Spacefrisian Posted November 27, 2009 Share Posted November 27, 2009 I've build one before and at that time it was asked if i could do a Tut on it. I 've finally found the kit again so here goes. I started with the Legs and a big base (made from Plasticard). http://i34.photobucket.com/albums/d109/Spacefrisian/IMG_3210.jpg Using those pieces wich normally form the arms, the big toe comes from one of the other 4 legs, it needs some cutting on the upper side to make it more stable later on. Dont worry about cutting of to much as that part will dissapear under some armour later on. Also keep note that the upper part of the leg is best placed in the manner as shown on the pic this gives more posing freedom http://i34.photobucket.com/albums/d109/Spacefrisian/IMG_3211.jpg All pieces together should look like this. Once one leg is done continue on to the 2nd leg. Dont worry about left and right unless you pose that big toe with an angle. http://i34.photobucket.com/albums/d109/Spacefrisian/IMG_3214.jpg The 2 legs. Now comes some real cutting. For the part wich connects the 2 legs "midsection" http://i34.photobucket.com/albums/d109/Spacefrisian/IMG_3215.jpg This is the same part as that wich would normally hold the arms. you only need the front part of it so cutting halfway the 1st part would be enough. this will leave a hole there in wich the joint socket should fit (smaller part shown on pic). The end result of this should look like this. (with some armour platting added to th efront section though this is optional. http://i34.photobucket.com/albums/d109/Spacefrisian/IMG_3216.jpg Once finished you can put the legs on do some dryfitting for the pose (this requires patiance as the model might fall over while glueing) http://i34.photobucket.com/albums/d109/Spacefrisian/IMG_3217.jpg When that is done you have finished the hardest part. The body is quite straight forward so shouldn't be a problem. Link to comment https://bolterandchainsword.com/topic/185823-bipedal-defiler/ Share on other sites More sharing options...
Spacefrisian Posted November 27, 2009 Author Share Posted November 27, 2009 2nd part the arms/ body. http://i34.photobucket.com/albums/d109/Spacefrisian/IMG_3218.jpg The 1st arm din't get some real cutting work on it i just picked one of the legs from wich i previously removed parts to make a toe for the legs and put it to gether. I flattened the ball somehwat to make a more solid connection later on. Some drilling might be required cause pinning this will make this a piece of cake. This arm will become my Reaper cannon arm as can be seen on the next pic. http://i34.photobucket.com/albums/d109/Spacefrisian/IMG_3220.jpg This also shows how i've put it onto the body. Pretty much straight forward i guess. Onto the other arm. http://i34.photobucket.com/albums/d109/Spacefrisian/IMG_3219.jpg Again i used one of the legs from wich the other toe came from. But i wanted it different. I've cut it in half this time,and flattened the ballpart again. Did some drilling to make room for some pins and put the parts together again. http://i34.photobucket.com/albums/d109/Spacefrisian/IMG_3223.jpg A 3rd toe was used to make that thumb (obviously), the claws are the same as those wich normally form the claws on deffy. http://i34.photobucket.com/albums/d109/Spa...an/IMG_3221.jpg http://i34.photobucket.com/albums/d109/Spa...an/IMG_3222.jpg (some Close ups of the arm) http://i34.photobucket.com/albums/d109/Spacefrisian/IMG_3223.jpg Than i've put this arm as wel. And the head was put on as well as some shoulder guards (optional). http://i34.photobucket.com/albums/d109/Spacefrisian/IMG_3224.jpg Now you need some patiance for this as he might fall of several times unless you pinn this again. And you have youre bipedal defiler. (or Knightlike thing) Link to comment https://bolterandchainsword.com/topic/185823-bipedal-defiler/#findComment-2197588 Share on other sites More sharing options...
Spacefrisian Posted November 27, 2009 Author Share Posted November 27, 2009 Here are some additional pics with more stuff on it and a groupo pose with the other one. http://i34.photobucket.com/albums/d109/Spacefrisian/IMG_3225.jpg http://i34.photobucket.com/albums/d109/Spacefrisian/IMG_3227.jpg Link to comment https://bolterandchainsword.com/topic/185823-bipedal-defiler/#findComment-2197589 Share on other sites More sharing options...
MattCrawford Posted December 18, 2009 Share Posted December 18, 2009 Suitably terrifying, but I'm not sure how much I like the look. Also, standing him up like that is bound to cause a TLOS argument. Link to comment https://bolterandchainsword.com/topic/185823-bipedal-defiler/#findComment-2219125 Share on other sites More sharing options...
Thantoes Posted December 18, 2009 Share Posted December 18, 2009 I think it looks pretty cool overall. Cant see an issue with TLOS. Standing up like that just makes it more visible to my guns B) Link to comment https://bolterandchainsword.com/topic/185823-bipedal-defiler/#findComment-2219164 Share on other sites More sharing options...
Brazen Posted January 24, 2010 Share Posted January 24, 2010 Nice conversion, but looks too much like a Transformer for my taste. When I see it all I can imagine is the whining voice of Starscream from the old 1980's cartoon series when I was a kid :D Link to comment https://bolterandchainsword.com/topic/185823-bipedal-defiler/#findComment-2259110 Share on other sites More sharing options...
MattCrawford Posted January 24, 2010 Share Posted January 24, 2010 I think it looks pretty cool overall. Cant see an issue with TLOS. Standing up like that just makes it more visible to my guns <_< With his head that high and an ordnance weapon in his chest, I'd imagine he could lay down some serious dakka on your positions. Link to comment https://bolterandchainsword.com/topic/185823-bipedal-defiler/#findComment-2259611 Share on other sites More sharing options...
BlackSpike Posted January 24, 2010 Share Posted January 24, 2010 Nice model! :) Suitably spiky, should strike terror into the hearts of all but the most stalwart! The normal Defiler is pretty big, I can't see much TLOS issues. Any chance of a comparison pic? Link to comment https://bolterandchainsword.com/topic/185823-bipedal-defiler/#findComment-2259618 Share on other sites More sharing options...
RobDonkey Posted February 6, 2010 Share Posted February 6, 2010 Nice conversion, but looks too much like a Transformer for my taste. When I see it all I can imagine is the whining voice of Starscream from the old 1980's cartoon series when I was a kid :P Is that necessarily a bad thing? And the claws look much better used that way. I've never been a fan of the angry crab look. Link to comment https://bolterandchainsword.com/topic/185823-bipedal-defiler/#findComment-2275665 Share on other sites More sharing options...
Feytor Posted February 6, 2010 Share Posted February 6, 2010 With his head that high and an ordnance weapon in his chest, I'd imagine he could lay down some serious dakka on your positions. I think he'll fall on the ground firing the battle cannon but it's just only mine opinion and Im not jealous cuz I like crab-like defiler. :D Link to comment https://bolterandchainsword.com/topic/185823-bipedal-defiler/#findComment-2275720 Share on other sites More sharing options...
Spacefrisian Posted February 6, 2010 Author Share Posted February 6, 2010 With his head that high and an ordnance weapon in his chest, I'd imagine he could lay down some serious dakka on your positions. I think he'll fall on the ground firing the battle cannon but it's just only mine opinion and Im not jealous cuz I like crab-like defiler. B) Being demonic it doesn't need to keep track of normal laws of nature and such. Link to comment https://bolterandchainsword.com/topic/185823-bipedal-defiler/#findComment-2275880 Share on other sites More sharing options...
ghosty Posted February 7, 2010 Share Posted February 7, 2010 With his head that high and an ordnance weapon in his chest, I'd imagine he could lay down some serious dakka on your positions. I think he'll fall on the ground firing the battle cannon but it's just only mine opinion and Im not jealous cuz I like crab-like defiler. ;) Being demonic it doesn't need to keep track of normal laws of nature and such. so in essence "it's chaos, I ain't gotta 'slpain ;)"? Works for me :) Link to comment https://bolterandchainsword.com/topic/185823-bipedal-defiler/#findComment-2276544 Share on other sites More sharing options...
MaleOpener Posted February 9, 2011 Share Posted February 9, 2011 Now that's some idea you had there. Great job! Link to comment https://bolterandchainsword.com/topic/185823-bipedal-defiler/#findComment-2652260 Share on other sites More sharing options...
Zincite Posted February 10, 2011 Share Posted February 10, 2011 ...Also, standing him up like that is bound to cause a TLOS argument. Anybody who cares about winning so much that they complain about this surely wouldn't mind... It just makes it a bigger target? Very nice job man, very nice indeed :( Link to comment https://bolterandchainsword.com/topic/185823-bipedal-defiler/#findComment-2654491 Share on other sites More sharing options...
Task Force Gauntlet Posted February 19, 2011 Share Posted February 19, 2011 THAT. IS. AWSOME. Link to comment https://bolterandchainsword.com/topic/185823-bipedal-defiler/#findComment-2664426 Share on other sites More sharing options...
