Battle-Brother Maracthor Posted October 9, 2008 Share Posted October 9, 2008 After reading the Auxiliary Grenade Launchers entry in the new codex, I am unsure as to whether they can be used with any weapon or only with another firing weapon. "An auxiliary grenade launcher can be fired in addition to another weapon." Does the wording mean if you fire a weapon you can also fire the grenade launcher or does it mean you can fire it even if the weapon you have is a CCW? Link to comment https://bolterandchainsword.com/topic/148484-auxiliary-grenade-launchers-use-with-any-weapon/ Share on other sites More sharing options...
Zeller Posted October 9, 2008 Share Posted October 9, 2008 My understanding from what I've seen is that you can fire the grenade launcher in addition to any other weapons fired by the model. How would you have a grenade launcher and chainsword? It defeats the purpose of being 'auxiliary' then, right? Link to comment https://bolterandchainsword.com/topic/148484-auxiliary-grenade-launchers-use-with-any-weapon/#findComment-1723542 Share on other sites More sharing options...
Eddie Orlock Posted October 9, 2008 Share Posted October 9, 2008 I'm going to go with yes, it can be fired on its own. It says that it can be fired in addition, not that it must be. Link to comment https://bolterandchainsword.com/topic/148484-auxiliary-grenade-launchers-use-with-any-weapon/#findComment-1723544 Share on other sites More sharing options...
Chronowraith Posted October 9, 2008 Share Posted October 9, 2008 I agree with Eddie on this one. The rule states it can fire with another weapon. Since it doesn't say it has to be fired in such a manner one would assume the standard rules apply to it shooting on it's own. @Zeller - the book described the auxillary launcher as both a underslung mount and then as seperate shoulder mounts too. So it's completely possible to have say a chainsword, storm shield, and then a shoulder mounted grenade launcher. Link to comment https://bolterandchainsword.com/topic/148484-auxiliary-grenade-launchers-use-with-any-weapon/#findComment-1723558 Share on other sites More sharing options...
emperorslion Posted October 9, 2008 Share Posted October 9, 2008 Or lightening claws and grenade launcher. Link to comment https://bolterandchainsword.com/topic/148484-auxiliary-grenade-launchers-use-with-any-weapon/#findComment-1723579 Share on other sites More sharing options...
Vodunius Posted October 9, 2008 Share Posted October 9, 2008 The original Terminator Captain mini had a small unobtrusive auxiliary grenade launcher mounted on the outside of his powerfist, ala Abaddons lightning claw mounted Storm Bolter. Addendum, found a pic: http://i143.photobucket.com/albums/r155/khromash/LA1.jpg Link to comment https://bolterandchainsword.com/topic/148484-auxiliary-grenade-launchers-use-with-any-weapon/#findComment-1723590 Share on other sites More sharing options...
Eddie Orlock Posted October 9, 2008 Share Posted October 9, 2008 The original Terminator Captain mini had a small unobtrusive auxiliary grenade launcher mounted on the outside of his powerfist, ala Abaddons lightning claw mounted Storm Bolter.I have this figure, and when I saw this in the codex I was stoked that I could use him again. :sweat: Link to comment https://bolterandchainsword.com/topic/148484-auxiliary-grenade-launchers-use-with-any-weapon/#findComment-1723611 Share on other sites More sharing options...
Brother Richard Posted October 9, 2008 Share Posted October 9, 2008 Anyone got a pic of that termie captain? Link to comment https://bolterandchainsword.com/topic/148484-auxiliary-grenade-launchers-use-with-any-weapon/#findComment-1723638 Share on other sites More sharing options...
Barret Posted October 9, 2008 Share Posted October 9, 2008 The original Terminator Captain mini had a small unobtrusive auxiliary grenade launcher mounted on the outside of his powerfist, ala Abaddons lightning claw mounted Storm Bolter. So that's what that is! I bit ordered that powerfist ages ago, and I've been wondering what that was on the back of the fist. As far as the original question goes, I believe that the Aux GL does indeed fire separately from everything else. For example, I have a Captain with Storm Shield, Relic Blade and AGL. Link to comment https://bolterandchainsword.com/topic/148484-auxiliary-grenade-launchers-use-with-any-weapon/#findComment-1723790 Share on other sites More sharing options...
Brother Ranuk Posted October 12, 2008 Share Posted October 12, 2008 The background also lists the that whilst underslung bolter/combi weapons are the usual place for them, shoulder or even vambrace loaded AGL's are not uncommon, so i'd go with a resounding yes on this one. (wait, the rules and the background DON'T contradict each other, absurd! Must be an oversight) Link to comment https://bolterandchainsword.com/topic/148484-auxiliary-grenade-launchers-use-with-any-weapon/#findComment-1727170 Share on other sites More sharing options...
Playa Posted October 12, 2008 Share Posted October 12, 2008 Hey, Must be an oversight Wait, the way I read ... "An auxiliary grenade launcher can be fired in addition to another weapon." ... is that the "other" weapon must be "fired" also. So, no GLs on CC-only models. IE, you get to fire two ranged weapons instead of one - not one instead of zero. Did I miss something? Playa Link to comment https://bolterandchainsword.com/topic/148484-auxiliary-grenade-launchers-use-with-any-weapon/#findComment-1727380 Share on other sites More sharing options...
Sandolphon Posted October 12, 2008 Share Posted October 12, 2008 I think that's just to clarify it's difference from a combi-weapon. Link to comment https://bolterandchainsword.com/topic/148484-auxiliary-grenade-launchers-use-with-any-weapon/#findComment-1727438 Share on other sites More sharing options...
SeattleDV8 Posted October 12, 2008 Share Posted October 12, 2008 Hey, Must be an oversight Wait, the way I read ... "An auxiliary grenade launcher can be fired in addition to another weapon." ... is that the "other" weapon must be "fired" also. So, no GLs on CC-only models. IE, you get to fire two ranged weapons instead of one - not one instead of zero. Did I miss something? Playa The fact that you can always legally fire one weapon? Link to comment https://bolterandchainsword.com/topic/148484-auxiliary-grenade-launchers-use-with-any-weapon/#findComment-1728507 Share on other sites More sharing options...
Imriel Posted October 14, 2008 Share Posted October 14, 2008 Anyone got a pic of that termie captain? Its not an assembled model, but you can see the parts Here. Link to comment https://bolterandchainsword.com/topic/148484-auxiliary-grenade-launchers-use-with-any-weapon/#findComment-1731130 Share on other sites More sharing options...
