Rules of Combat
King_Pash
It would be the same as if the Dread was "killed" at the higher I. It would get no attacks. the damage takes effect before his attacks.
I'm not sure where you're getting this but its not true. Assuming that the Dread has not suffered any other hits it would have 3, 2+1 for charging, attacks at its base strength of 6.
IIRC there used to be a bonus attack if you took the DCCW arm, but thats not the case anymore. Unless you have TWO CCW arms then it has absolutly no effect on the number of attacks the dread gets, only the strength it fights at (and in the case of seismic hammer the I it fights at, and in the case of chainfist the AP it uses, but you get the picture)
