Imperial Palace?
Custodian Athiair
i have read up to the Legio Mortis crossing the border in Mechanicum (no spoliers please)
but it mentioned very near the begginning that the Imperial Palace was built on the tallest mountains in the world which are the Himalers arn't they
so why does all other sources does it say that the Imperial Palace was built on Europe.
just that so please explain thank you
Athiair :D
https://bolterandchainsword.com/topic/160767-imperial-palace/
Think about this rationally. Britain is located in the north, is it not? Ok, 40,000 years of non-stop Tectonic plate shifting causes mountains possibly bigger than the Himalayas are raised. Or, Maybe Europa was moved, you never really know. I know the Cloning Facilities on Terra where the Primarchs were born are under the Himalayas. No idea why. But as it says somewhere (pardon the vagueness) 'The Great Wall of China can be seen from space, the Imperial Palace, home of the Almighty Emperor, can be seen from Mars.' maybe it refers to the palace being a mountain or like a mountain range. I can't imagine GW being setup in the UK then deciding 'I know! Lets put the Imperial Palace next to a squalor country half way across the world!' Sorry, I just dont see it. :D
the primarchs were made on a lunar facility you know, not under the Himalayas. the Imperial Palace is indeed in the Himalayas.
40k years won't change the landscape much since that would take millions of years. most of the change in geography is from undersea volcanoes and global warming. the Himalayas won't be in Europe by the year 40k.
It's in Europe, because GW is a European company. Sorry, was a European company. It's stupid, simple, but it's probably why they put it there.
Why you prefer they put it on America? ;)
And BTW, on that logic, they would put it on Britain, not on mainland Europe!
So, it was built from the Himalayans, which would have been massive, since all the proper seas dried up, so it's like an EVEN BIGGER MOUNTAIN.
Conor The Great Posted Today, 01:30 AM
wasnt the earth raveged by a succession of Nuke wars?Dont you think 40000 years of constant war would change a planet?
Yes - we know for sure that the oceans have boiled away. If the Palace is located in Britain (I wish someone would check the rulebook and end this debate), they are certainly not "The British Isles" any more
Emperor origin is Turkey, Anatolia. It is Europe.
Turkey is not part of Europe. More revisionist Islamic history.
Isnt Turkey's location in the middle of Asia and Europe? I know it's called a Eurasian country. Nothing revisionist with it since it does have parts in Europe and definitely not Islamic about it.
It is both. The Western half of Turkey, particularly the area on the far side of the Bosphorus Straits, on which side Istanbul is located is definitely in Europe. The Eastern half is definitely Middle East/Asia.
The two geographical areas are not mutually exclusive.
i can't check my rulebook at the moment it is a 3 hour drive away
but at the moment it seems that it spreads from the far East to Britain
that is a huge expanse of space i dought that it covers that much
becuase then no one could live anywhere but the Imperial Palace
thanks
Athiair :P
Yeah..I know, hmmm..I used the "Attack on Terra" piece of fluff...no idea if this is the right title, I only own a German copy :)
Here's something else:
http://www.shroudfilm.co.uk/hhmap.jpg
This is the map of Terra from the HH boardgame, it shows the palace as well as other stuff.
On TGC there was a big discussion about it, here's a quote for you:
Judjing by the place names in the Lightning Tower, the Outer Palace takes most of Nepal - it mentions the Kath Mandau Precinct (i.e. Kathmandau) Annapura Gate (the Annapura are a set of mountains around 100 miles to the West of Kathmandau) the Brahmaputra Plateau (the Brahmaputra is a river that joins the Ganges to the South East of Nepal) and the Karnali Delta (the Karnali is a river that starts in Tibet, flows through Nepal, joins the Ghaghara river in India, and eventually flows into the Ganges roughly 150-200 miles south of Kathmandau.
Hope this helps ^_^
As i know it, Europe is both a political entity and a Geographical entity. Turkey is in the Georagphical Europe, and politically (only because Istanbul is just west of the Bosphorus therefore a tiny bit of Turkey being in the political Europe.) and Geographically isnt it Eurasia? :D
And as i read it the Imperial Palace takes up the entire Northern Hemisphere. and the Golden Throne roughly where Nottingham used to be, being GWHQ?
The only info i can find atm is here
We also know that the Primarchs were created on a Luna base, on the moon, not under the Himalayas
And That the Emperor retired to the Imperial Dungeons when he left the Great Crusade, which are known to be below the Himalayas. The Dungeons are also described as being "Beneath the Imperial Palace".
