Hound Posted September 25, 2008 Share Posted September 25, 2008 The rules say that you have to deploy half your drop pods (round up) in your first turn. What about if I have just one drop pod in my army? May I deploy it during the first turn? Link to comment https://bolterandchainsword.com/topic/147090-question-about-drop-pods/ Share on other sites More sharing options...
Souchan Posted September 25, 2008 Share Posted September 25, 2008 Well what is 1/2 rounded up? (yes you deploy the lone one in the first turn ^^ ) Link to comment https://bolterandchainsword.com/topic/147090-question-about-drop-pods/#findComment-1706083 Share on other sites More sharing options...
nighthawks Posted September 26, 2008 Share Posted September 26, 2008 You are talking about the rules for DROP POD ASSUALT, which is not the same as having some units in drop pods and deep striking them as per usual rules, it's a special rule that you MAY choose to use. technicaly, I don't know if 1 pod constitues a DPA, but it might, and then Souchan has it - 0.5 rounds up to 1. Link to comment https://bolterandchainsword.com/topic/147090-question-about-drop-pods/#findComment-1706701 Share on other sites More sharing options...
Souchan Posted September 26, 2008 Share Posted September 26, 2008 You are talking about the rules for DROP POD ASSUALT, which is not the same as having some units in drop pods and deep striking them as per usual rules, it's a special rule that you MAY choose to use. technicaly, I don't know if 1 pod constitues a DPA, but it might, and then Souchan has it - 0.5 rounds up to 1. Actually droppod assault is required(uses "must" and everything), so if using only one droppod, it WILL be coming in the first turn, no matter how much youd want it later. Only droppods in the new Marine dex have this rule though, DA, BA, BT still have regular reserves droppods. Hope this helps ;) Link to comment https://bolterandchainsword.com/topic/147090-question-about-drop-pods/#findComment-1706855 Share on other sites More sharing options...
SeattleDV8 Posted September 26, 2008 Share Posted September 26, 2008 Sounds like it works the same as DA Deathwind deep strike. Link to comment https://bolterandchainsword.com/topic/147090-question-about-drop-pods/#findComment-1707106 Share on other sites More sharing options...
nighthawks Posted September 26, 2008 Share Posted September 26, 2008 You are talking about the rules for DROP POD ASSUALT, which is not the same as having some units in drop pods and deep striking them as per usual rules, it's a special rule that you MAY choose to use. technicaly, I don't know if 1 pod constitues a DPA, but it might, and then Souchan has it - 0.5 rounds up to 1. Actually droppod assault is required(uses "must" and everything), so if using only one droppod, it WILL be coming in the first turn, no matter how much youd want it later. Only droppods in the new Marine dex have this rule though, DA, BA, BT still have regular reserves droppods. Hope this helps :lol: yeah, missed that. Thanks. I like the mandatory DPA less than how I thought it worked... Link to comment https://bolterandchainsword.com/topic/147090-question-about-drop-pods/#findComment-1707312 Share on other sites More sharing options...
