Flamers in close combat
Tinus Maximus
To make it clearer:
1 - No unit can fire any weapon into close combat.
2 - a flamer will give you the same benefit as a bolter in CC - in short nothing. You use the models normal attacks with normal bonus's for charging etc
3 - to fire a flamer you need to be within aprx 8"-2" as you can not be within 2" of the enemy, and the flamer template has a range of 8"
4 - Flamers are VERY useful weapons but do take some practice to use corectly - best used on assault units as they can flame away then charge in.
Hope that helps!!
OP, are you talking about 'clipping' the edge of a combat with a flamer, while shooting at a unit that is near it?
If that's the question, then the answer is "maybe".
As far as shooting the weapon of a unit that is engaged in close combat, the answer is definitely no.
On a seperate topic, if you are playing a 3 way free for all, can one person shoot into a combat that doesn't involve his units?
And if so, how do you work it out?
I think you mean within 8"-1" because you can't get within 1", not 2", of any enemy.
Whoops - my bad!!
Still a no - the template can NOT fire into combat at all.
With normal rules - no.
With house rules - difrent story, lots of ways to work it out "fairly" rnaging from split wounds 50/50 to count models in combat, work out difrence in percentage of X vs Y make that a die roll - eg 9 vs 3 = 3 vs 1 = D3 roll = 1/2 = X, 3 = Y - however as this is a house rule its best to work out before a game - for more talk on the subject check out the hosue rules section :)
