Traitor Aranos Posted November 29, 2009 Share Posted November 29, 2009 So it was suggested to me by a Chaos player to add a unit of Havocs to my list with 4 autocannons. However, the Havocs only have 1 autocannon in the box. How should I acquire the other three? Thanks! Link to comment https://bolterandchainsword.com/topic/186030-autocannons/ Share on other sites More sharing options...
firewind Posted November 30, 2009 Share Posted November 30, 2009 The imperial guard heavy weapon squad box comes with three autocannons, three lascannons, three heavy bolters, and three missile launchers. Buying one of these would give you lots of heavy weapons, but if you can find someone who plays IG you could probably get the leftovers from them. Link to comment https://bolterandchainsword.com/topic/186030-autocannons/#findComment-2199832 Share on other sites More sharing options...
Traitor Aranos Posted November 30, 2009 Author Share Posted November 30, 2009 Thanks! Link to comment https://bolterandchainsword.com/topic/186030-autocannons/#findComment-2199871 Share on other sites More sharing options...
cathar the great Posted November 30, 2009 Share Posted November 30, 2009 Don't forget that the weapons in the IG box still need a bit of conversion to be held by Space Marines. Link to comment https://bolterandchainsword.com/topic/186030-autocannons/#findComment-2200176 Share on other sites More sharing options...
IronfrontAlex Posted August 4, 2010 Share Posted August 4, 2010 I take plastic Heavy Bolters and add plasticard to the tube, then a gargoyle head and drill holes into the barrel Link to comment https://bolterandchainsword.com/topic/186030-autocannons/#findComment-2480456 Share on other sites More sharing options...
CainTheHunter Posted August 4, 2010 Share Posted August 4, 2010 Or the quad autocannon weapon mount from the Aegis defence line. Link to comment https://bolterandchainsword.com/topic/186030-autocannons/#findComment-2480582 Share on other sites More sharing options...
chromedog Posted August 4, 2010 Share Posted August 4, 2010 I take plastic Heavy Bolters and add plasticard to the tube, then a gargoyle head and drill holes into the barrel ^ This is the easy way. SM devastators box. Add spikes. Heavy bolters converted to belt fed autocannons. Apart from that, bits swapping with mates or buying bits from sites (or swapping where those sites have such facilities). Link to comment https://bolterandchainsword.com/topic/186030-autocannons/#findComment-2481058 Share on other sites More sharing options...
IronfrontAlex Posted August 5, 2010 Share Posted August 5, 2010 QUOTE (IronfrontAlex @ Aug 4 2010, 07:38 PM) * I take plastic Heavy Bolters and add plasticard to the tube, then a gargoyle head and drill holes into the barrel ^ This is the easy way.SM devastators box. Add spikes. Heavy bolters converted to belt fed autocannons. Apart from that, bits swapping with mates or buying bits from sites (or swapping where those sites have such facilities). hey it works tho! and doesnt look half bad! Link to comment https://bolterandchainsword.com/topic/186030-autocannons/#findComment-2481305 Share on other sites More sharing options...
lord gunthar Posted August 6, 2010 Share Posted August 6, 2010 Just in case you dont know, you can buy the havoc models individually on the gw website. Link to comment https://bolterandchainsword.com/topic/186030-autocannons/#findComment-2482114 Share on other sites More sharing options...
templarboy Posted August 6, 2010 Share Posted August 6, 2010 I can't help but say that Havocs are kinda broken right now. Obliterators are a vastly better choice. Ugly models though. Havocs just aren't worth the points right now. Aside from that, using heavy flamers or assault cannons with some plastic rod additions can be very easily made to look great. The chaos terminator box has a nice reaper autocannon as well. All of these would be easy conversion materials. Link to comment https://bolterandchainsword.com/topic/186030-autocannons/#findComment-2482686 Share on other sites More sharing options...
