Stefoserpent Posted May 22, 2010 Share Posted May 22, 2010 Hello members of the Bolter and Chainsword forums. I am using the ubiquitous IKEA all- around glass display cabinet to store and display my models. However I noticed that the dust gets even inside the cabinet , thus covering the glass shelves and the models themselves. I would like to know just how to keep the dust off my models... its annoying having to keep my beautifully painted Blood Angels inside the carrying case.... And also , whats the best way to remove the dust from the models? On my models the dust is not " visible " but the glass bottom has it , and so does the models... Thanks in advance Stefoserpent Link to comment https://bolterandchainsword.com/topic/202138-dust-in-display-cabinet/ Share on other sites More sharing options...
CarbonCopy Posted May 22, 2010 Share Posted May 22, 2010 In general, it sounds like you just don't have much air flow in the room. Most dust is dead skin cells and pet debris. Try opening the window every now & then and running a vacuum cleaner to suck the room. You'll notice a dramatic reduction in the amount of dust in the room in general, in addition to what collects in the cases. FYI; I use the same kind of cabinets and don't have a problem with dust in the cases. And we have THREE cats! Link to comment https://bolterandchainsword.com/topic/202138-dust-in-display-cabinet/#findComment-2408979 Share on other sites More sharing options...
Kurgan the Lurker Posted May 23, 2010 Share Posted May 23, 2010 Better air flow in the room your case is in. Regular (i.e. daily) vac of the carpet or sweeping the floor if they are tile/hard wood/etc. Getting something like this specifically for the cabinet: http://www.micromark.com/MICRO-VAC,6493.html Link to comment https://bolterandchainsword.com/topic/202138-dust-in-display-cabinet/#findComment-2409094 Share on other sites More sharing options...
Stefoserpent Posted May 24, 2010 Author Share Posted May 24, 2010 I see...So opening the windows more often is the way to go. As for the vacuum cleaner , maybe I will get something like this. Thanks a lot. Link to comment https://bolterandchainsword.com/topic/202138-dust-in-display-cabinet/#findComment-2410667 Share on other sites More sharing options...
pingo Posted May 24, 2010 Share Posted May 24, 2010 As for the vacuum cleaner , maybe I will get something like this. Absolutely! The way to combat dust is not to let it build up in the first place. Well, I never thought we'd get onto household cleaning on B&C! And also: those cabinets are awesome :) I have two. They fill up alarmingly quick though! Link to comment https://bolterandchainsword.com/topic/202138-dust-in-display-cabinet/#findComment-2410713 Share on other sites More sharing options...
