff/5CM.jpg
As for lizard terminator heads:
I use a sculpted on head on my HQ instead of having the normal head switched to a lizard head. It gives the terminator a lizard look without having the mini look like a mutant-ish-kinda-sorta ;)
Here is a wip:
http://img.photobucket.com/albums/v231/Pyriel/Greenstuff/helmet1.jpg
Keep it up dude, we need more great looking sallies out there :D
