Lord Drax Posted October 8, 2008 Share Posted October 8, 2008 This is my first attempt at a Blood Raven scheme. Apologies if it is a little dark. C&C welcome. http://img525.imageshack.us/img525/1296/models011wf9.jpg Link to comment https://bolterandchainsword.com/topic/148351-blood-raven-assault-marine/ Share on other sites More sharing options...
ShinyRhino Posted October 8, 2008 Share Posted October 8, 2008 Looks nice. The eyes definitely stand out on the model. Link to comment https://bolterandchainsword.com/topic/148351-blood-raven-assault-marine/#findComment-1721727 Share on other sites More sharing options...
gettothegone Posted October 8, 2008 Share Posted October 8, 2008 Nice deep red. One suggestion. Do the shoulderpads apart from the model. Instead of priming it black *which I assumed happened, if i'm wrong ignore me*. But prime them white first, do a black outline around the edge of the pad to seperate and give you a buffer for painting the black rims, then glaze/paint the shoulder pads with bleach bone till you get a nice smooth bleach bone colour to it. Link to comment https://bolterandchainsword.com/topic/148351-blood-raven-assault-marine/#findComment-1721848 Share on other sites More sharing options...
Patrick O))) Posted October 8, 2008 Share Posted October 8, 2008 I disagree, though in a stylistic sense - I like the mottled look of the bone pads, I just think it looks nice. En masse though, it might well begin to look uneven rather than aesthetically pleasing, so if it's uniformity you want I'd listen to gettothegone. For me though, I just think the eyes could do with a little more attention. Link to comment https://bolterandchainsword.com/topic/148351-blood-raven-assault-marine/#findComment-1721861 Share on other sites More sharing options...
Ompfris Posted October 8, 2008 Share Posted October 8, 2008 the red is good, I always find the marines look better in dark colours, you dont need bright red soldiers do ya! Link to comment https://bolterandchainsword.com/topic/148351-blood-raven-assault-marine/#findComment-1721910 Share on other sites More sharing options...
Chronowraith Posted October 8, 2008 Share Posted October 8, 2008 Instead of priming it black *which I assumed happened, if i'm wrong ignore me*. But prime them white first, do a black outline around the edge of the pad to seperate and give you a buffer for painting the black rims While he may have primed them black, I think the mottled effect comes from a wash/ink rather than just the black bleeding through the bleached bone. Also, I don't think it's necessary to prime the arms/shoulder pads seperately. If the mottling wasn't intentional weathering then he just needs to get a nice solid coat of bone on there, it may take multiple coats but it works just fine. To the OP, it's hard to say a whole lot because of how dark the picture is but I do have a few comments. 1) I'm not real fond of the red. You seemed to have applied it just fine but I personally think it's too dark for Blood Ravens. Even if you disagree I'd say it still needs highlights. 2) The eagle on the chest needs some wash + highlights to make it really stand out. Otherwise it just kind of blends in with the jump pack harness. 3) Nice job on the freehand Link to comment https://bolterandchainsword.com/topic/148351-blood-raven-assault-marine/#findComment-1722444 Share on other sites More sharing options...
Zeller Posted October 8, 2008 Share Posted October 8, 2008 Their shoulderpads are supposed to be a dark parchment color which a black undercoat should help create. Mottled as has been said looks good. Link to comment https://bolterandchainsword.com/topic/148351-blood-raven-assault-marine/#findComment-1722483 Share on other sites More sharing options...
Manserus Posted October 8, 2008 Share Posted October 8, 2008 The model looks great! Love the red... What kind of grass do you use? Link to comment https://bolterandchainsword.com/topic/148351-blood-raven-assault-marine/#findComment-1722552 Share on other sites More sharing options...
Lord Drax Posted October 9, 2008 Author Share Posted October 9, 2008 Thanks for the comments. @Manserus - the basing was done using regular modelling sand and GW scorched grass @Chronowraith - i agree that the eagle needs more work after seeing it in photo form, and also the red looks a little too dark as the lighting on the shot was a bit messed up. i'll be adding some better highlighting as i can see what you mean about it. @Patrick - yeah i think the eyes do need something doing to them @gettothegone - thanks for the tips i'll be using them on the next models in the line. cheers Drax Link to comment https://bolterandchainsword.com/topic/148351-blood-raven-assault-marine/#findComment-1723260 Share on other sites More sharing options...
gettothegone Posted October 9, 2008 Share Posted October 9, 2008 If you want a really quick way to do thin lines, go grab a .5mm micron pen, you wouldn't believe how much this helps out vs trying to freehand it. Link to comment https://bolterandchainsword.com/topic/148351-blood-raven-assault-marine/#findComment-1723442 Share on other sites More sharing options...
Chronowraith Posted October 9, 2008 Share Posted October 9, 2008 @Chronowraith - i agree that the eagle needs more work after seeing it in photo form, and also the red looks a little too dark as the lighting on the shot was a bit messed up. i'll be adding some better highlighting as i can see what you mean about it. @Patrick - yeah i think the eyes do need something doing to them I figured the lighting had a bit to do with the darkness of the red, I just didn't know how much. For the eyes if you want them to really stand out then try painting the front of the eye a little bit lighter and then put an extremely small dab of white in the back corner. There are plenty of examples here and in the hall of honor. Barring that, have a look in the citadel painting guide if you have a store nearby that has one. Or, if you need help I can try and produce some photos that show what I mean. Link to comment https://bolterandchainsword.com/topic/148351-blood-raven-assault-marine/#findComment-1723523 Share on other sites More sharing options...
