ArcticFox Posted May 27, 2010 Share Posted May 27, 2010 I have just acquired two really nice equipment cases I'll be using to store and transport my Black Templars. The only problem I have is that I want to cut the foam to store my units and vehicles, but I don't want it to be all uneven and look like I used my teeth. What's the best tool/approach to use when cutting new foam? Link to comment https://bolterandchainsword.com/topic/202623-cutting-foam/ Share on other sites More sharing options...
ShinyRhino Posted May 27, 2010 Share Posted May 27, 2010 I use one of those extendable craft blades with the snap-off sections. Cutting foam dulls a balde very quickly, so you'll want to be constantly changing the blade. However, unless your foam is very thin (1/2" or so), it's going to come out uneven if you're cutting individual pockets into a big block. it's just a fact of life. Unless you're using a machine-guided toolt o cut, it won't be perfect. I wouldn't get too hung up on it though. No one examines the foam in your carry cases for neatness, and judges you based on that. ^_^ Link to comment https://bolterandchainsword.com/topic/202623-cutting-foam/#findComment-2414687 Share on other sites More sharing options...
averykess Posted May 27, 2010 Share Posted May 27, 2010 Do you have the foam already? Link to comment https://bolterandchainsword.com/topic/202623-cutting-foam/#findComment-2414717 Share on other sites More sharing options...
ArcticFox Posted May 27, 2010 Author Share Posted May 27, 2010 Yah it came with the cases. Link to comment https://bolterandchainsword.com/topic/202623-cutting-foam/#findComment-2414718 Share on other sites More sharing options...
averykess Posted May 27, 2010 Share Posted May 27, 2010 you could try a hot wire cutter. Link to comment https://bolterandchainsword.com/topic/202623-cutting-foam/#findComment-2414748 Share on other sites More sharing options...
ShinyRhino Posted May 27, 2010 Share Posted May 27, 2010 you could try a hot wire cutter. They don't seem to work on sponge foam. Probably a melting point issue. Link to comment https://bolterandchainsword.com/topic/202623-cutting-foam/#findComment-2414845 Share on other sites More sharing options...
hmk17 Posted May 27, 2010 Share Posted May 27, 2010 Is it like the GW cases with sponge foam sheets or foam blocks like Army Transport stuff? Link to comment https://bolterandchainsword.com/topic/202623-cutting-foam/#findComment-2414921 Share on other sites More sharing options...
matt.k Posted May 28, 2010 Share Posted May 28, 2010 scissors can work depending on the density of the foam Link to comment https://bolterandchainsword.com/topic/202623-cutting-foam/#findComment-2415149 Share on other sites More sharing options...
ArcticFox Posted May 28, 2010 Author Share Posted May 28, 2010 Is it like the GW cases with sponge foam sheets or foam blocks like Army Transport stuff? It's a spongy type of foam. Firmer than mattress foam, but still soft enough to bend in half. Link to comment https://bolterandchainsword.com/topic/202623-cutting-foam/#findComment-2415681 Share on other sites More sharing options...
SquigBait Posted May 28, 2010 Share Posted May 28, 2010 Depnding on the thickness, a bread knife works really well for the thicker pieces of foam. If you are careful it will leave a very clean cut. Electric carving knives work really well too (I used to work at a surplus hardware store and this is what we used to cut the sheets of foam we sold to size and shape). Just make sure you do not use you mothers good one, it may be worth finding your own at a second hand store or something. Link to comment https://bolterandchainsword.com/topic/202623-cutting-foam/#findComment-2415703 Share on other sites More sharing options...
ShinyRhino Posted May 28, 2010 Share Posted May 28, 2010 Depnding on the thickness, a bread knife works really well for the thicker pieces of foam. If you are careful it will leave a very clean cut. Electric carving knives work really well too (I used to work at a surplus hardware store and this is what we used to cut the sheets of foam we sold to size and shape). Just make sure you do not use you mothers good one, it may be worth finding your own at a second hand store or something. I own one of these for just that reason. I found it at Goodwill for $3. I recently used it to cut some blocks of old couch foam into shape for a pistolc ase I use for my tanks. It was great at cutting the thick, dense foam into the rough case shape, but it wasn't any good at cutting the storage compartments. Link to comment https://bolterandchainsword.com/topic/202623-cutting-foam/#findComment-2415729 Share on other sites More sharing options...
chewielight Posted May 28, 2010 Share Posted May 28, 2010 for cutting foam I use a hot knife. They are a largeish type cutter so you have to be careful and make sure you cut the foam outside. I got mine from amazon for about $17 Link to comment https://bolterandchainsword.com/topic/202623-cutting-foam/#findComment-2415769 Share on other sites More sharing options...
Raven Angel Posted May 28, 2010 Share Posted May 28, 2010 Use an electric carving knife for meat. I have a friend that does reapolstering work and thats what he told me to use and it does work. Link to comment https://bolterandchainsword.com/topic/202623-cutting-foam/#findComment-2416011 Share on other sites More sharing options...
