Afternoon,
Ever since I bought the new CSM codex I have fumbled with the idea of using rhinos as a mobile artillery line. If I give squads rhino transports with havoc launchers then I could deploy the rhinos on their own side and run them together up one flank to bombard the enemy with mass missile fire. I guess there is not much to this idea.
Khorne marines are the only troops in the CSM codex with the limitation of having no more than 10 members to have a rhino transport. Is this a typo? I was planning on having utilizing large 20 man squads of Word Bearers and having their transports perform the afformentioned rhino wall of missiles.
Kind of a simple topic but do you guys think the rhino tactic would be effective in non-tournament play against your average 'joe' army?
Perhaps the 150 points for 3 light tanks would be better suited to bringing a defiler instead.
*shrugs* Just thinking
https://bolterandchainsword.com/topic/137147-chaos-rhino/
Thanks to the dear Chaos Errata that went live some week or so ago you can now add a rhino to whatever squad you want (granted they could normally take it to begin with) even if they exceed 10 men.
So fire away with your plans, there are fully legal :sweat:
TDA
https://bolterandchainsword.com/topic/137147-chaos-rhino/#findComment-1581314
So fire away with your plans, there are fully legal :woot:
TDA
You are right !!
interesting.. :o I'll have to plot my own schemes.. rhino shield for the bezerkers.. and such
https://bolterandchainsword.com/topic/137147-chaos-rhino/#findComment-1581375
Hey,
Unfortunately, that makes minimum 300pt squads Slogging Plate Bait, and your paper Rhinos priority LRAT targets.
Opponents will set-up antipersonnel firelanes in response, and then where will their Tank Hunter Units look?
That said, I really like HL Rhinos for undersize squads otherwise ineligible for a HW upgrade.
Consider them "Ghetto Razorbacks". Add Daemonic Possession and compare to the SM version -
Point-for-point, Ghetto Sleds are a pretty good deal - in numbers!
Just one or two will have the And They Shall Know No Second Turn rule.
In most situations, a Rhino has too large a profile to benefit from available cover, so they have to *seem* harmless.
IOW, in order to survive long enough to be effective, you need to divert enemy AT Fire with more survivable Units.
Now, say you rush six Rhinos up the middle and pop smoke, then disembark; target priority now becomes problematic -
When the smoke clears, there are suddenly twelve Units there instead of six, and your FA Units are bringing the pain.
Hopefully, your mobile HQ and Elite Units will be waving their banners and chanting "I'll swallow your soul!", too.
Now, where are enemy Tank Hunters going to look? Paper Rhinos seem pretty harmless by comparison. ;- )
Shoot the Big Ones is a natural reaction wherever there is a choice of target.
The trick is in revealing the Big Ones only once there are *many* choices.
A paper 'wall of missiles' visible since Deployment is just bad timing.
Especially if your opponent gets first turn ...
Playa
https://bolterandchainsword.com/topic/137147-chaos-rhino/#findComment-1582619
I must shed a tear of sadness for I have chosen against this tactic for the time being. I just got my CSM battleforce yesterday *thumbs up* but found the havoc launcher a rather sloppy fit and did not fit comfortably onto my rhino considering I cut all the spikes off the racks and glued them on. :huh:
Fortunately this particular rhino is carrying my beserkers to the front so that pesky missile launcher would be kind of goofy. By the gods if I can get my camera batteries to last more than 1.5 seconds I will have pictures! Fear not, the dark adepts are on the case. :)
https://bolterandchainsword.com/topic/137147-chaos-rhino/#findComment-1585255
I think that you can upgrade Predator tanks with Havoc launchers. Perhaps you should consider including them on that vehicle, as the Predator Destructor set up is pretty much dedicated to anti-infantry fire-power?
I've run a few simulations of this set up using the Vassal engine, and they are quite adapt at this role. The only problem is the upcoming changes to vehicle shooting and movement, which severly limits the usability of tanks in any mobile setting.
https://bolterandchainsword.com/topic/137147-chaos-rhino/#findComment-1585309
I agree with Dark Apostle about the legality of the firing line. On an unrelated note, Word Bearers are Undivided, they just wear red armor to confuse everybody :D .
https://bolterandchainsword.com/topic/137147-chaos-rhino/#findComment-1587325
