D-USA Posted January 12, 2009 Share Posted January 12, 2009 Quick question: I have been running shrike with a unit of 5 assault marines (I don't like to run him with termies and then splitting them, just think that Shrike with jump-pack assault marines just fits the fluff better). I was wondering how the unit would act if I had 10 assault marines with Shrike. Could I infiltrate Shrike with 5 marines and infiltrate the other assault marines somewhere else? The way the rules read it seems like it should work. The rules read like the unit would deploy together, but can be split into combat teams at the time of deployment and can be deployed in two different parts of the board. It seems like it should be no different than splitting up a 10 man troop of scouts into combat squads and deploying them in two locations. Shrike gives the whole UNIT infiltrate, and the UNIT then splits into combat squads. But on the other hand I am pretty torn myself on how to interpret this rule. Thanks for any help. Link to comment https://bolterandchainsword.com/topic/157270-shrike-and-combat-squads/ Share on other sites More sharing options...
ThatWhichIsWhole Posted January 12, 2009 Share Posted January 12, 2009 A unit is a unit... The 2 combat squads count as 2 units. Only the unit with Shrike can infiltrate with his special ability. Scouts can do it because all scouts have the ability to infiltrate, not just the ones with the sergeant or something goofy like that. Link to comment https://bolterandchainsword.com/topic/157270-shrike-and-combat-squads/#findComment-1839534 Share on other sites More sharing options...
Cypher 102 Posted January 12, 2009 Share Posted January 12, 2009 Squads can only be split into combat squads when deploying or disembarking from a drop pod. They cannot split when moving on from reserves. Link to comment https://bolterandchainsword.com/topic/157270-shrike-and-combat-squads/#findComment-1840075 Share on other sites More sharing options...
King_Pash Posted January 14, 2009 Share Posted January 14, 2009 Infiltration isn't reserves.. Link to comment https://bolterandchainsword.com/topic/157270-shrike-and-combat-squads/#findComment-1842258 Share on other sites More sharing options...
Guest DING0 Posted January 14, 2009 Share Posted January 14, 2009 I'm not sure how reserves pertain to the discussion. Only the unit with Shrike in it may infiltrate. Link to comment https://bolterandchainsword.com/topic/157270-shrike-and-combat-squads/#findComment-1842317 Share on other sites More sharing options...
King_Pash Posted January 14, 2009 Share Posted January 14, 2009 I'm not sure how reserves pertain to the discussion. Only the unit with Shrike in it may infiltrate. I.e. only the single combat squad? Link to comment https://bolterandchainsword.com/topic/157270-shrike-and-combat-squads/#findComment-1842373 Share on other sites More sharing options...
Playa Posted January 14, 2009 Share Posted January 14, 2009 Hey, Only the unit with Shrike in it may infiltrate.I.e. only the single combat squad? You must choose whether to Infiltrate a full, or a Combat squad with Shrike at Deployment. Joining to confer Infiltrate upon the Unit, then splitting it into Infiltrating Squads won't work under Shrike's rules - RB p48: ICs - like Shrike - may join a Unit, but must Declare this *before* Deployment. Codex p51: Units split into Combat Squads are Declared *at* Deployment. Codex p92: Shrike's "squad" - not Unit - may Infiltrate. Playa Link to comment https://bolterandchainsword.com/topic/157270-shrike-and-combat-squads/#findComment-1842563 Share on other sites More sharing options...
D-USA Posted January 15, 2009 Author Share Posted January 15, 2009 Hey, Only the unit with Shrike in it may infiltrate.I.e. only the single combat squad? You must choose whether to Infiltrate a full, or a Combat squad with Shrike at Deployment. Joining to confer Infiltrate upon the Unit, then splitting it into Infiltrating Squads won't work under Shrike's rules - RB p48: ICs - like Shrike - may join a Unit, but must Declare this *before* Deployment. Codex p51: Units split into Combat Squads are Declared *at* Deployment. Codex p92: Shrike's "squad" - not Unit - may Infiltrate. Playa That's about what I was thinking. We talked about this not long ago at the store, but I was not completely sure. I was leaning both ways and could not decide how exactly to interpret the rules. Thanks to all who answered Link to comment https://bolterandchainsword.com/topic/157270-shrike-and-combat-squads/#findComment-1843896 Share on other sites More sharing options...
Gentlemanloser Posted January 16, 2009 Share Posted January 16, 2009 Wouldn't it work like this; Before you delpoy, you annouce that Shrike as joined this 10 man Squad, and they are going to deploy with infiltrate. You deploy the rest of your force, as does your opponent. You delpoy your infiltrating squad, which as you place it on the table, decides to split into two combat squads. That satisfies all the conditions, doesn't it? As you can't split it into two Combat Squads before you deploy, and being an infiltrating unit it deploys after both armies normal deployments. Link to comment https://bolterandchainsword.com/topic/157270-shrike-and-combat-squads/#findComment-1845622 Share on other sites More sharing options...
Oldenhaller Posted January 16, 2009 Share Posted January 16, 2009 An independent character may begin the game already with a unit by being deployed in coherancy with them suggests that the unit is deployed and then the character with it, however; for instance if an independent character without infiltrate joins a unit of infiltrators during deployment, the unit cannot infiltrate. would suggest that they have to be assigned before hand otherwise they wouldn't be deployed together. Shrike (and models in his squad) benifit from the Infiltrate special rule The squad he is attatched to when he is deployed therefore is conveyed the special ability as; The deciscion to split into combat squads, as well as which model goes in each squad, must be made when the unit is deployed...If you decide to split a unit into combat squads then each combat squad is treated as a separate unit from that point means that they are separate squads from the moment they hit the table but are deployed at the same time. As they have to be deployed at the same time they both therefore must have infiltrate. Poorly worded with lots of contradictions, but that's my take on it. ~O edited for spelling Link to comment https://bolterandchainsword.com/topic/157270-shrike-and-combat-squads/#findComment-1845747 Share on other sites More sharing options...
Steelmage99 Posted January 16, 2009 Share Posted January 16, 2009 Wasn't there a wording somewhere that stated something along the lines of; "Units using the Reserve rule cannot split into Combat Squads". I seem to remember reading that somewhere. Could be wrong though. :D Link to comment https://bolterandchainsword.com/topic/157270-shrike-and-combat-squads/#findComment-1846431 Share on other sites More sharing options...
Reglor Posted January 17, 2009 Share Posted January 17, 2009 Wasn't there a wording somewhere that stated something along the lines of; "Units using the Reserve rule cannot split into Combat Squads". I seem to remember reading that somewhere. Could be wrong though. :) BA and DA have this rule. However, it is irrelevent seeing as infiltrating dosn't use reserves. Link to comment https://bolterandchainsword.com/topic/157270-shrike-and-combat-squads/#findComment-1846457 Share on other sites More sharing options...
Steelmage99 Posted January 17, 2009 Share Posted January 17, 2009 True. Link to comment https://bolterandchainsword.com/topic/157270-shrike-and-combat-squads/#findComment-1846780 Share on other sites More sharing options...
wisdom like silence Posted January 19, 2009 Share Posted January 19, 2009 ICs are only considered part of a unit if they are within 2" of a model in that unit. Thus, you have to deploy Shrike separately from the squad upon which you wish to confer Infiltrate, and thus cannot do so because you deploy infiltrators after regular deployment. ICs can only deploy as part of a unit if both units are in reserves and are specified as being together. Link to comment https://bolterandchainsword.com/topic/157270-shrike-and-combat-squads/#findComment-1849399 Share on other sites More sharing options...
Oldenhaller Posted January 19, 2009 Share Posted January 19, 2009 ICs can only deploy as part of a unit if both units are in reserves and are specified as being together. Where's this one printed? Shrike separately from the squad upon which you wish to confer Infiltrate, and thus cannot do so because you deploy infiltrators after regular deployment. Then what is the point of his special rule? Please think through your answer and re-submit :rolleyes: ~O Link to comment https://bolterandchainsword.com/topic/157270-shrike-and-combat-squads/#findComment-1849418 Share on other sites More sharing options...
