Brother Captain Aruis Posted June 4, 2008 Share Posted June 4, 2008 As the topic says are they for pressing designs into green stuff or do you glue them to your army? Link to comment https://bolterandchainsword.com/topic/137739-brass-etching-from-forge-world/ Share on other sites More sharing options...
WingsOfTheFalcon Posted June 4, 2008 Share Posted June 4, 2008 I just clipped, bent to shape and glued onto my marines, but you could use then to press shapes into GS as well. Link to comment https://bolterandchainsword.com/topic/137739-brass-etching-from-forge-world/#findComment-1588826 Share on other sites More sharing options...
Arschbombe Posted June 4, 2008 Share Posted June 4, 2008 Brass-etched details are popular after market items in the wider modeling world of tanks, planes and ships. I've never heard of them being used for making molds. They just get glued onto a model to add details that are often too small to be represented well in plastic. Link to comment https://bolterandchainsword.com/topic/137739-brass-etching-from-forge-world/#findComment-1588834 Share on other sites More sharing options...
smelly_squig Posted June 4, 2008 Share Posted June 4, 2008 on the forgeworld website there is examples of what you can do with them http://www.forgeworld.co.uk/ultrabretch.htm http://www.forgeworld.co.uk/bretcheagles.htm http://www.forgeworld.co.uk/inqetch.htm http://www.forgeworld.co.uk/brreds.htm  i bought some of the renagade brass etch bits to use in my chaos army as icons i cut them off the sprue, glue them to some platicard and then cut the plasticard around them creating an easy icon  for my magos i glued a brass etch cog onto his back and stuck it in the middle of the icon i have a picture of it in my photobucket here  for my prince i stuck a chaos icon onto his right shoulder pad and i have a picture of this one too here Link to comment https://bolterandchainsword.com/topic/137739-brass-etching-from-forge-world/#findComment-1588997 Share on other sites More sharing options...
Battle Brother Fischer Posted September 23, 2011 Share Posted September 23, 2011 so you simply glue them on and paint them? What about glueing them on after it's all painted and using that brass color as part of the vehicle scheme? Link to comment https://bolterandchainsword.com/topic/137739-brass-etching-from-forge-world/#findComment-2883828 Share on other sites More sharing options...
templarboy Posted September 25, 2011 Share Posted September 25, 2011 Making a press mould from a brass etched piece would be problematic. The brass is really really thin. The resultant press moulded piece would be too thin to use. The brass these sheets are made of is so thin I have lacerated my hand badly enough for stitches by mishandling it. That said, I wish FW would make a sheet for my Word Bearers. Link to comment https://bolterandchainsword.com/topic/137739-brass-etching-from-forge-world/#findComment-2885068 Share on other sites More sharing options...
Lucien Eilam Posted September 26, 2011 Share Posted September 26, 2011 The brass these sheets are made of is so thin I have lacerated my hand badly enough for stitches by mishandling it. That said, I wish FW would make a sheet for my Word Bearers. Khorne cares not whence the blood flows. Link to comment https://bolterandchainsword.com/topic/137739-brass-etching-from-forge-world/#findComment-2885329 Share on other sites More sharing options...
darth_giles Posted September 26, 2011 Share Posted September 26, 2011 Methinks FW favors Khorne a little much, but that isn't the only place in their Chaos lineup where they've been laying down. They also still don't have generic cult hatch sets and dreads. Link to comment https://bolterandchainsword.com/topic/137739-brass-etching-from-forge-world/#findComment-2885336 Share on other sites More sharing options...
IronKobra Posted September 26, 2011 Share Posted September 26, 2011 I just picked up a sheet of the Blood Angels etched brass because I was feeling saucy at Games Day... Does anyone have any tips/adive/exaples of these things painted? I have seen lots of them just stuck to a model after painting but am curious about how they come out being painted... Gracias! Link to comment https://bolterandchainsword.com/topic/137739-brass-etching-from-forge-world/#findComment-2885483 Share on other sites More sharing options...
Firepower Posted September 26, 2011 Share Posted September 26, 2011 I recently purchased the Black Templar brass etchings and put them to use on my most recent vehicles. Some things, like very fine lettering, can be a real pain to paint, but for the most part they paint just as easy as anything else. The one bit of advice I have is to be very, very careful when you glue them on: superglue will stick those things down tight the instant they touch, so you only get a second or two to adjust the angles before it becomes impossible/unlikely that the piece can be removed and reglued without permanently messing it up. Â Examples of their use can be found on the landraider and rhino in this blog (too lazy to repost just now): http://www.bolterandchainsword.com/index.p...6588&st=100 Link to comment https://bolterandchainsword.com/topic/137739-brass-etching-from-forge-world/#findComment-2885761 Share on other sites More sharing options...
SCC Posted September 28, 2011 Share Posted September 28, 2011 The one bit of advice I have is to be very, very careful when you glue them on: superglue will stick those things down tight the instant they touch, so you only get a second or two to adjust the angles before it becomes impossible/unlikely that the piece can be removed and reglued without permanently messing it up. Do what I do and cheat - use PVA glue to set the brass where you want it (plenty of time to work it around before it sets and easily removed too if necessary) then apply CA/superglue using a needle, pin or similar around the edge of the brass to lock it down permanently, works a treat. As for what painted EB looks like, well, it looks like raised detail basically. If you bend it to the bend to get a nice 'flat' fit it looks like it was always there: Knee & shoulder insignia are brass, as is the small Aquila on the side of the launcher. EB is brilliant for the freehand or GS challenged, I've used Forge World Stuff and some from Secret Miniatures too - they do some great Roman & Arabic numerals that are perfect for squad/company markings, plus they've got some lovely runes/Celtic knotwork that's spot on for Space Wolves... Link to comment https://bolterandchainsword.com/topic/137739-brass-etching-from-forge-world/#findComment-2887560 Share on other sites More sharing options...
darth_giles Posted September 28, 2011 Share Posted September 28, 2011 GW also used Etched Brass in the BA codex, on some of the Land Raiders. Link to comment https://bolterandchainsword.com/topic/137739-brass-etching-from-forge-world/#findComment-2887562 Share on other sites More sharing options...
