krispy Posted November 11, 2008 Share Posted November 11, 2008 Okay well im more of a lurker here than anything, played 40k back when in rogue trader times and just recently got back into it all. i saw that the new master of the forge could have a conversion beamer and i had an old one lying around, so i got a techmarine from ebay and set about it ;) - it says in the codex the servo arms are not there when a conversion beamer is used so i have tried to make it look like the "arms" have been used to hold the beamer. I have also used magnets and done it so that the standard big servo harness can be swapped with the conversion beamer harness. the pictures are below and i would like to know what anyone here thinks about how it is just now as well as how it could be better developed - im thinking i need to bulk up the backpack a bit more - maybe make it look like the heavy weapons backpacks or maybe more like the standard big servo harness backpack. thanks for any suggestions / comments /krispy Link to comment https://bolterandchainsword.com/topic/151889-master-of-the-forge-with-conversion-beamer/ Share on other sites More sharing options...
Lord Castellan Mik Posted November 11, 2008 Share Posted November 11, 2008 Looks good... and a nice idea But... Conversion Beamer OR Harness and Bolter Can't have CB and Bolter Link to comment https://bolterandchainsword.com/topic/151889-master-of-the-forge-with-conversion-beamer/#findComment-1767972 Share on other sites More sharing options...
krispy Posted November 11, 2008 Author Share Posted November 11, 2008 Looks good... and a nice idea But... Conversion Beamer OR Harness and Bolter Can't have CB and Bolter oops! - well in that case i guess i need to put another magnet set there so i can swap the bolter arm for one holding a control pad - that ought to help ;) thanks for pointing that out /krispy Link to comment https://bolterandchainsword.com/topic/151889-master-of-the-forge-with-conversion-beamer/#findComment-1767978 Share on other sites More sharing options...
