Plague marines á la Animerik
Animerik
  • 1 month later...
++UPDATE++
Well it was quite a while since I updated this and honesly I have not been working that much on it. Have been busy with visiting a viking era market/festival, Depeche mode condert and a music festival (Arvika) and of course spending time wit my gf. Not much time left for ol warhammer. Anyways I have been painting another squad so here´s a quick recap of all the PMs painted so far
squad 1:
http://i2.photobucket.com/albums/y21/animerik/DSC018071.jpg
squad 2:
http://i2.photobucket.com/albums/y21/animerik/DSC018131.jpg
squad 3:
http://i2.photobucket.com/albums/y21/animerik/DSC018231.jpg
pics are crapalicous as usual... anyhow, next up is a PIP rhino, it got a bit wrecked during a transport after I completed the build and the glue was not completly set, this resulted in a wonky looking dozerblade and headlight that is far from straight... well well. I been testing some techniques to make it look old and worn but I´m not to happy with the results... I will just finish it and then maybe get back to it later and re do it. For the time being I´m sick of it and just want to finish it. And the freehand on the roof is crap I know but as said, will redo this junk later.
http://i2.photobucket.com/albums/y21/animerik/DSC018351.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC018291.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC018311.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC018321.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC018331.jpg
Well something I'm more happy with is the oblits, one all done so far only a lick of paint.
http://i2.photobucket.com/albums/y21/animerik/DSC018391.jpg
more angles:
http://i2.photobucket.com/albums/y21/animerik/DSC018401.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC018411.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC018421.jpg
And no.2 wip
http://i2.photobucket.com/albums/y21/animerik/DSC018371.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC018381.jpg
thanks for looking //Erik
This is the coolest nurgle army yet, especially the obliterators! Did you use SM termies?
I think he used the Oblit models. If you look closely you can see them peaking out from beneath his amazing sculpting work! :)
Great army, I was a huge fan of your Fantasy army over on Warseer.
++UPDATE++
Here we go again. Last night I was looking at old threads amd came across a good ol one. Squiggs PMs, he made a termi lord with a old chainsword and I took alot off inspiration (read looted/ripped off) and found a old mini in bad shape. After some hours of gs loving and bitz it looked really good. I will probably enter it to the TWF convertion/painting comp. In the army it will be a lord for smaller battles.
http://i2.photobucket.com/albums/y21/animerik/DSC01854.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC01853.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC01852.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC01850.jpg
Still some mould lines to fix and gs to clean up or such, I´m very happy with it so far.
Also started a DP, this will go slow, very slow but I try to push myself further and challenging myself with new stuff.
http://i2.photobucket.com/albums/y21/animerik/DSC01856.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC01857.jpg
Also started my last 7 PMs for my 2250pts list. Wip of course
http://i2.photobucket.com/albums/y21/animerik/DSC01865.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC01867.jpg
Oh and something people wanted...
++OBLIT TUTORIAL PART 1++
Materials needed
*Plastic rod - riverts, pistons stuff like that
*Green stuff/ brown stuff/ grey stuff whatever putty you like
*Plastic pipes - To make the base for the legs. Chose your own thickness depending on if you want to make termies, oblits or even DPs.
*Foam core or thick plasti cart - To use as the underlying structure for the back and torso.
Step one.
Take some pipe and cut it up equall to the size you want the lower legs to be. Take some putty and mix it, then roll it to a sausage and add it to the lower part closest to the feet. Next take a tool and just drag the putty upwards to create a shape where the leg is broader closer to the feet and narrower at the knee. I allways do this quickly with a tool and then go back and smooth it out with my finger (remember to use lots of water on you tools/fingers) sometimes I use clay shapers as well.
After this cut up some pipe to use as upper leg parts, add these by using putty and some glue.
Take some foamcore and cut it up equall to the size you want the torso to be broad. Take some pipe (I used the same size as I used for the lower part of the legs) and cut it a bit longer than the torso. Glue it like in the pic (see pic A). Also cut a thinner slize of pipe and cut that in two parts, glue this above the other piece of pipe to function as a "roof", this will be where the head will be placed later. Now take som putty and add to the space between the pipe and the foamcore to make it more torso looking. Smooth it out with your finger and try to get a good shape to it as this will be the base for the chest armour later on.
PIC A.
http://i2.photobucket.com/albums/y21/animerik/DSC01805.jpg
* side note! If you want to make it easier, just take a marine shoulder pad and glue it above the pipe like in pic B, this is what I did for the first two oblits.
PIC B:
http://i2.photobucket.com/albums/y21/animerik/DSC01868.jpg
Thanks for looking and more comming later. Cheers
++UPDATE++
Well some work on the champ, just trying to paint something to a bit higher standard.. still not there yet. painob is about 75% done I recon.
http://i2.photobucket.com/albums/y21/animerik/DSC018811.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC018821.jpg
And some small progress on the DP
http://i2.photobucket.com/albums/y21/animerik/DSC018841.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC018861.jpg
Hope you like it, C&C welcome
Cheers //Erik
Cant wait to see the progress on your DP after looking over your Obliterators for like 30´th time now simply awsome and werry nice work and modds on the Lord there and a nice toutch with a chainsword on him too ;) filthy and brutal :tu: hehe ..
Cheers mate
  • 5 weeks later...
I really busy atm so here is some sneak peaks of what I have been doing and mainly to show that I´m still at it.
pip oblit
http://i2.photobucket.com/albums/y21/animerik/DSC019471.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC019531.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC019501.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC019491.jpg
and some pip squad
http://i2.photobucket.com/albums/y21/animerik/DSC019591.jpg
thanks for looking.
  • 1 month later...
++UPDATE++
Well have nor been working so much with warhammer latley, but here´s some better pictures and pics on some of the stuff I have been working with..
Oblit:
http://i2.photobucket.com/albums/y21/animerik/DSC021331.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC021351.jpg
more angles:
http://i2.photobucket.com/albums/y21/animerik/DSC021341.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC021361.jpg
Some stuff still to paint, mostly picking out details and making the osl look more realistic
Oblit no2. Soon done:
http://i2.photobucket.com/albums/y21/animerik/DSC021291.jpg
Termicide http://i2.photobucket.com/albums/y21/animerik/DSC021271.jpg
DP:http://i2.photobucket.com/albums/y21/animerik/DSC021411.jpg
backside:http://i2.photobucket.com/albums/y21/animerik/DSC021441.jpg
It is still in heavy WIP just fleshing it out as I go.
and some overall shots
http://i2.photobucket.com/albums/y21/animerik/DSC021501.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC021511.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC021541.jpg
Cheers for looking
//Erik
++UPDATE++
Here comes some pics of the oblit with finished base and some details fixed. There is some blends that could be better and well some of the "soft" edges on the mini and the built is not as good as I would like them to be, however that´s the first of 4 oblits I think the rest will be better.
http://i2.photobucket.com/albums/y21/animerik/DSC021651.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC021661.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC021671.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC021691.jpg
http://i2.photobucket.com/albums/y21/animerik/DSC021711.jpg
Also found one of the first PMs I ever painted and converted.... arms and backpack is lost in the warp but here´s a pic showing how far my tabletop standard has improved.....
http://i2.photobucket.com/albums/y21/animerik/DSC021641.jpg
cheers and thanks for looking
++UPDATE++
Finished (almost) a squad, only need to finish up the the champ and I have 4 squads ready to go
http://i2.photobucket.com/albums/y21/animerik/DSC02175.jpg
Also finished an old plasmagunner (love these special weapon sculpts!)
http://i2.photobucket.com/albums/y21/animerik/DSC02176.jpg
and almost completed the converting on the next squad, still some mouldlines and such to take care of as well as some sculpting
http://i2.photobucket.com/albums/y21/animerik/DSC02178.jpg
Thanks for looking
Cheers //Erik
Some beautifully ugly marines. I'll be tracking them from now on. Your painting and modeling is amazing, some incredible progress! I'm just about to start with some GS, I hope I can be half as good!
Keep 'em coming!
++UPDATE++
Just a small one for this time. I have a exam that I should be workin on and not converting all night.... however I did make these three when studying.
http://i2.photobucket.com/albums/y21/animerik/DSC02186.jpg
I´m really happy with them, the guy to the right looks like his helm is unfinished but is actually pretty crisp irl, just a bad pic. Now only to finish the exam and another four pms :huh:
hope you like em and thanks for looking
