BrotherCaptainPrimus Posted November 17, 2006 Share Posted November 17, 2006 I'm a gamer first, painter very much last. My Ultramarines look k except for the vets, i can NEVER paint white properly. Can anybody give me tips on how to paint white? I can never get a uniform colour. It's always patchy. Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/ Share on other sites More sharing options...
Gnolan Posted November 17, 2006 Share Posted November 17, 2006 The key to white is lots of thin layers. Thinning your paints is key to this. Using either a little glaze medium (preferable) or water, thin your paint. You want it to be around the consistency of cream, much thinner than that and its worthless. Paint a layer on, then make sure you let it dry. Doing it faster can lead to it becoming uneven and splotchy. Dont worry if it looks like crap at first, it will turn out nice, solid, and smooth. Just keep painting thin layer, let it dry, thin layer, etc until your happy with it. Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1134264 Share on other sites More sharing options...
LifeAfterDeath Posted November 17, 2006 Share Posted November 17, 2006 for white or some other light color... is always better off to paint a layer of light grey/bone color before painting the white on top, since those colors are much better to cover the original color of the base then white. I always paint a few thin layer of bone color before white/yellow most of the time. Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1134314 Share on other sites More sharing options...
Cigaro Posted November 17, 2006 Share Posted November 17, 2006 most of gw's white tutorials give you this basic setup basecoat codex grey highlight fortress grey highlight white that gives a decent look, but (especially on marines) if you want that stark white look, you gotta use a different forumla. white looks whiter on top of blue so basecoat fortress grey highlight space wolves grey highlight white and assuming you are painting over a black undercoat, like previously people have said, this will require multiple thins layers keep at it and you'll get it : ) Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1134345 Share on other sites More sharing options...
Alys Dwr Posted November 18, 2006 Share Posted November 18, 2006 i paint my deathwing white and have found the best way is to use and enamel based paint with lots of thinners. Start with black and then all many thin layers of white. The thinners mixes the white into the layer below it so you get many shades of grey leading up to the straight white on the raised edges. I'm working on model at the moment and i'll post a pic of it later. Al edit: http://i92.photobucket.com/albums/l39/bonsai-al/STA71109.jpg Here he is a couple of days ago. i use the photos to look for things i've missed (i'd missed a lot here). Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1134480 Share on other sites More sharing options...
Allerka Posted November 18, 2006 Share Posted November 18, 2006 For the Apothecary I just did, I had primed black, then bestial brown, bleached bone, then I did the white. Came out pretty nice, though the white started acting up on me and wasn't drying evenly, so it's slightly textured now (Though not enough to be noticeable from more than a foot or two away, at least). >.< Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1134481 Share on other sites More sharing options...
AlvinBlah Posted November 19, 2006 Share Posted November 19, 2006 I second Allerka's method of white. That's how I do it as well with thin layers of paint and it works. Bummer about it coming out rough in parts, I've never had it get bad on me, but yeah, that's probably the fastest way to do it. Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1135202 Share on other sites More sharing options...
diddy_lemon1 Posted November 22, 2006 Share Posted November 22, 2006 i normaly spray white models but if its only a part i want to do i have 2 pots of gw skull whitewhich i have thined down Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1136847 Share on other sites More sharing options...
Climpse Posted November 22, 2006 Share Posted November 22, 2006 I started to do Sisters army with GW white, got through half before I found Vallejo white. I will never go back to any other white. Twice as fast to paint white and so smooth. Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1136974 Share on other sites More sharing options...
Allerka Posted November 23, 2006 Share Posted November 23, 2006 Yeah, I've been thinking about completely switching over to Vallejo. I bought a few bottles of prime colors (Black, white, red, green, etc) to test out, and it was just...wow. They just...work so much better. The consistency is a bit different, though, so it takes a little getting used to in terms of how much water/thinner you use and whatnot to achieve the same blend. I'm kicking myself now for not using what I've got left of my Vallejo white on my apothecary. One awesome paint Vallejo sells that I haven't seen anyone else with is the Metallic Medium paint. Basically mix it with any normal color to get that color in a metallic shade. I mixed it with some regal blue, and got a BEAUTIFUL look for some power weapons, that's just WAY easier than layering a highlight to the edge or something. Word of advice, go with darker shades, because the Medium is gonna lighten it quite a bit. Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1137169 Share on other sites More sharing options...
John Thompson Posted November 23, 2006 Share Posted November 23, 2006 BC Primus, do yourself a BIG favour.. I bet you spray your Ultra's a black undercoat. This is fine for the basic armour and everything, but to do an easy white (so for the non-painters) there's only one solution: White undercoat. Try basecoating your white-helmeted guys in 2 colours in the case of plastics. Spray the body and all with black paint and keep the helmet seperate to be sprayed white. Then after painting both, glue them together! To paint white over a white basecoat, just thin down some Fortress Grey to a 1:1 mix with water, take a small brush and paint the thin mix in the recesses. After this, paint a thin white over the rest of the helmet and it's a job well-done! In the case of metal models, however, the heads are usually in one piece with the body and so impossible to spray seperately. In that case, stick to your usual black. To give the to-be-white part a good basecoat over black is to take Fortress Grey and White and mix them about 1 part Fortress to 2-3 parts White. This will give you a very light colour that will cover a black basecoat very well in only about 2 or 3 thin coats! When this is done, you can, if you want to, paint some thin (1:1 with water) Fortress in the recesses and then paint 1-2 thin layers of pure White over the rest of the helmet. The BIGGEST mistake a lot of paople make when painting white is beginning with too dark a base coat, like Codex Grey. Fortress Grey is covered by white a LOT easier and gives a nicer, more even white than Codex Grey. Beter still is to make the base coat even lighter, by starting with a mix of Fortress Grey and white. This last thing is what I always do and to be honest, I count myself as being rather adept at painting mini's to an acceptable level... In my step-by-step Storm Ghost tutorial I covered white at step 11. Here's the (crappy) pic from that step with the basic rundown: http://img.photobucket.com/albums/v320/John_Thompson/Space%20Marines/Step11.jpg 1- 1:1 mix Fortress Grey:Skull White 2- highlight 1:3 mix FG:SW in 2 thin layers 3- highlight pure SW in 2 thin layers 4- shade the deepest recesses (around the pins) with a 1:1 mix FG:water. 5- doesn't matter in this case as it's just giving some colour to the white. Hope it helps... John. Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1137196 Share on other sites More sharing options...
the_unforgiven Posted November 30, 2006 Share Posted November 30, 2006 I am wondering for asons of malice force hwta woukld the best way to paint a bbright white color ??? possibly highlighted Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1141648 Share on other sites More sharing options...
esinhorn Posted November 30, 2006 Share Posted November 30, 2006 I use white primer then a thinned down was of black ink with a drop of elmers glue. Then many thin layers of skull white the consistancey of milk Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1141655 Share on other sites More sharing options...
John Thompson Posted December 1, 2006 Share Posted December 1, 2006 By reading my post in last weeks topic about painting white.. ;) Linkie John Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1141900 Share on other sites More sharing options...
the_unforgiven Posted December 1, 2006 Share Posted December 1, 2006 Elmers glue ???? Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1142166 Share on other sites More sharing options...
the_unforgiven Posted December 1, 2006 Share Posted December 1, 2006 tutorial not to great for dons of malice unless i get good at sparyin exactly half of a side right down to the skull on the chest Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1142168 Share on other sites More sharing options...
esinhorn Posted December 1, 2006 Share Posted December 1, 2006 The elmers glue helps the ink grip into all the cracks evenly. But only use a tiny bit. BTW Elmers glue is a brand of pvc glue(the stuff you use to put flock on a base)white glue Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1142204 Share on other sites More sharing options...
LifeAfterDeath Posted December 1, 2006 Share Posted December 1, 2006 codex grey as base color... then either light grey/bone color... then white at the last... Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1142205 Share on other sites More sharing options...
Daeothar Posted December 1, 2006 Share Posted December 1, 2006 Blended the two white threads together... Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1142274 Share on other sites More sharing options...
the bearded snot Posted December 4, 2006 Share Posted December 4, 2006 For my Teutonian Templars : Undercoat with Tamiya primer ( = light grey ) Spray some skull white from above Use a wash made with Payne grey (oil color) and white spirit Glaze with Titanium white (oil color). No need to be too even when applying color as you'll use a soft brush to smooth the paint. Et voil Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1143396 Share on other sites More sharing options...
isack iraticus Posted April 5, 2007 Share Posted April 5, 2007 as the title says, how do i paint white onto a model, straight from the brush(i dont like using spray paint) any help will be appreciated ;) Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1225850 Share on other sites More sharing options...
PanzerSmurf Posted April 5, 2007 Share Posted April 5, 2007 you dont. Or, you can try, layer over layer over layer over layer, and eventually it will be pearly white. Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1225852 Share on other sites More sharing options...
Commander Sha'son Posted April 5, 2007 Share Posted April 5, 2007 if you have some wierd primer phobia, then you are boned. may i ask why you "dont like using spray paint"? it would better put us all in a frame of reference when we give you advice. Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1225869 Share on other sites More sharing options...
isack iraticus Posted April 5, 2007 Share Posted April 5, 2007 i dont have a phobia of spraypaint, its just that when i try to prime the model, i cant get to all the places of the model. i just find it easier to paint it by hand. Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1225889 Share on other sites More sharing options...
Commander Sha'son Posted April 5, 2007 Share Posted April 5, 2007 Ok. try a spray can nozzle trigger. alternately, try latex gloves to rotate you model. if you absolutely must, try vallejo's paint on primer Link to comment https://bolterandchainsword.com/topic/134415-faq-painting-white/#findComment-1225912 Share on other sites More sharing options...
