TrentL Posted May 1, 2010 Share Posted May 1, 2010 So the Icon pack looks like this on Forge world FW Icons But it actually arrives like: Actual FW Icons I'd love some advice for how to get them out of that extra stuff..... Link to comment https://bolterandchainsword.com/topic/200173-fw-icon-packs/ Share on other sites More sharing options...
faol Posted May 1, 2010 Share Posted May 1, 2010 you may have to trim and or sand them down I've don't have any resin XP so more knowledgeable battle brother please come to aide Link to comment https://bolterandchainsword.com/topic/200173-fw-icon-packs/#findComment-2384418 Share on other sites More sharing options...
winterdyne Posted May 1, 2010 Share Posted May 1, 2010 A sharp, pointed hobby knife. Trim patiently! Link to comment https://bolterandchainsword.com/topic/200173-fw-icon-packs/#findComment-2384419 Share on other sites More sharing options...
templarboy Posted May 2, 2010 Share Posted May 2, 2010 So the Icon pack looks like this on Forge world FW Icons But it actually arrives like: Actual FW Icons I'd love some advice for how to get them out of that extra stuff..... It is actually a good thing that they come with all that flash and sprue. All those fiddly parts would very likely break before you could use them. As with any FW stuff-Bring some modelling-fu when you deal with it. It is wonderful but takes some time and skill to use. Link to comment https://bolterandchainsword.com/topic/200173-fw-icon-packs/#findComment-2384795 Share on other sites More sharing options...
igotsmeakabob!! Posted May 2, 2010 Share Posted May 2, 2010 Don't but the icon packs, they're terrible. Buy the brass-etched ones. I made the same mistake once as well. Link to comment https://bolterandchainsword.com/topic/200173-fw-icon-packs/#findComment-2384864 Share on other sites More sharing options...
maverike_prime Posted May 3, 2010 Share Posted May 3, 2010 A good trick I found with the resin Icon packs is to use a powered sander of some sort, a large dremmel wheel for instance, and come from the back of the icon you want. once you reduce the thickness of the surrounding flash to a point that you can just about see through it, you can come in with a decent Hobby knife and cut out the icon you want. Link to comment https://bolterandchainsword.com/topic/200173-fw-icon-packs/#findComment-2385752 Share on other sites More sharing options...
chromedog Posted May 3, 2010 Share Posted May 3, 2010 Sand the back side down until you can cut through it and around the icons. To get them off the strip (which is the pouring gate - where the resin goes in) use a fine bladed saw, like a razor saw. Do not use clippers - you're just as likely to make them shatter as not. Go slow and patiently. If you rush it, you will probably ruin them and hurt yourself. Link to comment https://bolterandchainsword.com/topic/200173-fw-icon-packs/#findComment-2385966 Share on other sites More sharing options...
glayvin34 Posted May 3, 2010 Share Posted May 3, 2010 Yeah, I broke 2 out of 3 Ultramarine icons, they're a pain to deal with. So I have 2 solutions- 1. I Pretend I'm carving the icon from scratch. That way I just carve it calmly and purposefully and take my time, because it does take quite a bit to get them ready. 2. Make a backing out of the extra resin. You can cut a circle or rectangle around the icon, then trim down those lines that stick out and it looks like the icon is mounted on a piece of material. Slightly easier than cutting the icon out. Link to comment https://bolterandchainsword.com/topic/200173-fw-icon-packs/#findComment-2386874 Share on other sites More sharing options...
winterdyne Posted May 3, 2010 Share Posted May 3, 2010 I recently bought this: http://www.toysrus.co.uk/Toys-R-Us/Learnin...rkshop(0044582) and modified it with a mains adapter I had lying around, and a new sheet of 600 grit paper on it's bench sander attachment. It's slow enough to sand resin nicely without melting it. Could do with a higher torque motor in there and a few other modifications, but all in all, damn handy. The lathe works alright with modelling putty and so on (new / repaired Eldar weapons now easy!) Note: When sanding resin, you *really* need to wear a mask. Really. Link to comment https://bolterandchainsword.com/topic/200173-fw-icon-packs/#findComment-2386892 Share on other sites More sharing options...
LoneSniperSG Posted May 4, 2010 Share Posted May 4, 2010 Wow Winterdyne. I never would have thought to use a little kid's thing for actual model work. Link to comment https://bolterandchainsword.com/topic/200173-fw-icon-packs/#findComment-2387185 Share on other sites More sharing options...
winterdyne Posted May 4, 2010 Share Posted May 4, 2010 Out of the box, it's not great - and there are a few changes I want to make - brass spindles and a proper chuck for the lathe as well as improved bearings, adjusting the drill press to have a clamp rather than a hole. Nothing major. Link to comment https://bolterandchainsword.com/topic/200173-fw-icon-packs/#findComment-2387247 Share on other sites More sharing options...
TrentL Posted May 18, 2010 Author Share Posted May 18, 2010 I also noticed these icons are rather thick... and when looking at it sideways it almost looks like it is stuck on a backing... I'm almost wondering if I'm supposed to cut it off the backing rather than cut around the icon itself.... Link to comment https://bolterandchainsword.com/topic/200173-fw-icon-packs/#findComment-2403735 Share on other sites More sharing options...
Venerable Jazzman Posted May 18, 2010 Share Posted May 18, 2010 You won't manage to cut it off the backing, it'll just snap. I sanded mine down very carefully on the back til i got them as thick as I wanted. Remember to wear some sort of mask when sanding resin, it's not good for you And good luck getting the skull and crossbones off in one piece :) Link to comment https://bolterandchainsword.com/topic/200173-fw-icon-packs/#findComment-2404398 Share on other sites More sharing options...
Inquisitor Kravin Posted May 20, 2010 Share Posted May 20, 2010 Thanks for this topic. You just saved me a lot of trouble! I was planning on buying some of these but now I'll stick with the brass etch which is fantastic. Link to comment https://bolterandchainsword.com/topic/200173-fw-icon-packs/#findComment-2406078 Share on other sites More sharing options...
TrentL Posted May 20, 2010 Author Share Posted May 20, 2010 Yeah I just saw someone elses and noticed how thin theirs was ... I'm going to go pry off the symbol off my vindicator and sand it down some (While wearing a mask ... as Resin can KILL YOU! (Or at least that's what I keep hearing)) Link to comment https://bolterandchainsword.com/topic/200173-fw-icon-packs/#findComment-2406341 Share on other sites More sharing options...
