juckto Posted February 1, 2009 Share Posted February 1, 2009 Me and my friend noticed this when he fired one of the lascannons of his LR at me. The lascannon was half blocked by terrain but I didn't get a cover save. Why? Continue reading: Rule: Vehicle firing multiple weapons. For Line of Sight each weapon mount is treated as if it were a seperate model firing in a unit. Rule: Units partially in cover. If the majority of the firing models can see the majority of the target models clearly, then they don't get a cover save. Rule: LoS to obscured vehicles: Do not count models which cannot hurt the vehicle Conclusion: By firing the TL heavy bolters and storm bolter at my Pred, the majority of his weapons had clear line of sight, and I was denied a cover save. +Edit: Updated with SeattleDV8's find. Link to comment https://bolterandchainsword.com/topic/159207-denying-the-enemy-a-cover-save/ Share on other sites More sharing options...
Reclusiarch Darius Posted February 1, 2009 Share Posted February 1, 2009 I'd say he's misinterpreting the rules to gain an unfair advantage. If you're hull down, you're hull down. It doesn't matter about the 'majority of his weapons'; if you do a True LOS check from the muzzle of the vehicle weapon (in this case a twin-las sponson) and 50% or more of the vehicle can't be seen, you get a 4+ cover save. Link to comment https://bolterandchainsword.com/topic/159207-denying-the-enemy-a-cover-save/#findComment-1866014 Share on other sites More sharing options...
SeattleDV8 Posted February 1, 2009 Share Posted February 1, 2009 Actually he did it correctly,Very unsporting but correct. Link to comment https://bolterandchainsword.com/topic/159207-denying-the-enemy-a-cover-save/#findComment-1866036 Share on other sites More sharing options...
eyescrossed Posted February 1, 2009 Share Posted February 1, 2009 No, it's not the majority of the weapons, it's each individual weapon when it comes to cover saves. Link to comment https://bolterandchainsword.com/topic/159207-denying-the-enemy-a-cover-save/#findComment-1866038 Share on other sites More sharing options...
SeattleDV8 Posted February 1, 2009 Share Posted February 1, 2009 BRB pg. 22 "If the majority of the firers have a clear shot to the majority of the models in the target unit,the unit receives no save." Since all the weapons on a vehicle is one unit....sadly it is RAW. Not the playing style that makes someone want to play you again,but.... OOPS hold it, upon rereading the rules for vehicles BRB pg 62 "(Do not count weapons that cannot hurt the vehicle) " phewww GOOD. it isn't ok then edit changed page # Link to comment https://bolterandchainsword.com/topic/159207-denying-the-enemy-a-cover-save/#findComment-1866049 Share on other sites More sharing options...
Souchan Posted February 1, 2009 Share Posted February 1, 2009 Just adding that it's p62, p92 is about secrecy and missions^^ Link to comment https://bolterandchainsword.com/topic/159207-denying-the-enemy-a-cover-save/#findComment-1866108 Share on other sites More sharing options...
rat of vengence Posted February 1, 2009 Share Posted February 1, 2009 BRB pg. 22 "If the majority of the firers have a clear shot to the majority of the models in the target unit,the unit receives no save."Since all the weapons on a vehicle is one unit....sadly it is RAW. Not the playing style that makes someone want to play you again,but.... OOPS hold it, upon rereading the rules for vehicles BRB pg 92 "(Do not count weapons that cannot hurt the vehicle) " phewww GOOD. it isn't ok then Good find. That answers that one then. :P RoV Link to comment https://bolterandchainsword.com/topic/159207-denying-the-enemy-a-cover-save/#findComment-1866123 Share on other sites More sharing options...
Morticon Posted February 4, 2009 Share Posted February 4, 2009 Rule still stands vs. troopers...which is quite interesting. Link to comment https://bolterandchainsword.com/topic/159207-denying-the-enemy-a-cover-save/#findComment-1869468 Share on other sites More sharing options...
Shiodome Posted February 6, 2009 Share Posted February 6, 2009 can't think of any instance where that'd apply though (a vehicles weapons being unable to wound a multi-model infantry unit) afaik the lowest strength of any vehicle weapon is 4... and i don't know of any multi-model units with toughness 8. Link to comment https://bolterandchainsword.com/topic/159207-denying-the-enemy-a-cover-save/#findComment-1871953 Share on other sites More sharing options...
eyescrossed Posted February 6, 2009 Share Posted February 6, 2009 can't think of any instance where that'd apply though (a vehicles weapons being unable to wound a multi-model infantry unit) afaik the lowest strength of any vehicle weapon is 4... and i don't know of any multi-model units with toughness 8. Actually, the weakest weapon is the one on the lead ravager in that DE formation, which is Strength 1. But if we're talking normal games, there's the lasguns on the chimera. Link to comment https://bolterandchainsword.com/topic/159207-denying-the-enemy-a-cover-save/#findComment-1871997 Share on other sites More sharing options...
Shiodome Posted February 8, 2009 Share Posted February 8, 2009 which still doesn't matter unless there's multiple model units with majority toughness 7. Link to comment https://bolterandchainsword.com/topic/159207-denying-the-enemy-a-cover-save/#findComment-1874688 Share on other sites More sharing options...
juckto Posted February 8, 2009 Author Share Posted February 8, 2009 Ah, good find. Cheers. Link to comment https://bolterandchainsword.com/topic/159207-denying-the-enemy-a-cover-save/#findComment-1874774 Share on other sites More sharing options...
eyescrossed Posted February 9, 2009 Share Posted February 9, 2009 which still doesn't matter unless there's multiple model units with majority toughness 7. With the strength 1 one, you could fire it at wraithguard or plague marines. Link to comment https://bolterandchainsword.com/topic/159207-denying-the-enemy-a-cover-save/#findComment-1875320 Share on other sites More sharing options...
