My first Drop Pod
BigJon
Welcome to the first (or second) look at the drop pod.
I decided to tackle it this morning so I can throw some paint on it soon.
First off are the door. Not much mold likes which is good, but have some rubber
bands handy to hold them together.
http://farm4.static.flickr.com/3209/2873117698_cf10c69e16_o.jpg
Next is the base, here you do not glue the doors down but glue the
top of the base to the bottom of the base, make sure this fits snug
and not to let glue seep into the door pegs.
http://farm4.static.flickr.com/3213/2872289857_9e2b318f77_o.jpg
Next is inside. This is the rough part. The direction included are a rough
CAD drawing that is very confusing. I installed the first two harness supports
backwards because that's how the directions have it on the left side
of the page. The red circle on the left is the WRONG way, both those
pices will have to be snipped to let the wings on the pod, the red circle on the
right is correct.
Also, the directions only have you installing one set of harness's, but the kit
has enough for both sides and in fact both sides need to be installed.
Don't worry, I'm still working on the mold lines.
http://farm4.static.flickr.com/3114/2873119534_5b90570e69_o.jpg
Next image is for scale, also, three of my doors are having a hard time
staying closed, going to need to engineer a solution.
http://farm4.static.flickr.com/3212/2873119494_8a5892deae_o.jpg
And a top down image so you get an idea of how much room your will need
to Drop Pod assault them in.
Top down view to help with Drop Pod assault spacing and room.
http://farm4.static.flickr.com/3117/2873119512_3a06ee36be_o.jpg
As with all GW kits the next few drop pods will be much easier as I go
along.
BigJon
P.S. Did I mention the CAD instructions are crap?
https://bolterandchainsword.com/topic/146648-my-first-drop-pod/
Cool, nice close up look of the new kit. Have you glued those wings in, or are you going to paint it up unassembled then assembled it afterwards?
three of my doors are having a hard time staying closed, going to need to engineer a solution.
Three words: rare earth magnets.
I finished mine today, and I agree its not easy to put together your first one. On my one, the engine is not quite directly above the centre of the model, so the doors don't quite shut properly. I also had to cut the pipe off the harness frame, the pipe that joins to the wing/fin, as I didn't glue it on properly. It sure is a hard kit to get used to though, but I think it'll be easier after your first one, as then you know how it works, etc.
It looks like a great peice of kit!
prehaps a loose pin to keep the doors closed?
Oh if you don't mind, whats the basic diamiter of the base (with the doors 'up' i.e not landed)? I need to gat some bases to represent a 'pod' (my chapter are all ghostly, so its the point the appear from, with some sort of mysterious lightning representing the storm bolter) thanks...
how much did it cost?
I used some rare earth magnets to help secure the doors, even the ones that stayed closed.
I did not make it neat for clever, just glued them to the tips of the doors and then to the
engine shaft. I will include some pics later as I am currently at work, but it does seem
to work so much better.
BigJon
