Redleg Posted October 31, 2008 Share Posted October 31, 2008 Just played my 3rd 40k game and my buddy used Boss Snikrot who has the following special rule... "Snikrot may reroll all failed rules in an assault" I interpret this as the turn Snikrot assaults into close combat, he rerolls any dice that fail to hit. But in subsequent turns of close combat, he does not have the ability to reroll. My buddy thinks an assault is ongoing so long as there are survivors (assuming no fall backs), and Snikrot can continue to reroll failed dice. Can somebody clarify? Thanks. Link to comment https://bolterandchainsword.com/topic/150858-re-rolling-dice-during-assault/ Share on other sites More sharing options...
Mordekiem Posted October 31, 2008 Share Posted October 31, 2008 Your buddy is correct. You are incorrect. If they wanted it your way they would say "On the turn that Snikrot charges..." If you want some rules to compare it to check out the preferred enemy USR and the chaplains ability in the latest SM Codex. Link to comment https://bolterandchainsword.com/topic/150858-re-rolling-dice-during-assault/#findComment-1754020 Share on other sites More sharing options...
Redleg Posted October 31, 2008 Author Share Posted October 31, 2008 Thanks for the quick help. We ruled in his favor during the game. Glad to see it was the right call. Link to comment https://bolterandchainsword.com/topic/150858-re-rolling-dice-during-assault/#findComment-1754027 Share on other sites More sharing options...
Gurth Posted October 31, 2008 Share Posted October 31, 2008 I interpret this as the turn Snikrot assaults into close combat, he rerolls any dice that fail to hit. But in subsequent turns of close combat, he does not have the ability to reroll. As has been mentioned, he can re-roll every turn. The problem is GW's use of the word "assault" where "close combat" or "melee" would have been better — it kind of implies an assault happens on only the turn in which the unit charges another unit, when actually GW uses it to mean any time models in base-to-base contact fight each other, regardless of whether a charge was involved. Link to comment https://bolterandchainsword.com/topic/150858-re-rolling-dice-during-assault/#findComment-1754425 Share on other sites More sharing options...
nighthawks Posted November 1, 2008 Share Posted November 1, 2008 While I agree with everyone about the reading of the rule, I wanted to add the following: Assault is a phase. as odd as the word feels in use this way "charge" is typically used to indicate the instigation of an assault, while "assault" is the round, for however many turns it lasts. Link to comment https://bolterandchainsword.com/topic/150858-re-rolling-dice-during-assault/#findComment-1755520 Share on other sites More sharing options...
