Eagle's Eternal
War Angel
Good news! ive finished the marines base's and they are now fully opperational!!!
pics of base's
http://i301.photobucket.com/albums/nn74/Lastdogdead/082.jpg
http://i301.photobucket.com/albums/nn74/Lastdogdead/083.jpg
http://i301.photobucket.com/albums/nn74/Lastdogdead/084.jpg
http://i301.photobucket.com/albums/nn74/Lastdogdead/085.jpg
all four together
http://i301.photobucket.com/albums/nn74/Lastdogdead/086.jpg
Staff Sergeant Daceus, First squad leader
no real reason for the name, beside's the fact that he has a name plate on his left leg, so i painted that on it... SGT Daceus was one of my drill instructors, and the name just came to mind.
http://i301.photobucket.com/albums/nn74/Lastdogdead/087.jpg
http://i301.photobucket.com/albums/nn74/Lastdogdead/091.jpg
couldnt think of any thing for the robe, so i just gave it the red trim, still debateing on if i can put somthing in it
this is the first marine, finaly has his shoulder pads and back pack on... and has a less basic base...still kinda plane in comparision, and it dosnt match the tilled floor of the others (then again, nether does the fire one.. :yes:
http://i301.photobucket.com/albums/nn74/Lastdogdead/090.jpg
Heres the Sergeant of second squad... not quite sure of his name...
http://i301.photobucket.com/albums/nn74/Lastdogdead/092.jpg
"Contact! direct front!"
http://i301.photobucket.com/albums/nn74/Lastdogdead/093.jpg
dosnt that just look like its popping out at you???
i hope the base looks like i imagin it, its supposed to be the side walk, next to the road... the road looked a bit flat so i used some inks to make an oil stain..
http://i301.photobucket.com/albums/nn74/Lastdogdead/097.jpg
http://i301.photobucket.com/albums/nn74/Lastdogdead/098.jpg
that first one (prev post) his head wasnt glued in, i was trying to find out how to get his head to fit in there... had to hack at the neck and the inside of the chest a bit to get it in ... and now i noticed its not facing the way i left it...eh, still good i suppose....
yes yes, i just noticed the skull on the glove lol, thanks for reminding me :wallbash:
C&C
and ill post these guys in the hall of fame once ive got a full squad for each.
(PS, is there any thing i should do to protect these guys? some of my older guys laying around got a lot of dust on them....)
I like how the PF sarge looks like he's gonna draw his bolt pistol.
thanks, took alot of work. i had to get the PF from the older CC vets from 4th eddition, ill see if i can find the box laying around. but having it stick out like that on a non metal base makes it really lop sided, i added a nickle to the base, so i hope that does the trick.
im going to do a vote on this... i wanted to build somthing of my AoBR box... spicificly the termmies cause i wanted some First company colors on the table... (more white) but i also would like to put a dread down...
vote... which do i do next?
  • 1 month later...
I vote for a dread, but make it extra awesome.
and so it began!
ive been working preaty hard on this for about a month i wanna say... Its the AOBR dread... i hacked at it and molded it so it will look a bit more like the normal dread's. (cut the body away from the legs so i could replace the swashplate...)
http://i301.photobucket.com/albums/nn74/Lastdogdead/071-1.jpg
http://i301.photobucket.com/albums/nn74/Lastdogdead/072-1.jpg
arms are magnitized for swapouts (not sure how well a multimelta will work for a dread...but well see...)
i cut the right leg (seen on the left) and reposistioned it along the cog so that it would be slightly angled to alow it to look like it is steping on the tank treds... currently the body is not glued to the legs, and there is a serial code on the left side of his front armor 032 (didnt take a picture of this)
i want to think of some other things to make it look more imposeing before i begin the painting its going to be a standard dread, however...because of the arms being magnitized... i suppose i could change it to an ironclad...oppinions?
C&C as always
finished painting the dread, (also added some more things to it i guess)
http://i301.photobucket.com/albums/nn74/Lastdogdead/001-1.jpg
http://i301.photobucket.com/albums/nn74/Lastdogdead/002-1.jpg
http://i301.photobucket.com/albums/nn74/Lastdogdead/003-1.jpg
http://i301.photobucket.com/albums/nn74/Lastdogdead/004.jpg
also, ive changed the name of this thread because ive decided upon a new chapter name...
they shall be the Eagle's Enduring
  • 1 month later...
