Chaos_Minds Posted December 10, 2008 Share Posted December 10, 2008 Hello all, I am currently working on a true scale pre-heresy death guard army. I plan on using this army in regular games at my local hobby store and I have something I need to clarify. Since terminator legs won't fit on 25mm bases, I have to use the 40mm ones that come with the box. Is it legal to have an entire army like this using normal marine rules? I.E. can I have a tactical squad with 40mm bases. I would like to clear this up before I finish the army and discover its illegal to play. Link to comment https://bolterandchainsword.com/topic/154529-true-scale-marines-and-40mm-bases/ Share on other sites More sharing options...
nighthawks Posted December 10, 2008 Share Posted December 10, 2008 if they count as regular space marines, then it's a 25 mm base or opponents' permission (usually ok in friendly games). that's a lot of TDA legs - expensive army... Link to comment https://bolterandchainsword.com/topic/154529-true-scale-marines-and-40mm-bases/#findComment-1802391 Share on other sites More sharing options...
Chaos_Minds Posted December 10, 2008 Author Share Posted December 10, 2008 Haha, yeah. I know. Thanks for the answer. Link to comment https://bolterandchainsword.com/topic/154529-true-scale-marines-and-40mm-bases/#findComment-1803328 Share on other sites More sharing options...
AnthonyVG Posted December 23, 2008 Share Posted December 23, 2008 Could someone please clarify this, i thought it was legal to mount any model on a base larger than what is provided, but you aren't allowed to mount it on something smaller. pg 3 says "as mounting your models on different bases might affect the way they interact...make sure before the game that your opponent does not mind this" I only ask because it doesn't say anything about legality, but I've also never been to a pro-tourney. Link to comment https://bolterandchainsword.com/topic/154529-true-scale-marines-and-40mm-bases/#findComment-1818034 Share on other sites More sharing options...
Mordekiem Posted December 23, 2008 Share Posted December 23, 2008 Could someone please clarify this, i thought it was legal to mount any model on a base larger than what is provided, but you aren't allowed to mount it on something smaller. pg 3 says "as mounting your models on different bases might affect the way they interact...make sure before the game that your opponent does not mind this" I only ask because it doesn't say anything about legality, but I've also never been to a pro-tourney. Your statement was true in 4th edition. However, 5th edition requires your opponents permission to use any non-standard base. most people don't have a problem with it unless they think you are trying to get an advantage. Link to comment https://bolterandchainsword.com/topic/154529-true-scale-marines-and-40mm-bases/#findComment-1818086 Share on other sites More sharing options...
Mal Posted December 23, 2008 Share Posted December 23, 2008 Lets face it, bigger models are easier to draw LOS to, meaning its harder to deny LOS... not much of an advantage, plus the fact that they can fit less models in combat against those characters... once again not much of a bonus.... With those Benes in mins, I would not have a problem with someone making use of larger bases, that being said, I would point the aove out to them... Link to comment https://bolterandchainsword.com/topic/154529-true-scale-marines-and-40mm-bases/#findComment-1818113 Share on other sites More sharing options...
SeattleDV8 Posted December 24, 2008 Share Posted December 24, 2008 Also fewer units under a template. myself its not a big deal. The so called true scale guys make me laugh. Its the silliest idea since the Rainbow Warriors. Link to comment https://bolterandchainsword.com/topic/154529-true-scale-marines-and-40mm-bases/#findComment-1818726 Share on other sites More sharing options...
Hexx Posted December 24, 2008 Share Posted December 24, 2008 Larger (well taller) models actually make it a bit easier to shoot over intervening regular size units, (thereby ignoring intervening cover saves) while keeping part of their own body covered. (There's some excellent drawings in http://www.bolterandchainsword.com/index.p...howtopic=155485 by Steelmage99 ) Of course I don't know how often it will come up, but there are enough game advantages to having slightly taller models on bigger bases that I wouldn't count on being able to play tournies or non friendly pick up games. Link to comment https://bolterandchainsword.com/topic/154529-true-scale-marines-and-40mm-bases/#findComment-1818737 Share on other sites More sharing options...
nurglez Posted December 27, 2008 Share Posted December 27, 2008 I must ask, while not about true scale marines, this is a question about bases, so i thought i'd chuck it in here. I got some old termies, metal ones, that come on the same bases as regular marines. these are the bases they were supplied with, do i have to rebase these to use them? Link to comment https://bolterandchainsword.com/topic/154529-true-scale-marines-and-40mm-bases/#findComment-1820958 Share on other sites More sharing options...
SeattleDV8 Posted December 27, 2008 Share Posted December 27, 2008 No you do not. I have several of these and did the glue the 25mm base to a poker chip (Almost a prefect 40mm) trick. it gives me the same base for all my termies and makes the metal ones just a touch taller so they match the plastic ones . Link to comment https://bolterandchainsword.com/topic/154529-true-scale-marines-and-40mm-bases/#findComment-1820972 Share on other sites More sharing options...
Steelmage99 Posted December 27, 2008 Share Posted December 27, 2008 Agree with SeattleDV8. I too have several (40+) of the old metal Deathwing Terminators which came supplied with the 25mm base. At some point I'll properbly rebase them, but it will be out of a modeling desire as they "are on the base they were supplied with". Link to comment https://bolterandchainsword.com/topic/154529-true-scale-marines-and-40mm-bases/#findComment-1821115 Share on other sites More sharing options...
