Runepriest2007 Posted January 22, 2009 Share Posted January 22, 2009 Oh, and what's a CML? I'm guessing: Chapter Master Launcher or something...Yes, I did notice that eve really small neodymium magnets can hold other magnets even through quite a bit of plastic. I suppose larger ones go through more plastic. CML = Cyclone Missile Launcher Runepriest Link to comment https://bolterandchainsword.com/topic/154822-modelling-using-magnets/page/3/#findComment-1853300 Share on other sites More sharing options...
Shortsonfire79 Posted January 22, 2009 Author Share Posted January 22, 2009 I'm doing a vid on sculpting a shoulder pad, which I've only done once. It turned out okay. The shoulder pad I'm doing, I've never seen before, so we'll see how it goes. Link to comment https://bolterandchainsword.com/topic/154822-modelling-using-magnets/page/3/#findComment-1853413 Share on other sites More sharing options...
Malkuth Posted January 22, 2009 Share Posted January 22, 2009 I just found out that 1mm x 3mm magnets stick together just fine through 1mm (or a bit less in this case) of solid plastic, which means I managed to magnetize a CML to a terminators back without having to have bare magnet visible when another weapon option is used. I might take some pictures when I make the next one if anyone's interested. Yes, I'd have loved to do this, but at the time, I didn't currently have small enough magnets, so I couldn't place any in the CML, so I didn't do it =-P If you'd like to post, go right ahead! Neither did I, actually, so I modified the connection a bit: http://i378.photobucket.com/albums/oo229/Malkuth/cml003.jpg A more proficient modeller could certainly make it look a lot better, but even this one will look ok after some cleaning up, I think. You can't really see the connetion when it's attached to the terminator. The downside of this is, that you can't use the specific torso frontside that's supposed to go with CML, but I didn't think it was much of a problem. I did remove the bit that's supposed to connect with wires coming from the torso, however. Link to comment https://bolterandchainsword.com/topic/154822-modelling-using-magnets/page/3/#findComment-1854020 Share on other sites More sharing options...
Shortsonfire79 Posted January 22, 2009 Author Share Posted January 22, 2009 Mmm I didn't wan to do it that way, because I didn't like the way that it looked in the middle, I wanted to place it IN the CML, but I guess that works. Link to comment https://bolterandchainsword.com/topic/154822-modelling-using-magnets/page/3/#findComment-1854198 Share on other sites More sharing options...
Malkuth Posted January 22, 2009 Share Posted January 22, 2009 Yeah, I know, definitely not the best looking way to do it, but works for me. Do you mean "in the CML" as in hiding both/all magnets inside the model, or just using magnets with about half the diameter compared to those I used and putting one in each "slot"? Link to comment https://bolterandchainsword.com/topic/154822-modelling-using-magnets/page/3/#findComment-1854297 Share on other sites More sharing options...
Shortsonfire79 Posted January 22, 2009 Author Share Posted January 22, 2009 I mean placing them into the CML when I assemble it, so its never visible, and a couple in the body, so they're never visible. Its magic! Link to comment https://bolterandchainsword.com/topic/154822-modelling-using-magnets/page/3/#findComment-1854350 Share on other sites More sharing options...
MechSpacewulf Posted January 29, 2009 Share Posted January 29, 2009 A little trick I do for the polarity is pair up all the magnets you will be using and marking the outside magnets with a black sharpie. This way if they get dropped or stick to another bunch all you need to do is black gets buried and silver should be showing. Has been working wonders. Hope this helped. Link to comment https://bolterandchainsword.com/topic/154822-modelling-using-magnets/page/3/#findComment-1863010 Share on other sites More sharing options...
Shortsonfire79 Posted January 30, 2009 Author Share Posted January 30, 2009 I used to do that, but the sharpie just rubbed off after time. (while still not in use) its easier to just get a model thats already been magnetized, and set polarity directions before you start working. Link to comment https://bolterandchainsword.com/topic/154822-modelling-using-magnets/page/3/#findComment-1863698 Share on other sites More sharing options...
Mr.Mumbles Posted February 2, 2009 Share Posted February 2, 2009 I have to say, this is going to help me out tremendously. ;) Thank you. Link to comment https://bolterandchainsword.com/topic/154822-modelling-using-magnets/page/3/#findComment-1867060 Share on other sites More sharing options...
Shortsonfire79 Posted February 3, 2009 Author Share Posted February 3, 2009 Cool, you're welcome! Link to comment https://bolterandchainsword.com/topic/154822-modelling-using-magnets/page/3/#findComment-1868130 Share on other sites More sharing options...
