scale of primarchs
chrac
Not really, in the Collected Visions there is a nice 2 page spread with Horus planning his assault on Earth (the one with the red angel), that is a good representation of size.
Sorry, I don't think so at all. In the picture even taking into account perspective and that Horus stands a little lower than the rest of the Astartes present, he is just about the height of Abaddon. In the books he is described as easily towering the Mournival (even Abaddon). There are several pics of Primarchs with their retinue of Terminators and they are even taller than them by half a feet (?).
I got a Primarch miniature on my desk and he's exactly 47mm from head to toe in power armour, which compared to the rest of my Space Marines looks just perfect. Therefore I think Inquisitor Scale is not fit for a conversion, although I saw a nice pre-heresy Angron made out of Tyrus (which is quite small for 54mm).
It depends on the Primarch. As said prior, Magnus was probably the tallest, Alpharius-Omegon being the shortest. I can quite easily see Angron being the largest all around, he was a hulk even compared to other Primarchs (that means you too, Russ!). Mortarion was also exceptionally tall compared to other Primarchs as well.
Horus' height was reffered to during the vision he was shown when he was injured. When he was walking through the crowds, he was mentioned as being half as tall again as the tallest people in sight. If you esimate that the tallest people in the huge crowd were roughtly in the region of 6'4" tall (as an average esimate), that would make Horus the better part of 10 feet (3.3m) tall.
A scale of 9 - 10 feet is roughly how I imagined most of them to be, which exceptions such as Mortarion being significantly taller and Alpharius/Omegon being shorter than that (standard Astartes height, as has already been mentioned).
I think the heigh range of the Primarchs is likely to be fairly wide, in keeping with their appearances, as well as the fact that they're all "splinters" of the Emperor's whole as it were. I'd think Primarchs such as Angron and Vulkan to be much "bigger" in build than most, with Primarchs such as Corax or Lorgar being much more slightly built (according to Fulgrim and Tales of Heresy).
Most of the conversions i've seen have them about a head taller than a terminator. The plastic Chaos lord is a good base(Its slightly taller than a normal terminator) if you can make the legs and body look like power armour.
Actually, in the Index Astartes article about the Alpha Legion, it notes that Alpharius was in fact quite tall.
I can't remember for sure, but in there, he's as tall as Horus, if not a bit taller?
So...
Alpharius war taller than an Astarts, but it is mentioned in "Legion" that some normal Marines were fit to act in is stead. So we can assume he was taller, but not so much taller than the rest of the Primarchs.
Hmmm.... I don't know about that.
As previously stated (and I'll look it up later tonight!), I think Alpharius has actually been noted as being exceptionally tall amongst Primarchs.
So, it would stand to reason that his Legion, made from his geneseed, is also on the tall side.
Tall enough to 'fool' anyone else thinking they were looking at the 'real' Alpharius?
Probably!
Probably!
Actually, I believe in Fulgrim it makes note of him standing tall and erect, as if to try and measure up in stature to his brothers.
Well, there's a problem regarding the Alpha Legion. Didn't it mention in Legion that the Marines working with Alpharius and Omegon were altered to look more like their Primarch(s)? If that's the case, then maybe the Marines mentioned therein were inordinately tall for Astartes?
Given all that we 'know' from the Index Astartes article and LEGION, yes, probably.
I'm quite sure Alpharius was actually on the shorter side of the Primarch stature, which make use of his stealth and covert ops within the Legion even better. Think of it... if he's tall, even for a Primarch, having an normal Astartes stand in for him would be a waste of time. I'm sure he's a little taller then your normal Space Marine, but not by much.
