Spacefrisian Posted October 26, 2009 Share Posted October 26, 2009 I've bought the Assault on Black reach box set and wanted to paint them up as the Howling Griffons chapter. WD 309 shows a great example and a small tut on how to do this but i have a few questions before i start. 1: Painting yellow isn't one of my strong points, would dipping it be a better replacement? 2: I cant find brown inkt anymore what would make a good substitute from the newer ink lines? 3: Where can i find the Howling Griffons decals? The first step has already been done btw (in regards to paint) that is a whit undercoat. Link to comment https://bolterandchainsword.com/topic/182932-painting-howling-griffons/ Share on other sites More sharing options...
Brother Nihm Posted October 26, 2009 Share Posted October 26, 2009 1: Painting yellow isn't one of my strong points, would dipping it be a better replacement?Finding a good yellow recipe is preferable to dipping if you want a truly stunning army. If you want a tabletop ready army in no time, then dipping is for you. 2: I cant find brown inkt anymore what would make a good substitute from the newer ink lines?Make your own, or try out Devlan Mud on a test model. 3: Where can i find the Howling Griffons decals?Why right here at the BnC!http://www.bolterandchainsword.com/index.p...amp;showfile=48 http://www.bolterandchainsword.com/index.p...mp;showfile=386 Link to comment https://bolterandchainsword.com/topic/182932-painting-howling-griffons/#findComment-2163984 Share on other sites More sharing options...
Darkson Designs Posted October 31, 2009 Share Posted October 31, 2009 Try using a skinwash from Vallejo on the yellow. Its a nice mild shading and lining on a yellow. Please don't dip its not painting. Put some love into your marines. Link to comment https://bolterandchainsword.com/topic/182932-painting-howling-griffons/#findComment-2170295 Share on other sites More sharing options...
the thousandth whisper Posted November 4, 2009 Share Posted November 4, 2009 Do they still make vomit brown? well, I do my yellows and work them up from a brown with more and more brown added each time. Oh a white undercoat, didn't read that bit, um then wash it with the yellow wash, or thin down iyanden darksun and paint that in a few thinner layers over the yellow parts. then shade with devlan mud and iyanden darksun mix. Put it up when you're done, for the red I suggest Pig of sparta's red in the librarium Link to comment https://bolterandchainsword.com/topic/182932-painting-howling-griffons/#findComment-2174482 Share on other sites More sharing options...
