Iron Father Rik Posted May 30, 2010 Share Posted May 30, 2010 Hey guys, I've recently begun a Flesh Tearers army, which is likely to be more of a modelling and collecting project than a gaming one, but I digress. I had the idea of modelling the models that I wish to equip with power fists as carrying eviscerator blades as "counts as" power fists - the rules are similar anyway, and I think it would look much cooler for the Flesh Tearers (Seth carries one after all!) However I have hit a bit of a stumbling block in that I am not sure how exactly I can do this. I have been seeding the double-edged chaos chainblades (with chaos iconography removed) throughout my army, and intend to also use some chain-axes, to get what I see as the Flesh Tearers "feel", using these as regular chainsword close-combat weapons. I want the "eviscerators" to, obviously, be bigger and more vicious looking than the regular chainblades, and I am at a loss as to what parts to use for them. Can anyone suggest some bitz that would be relatively easily converted into an eviscerator for a Space Marine? Ideally it should be double handed (though not a necessity), and should be larger than a regular chainblade (Sisters Repentia eviscerators don't seem much bigger than a normal Space Marine chainsword). I am aware that Seth has one, and I only need a handful of them, but I think it would get a bit pricey and a bit samey if I bought four or five Seth models! Cheers guys. Link to comment https://bolterandchainsword.com/topic/202851-modelling-eviscerators/ Share on other sites More sharing options...
Whitefireinferno Posted May 30, 2010 Share Posted May 30, 2010 What are you talking about MY CHAPTER MASTER DOES NOT HAVE A NANCY EVISCERATOR. He has the Blood Reaver one of the most Brutal chainswords in existance But more to the point Just use the DC thunderhammer (the Hilt part since its 2 handed) and cut 2 chaos chainswords so its what ever legnth you want, I however would'nt do this because it will detract from Seths Blood Reaver's EPIC BAD ASSERY. but yeah hope that could have been of some use. Link to comment https://bolterandchainsword.com/topic/202851-modelling-eviscerators/#findComment-2417700 Share on other sites More sharing options...
Iron Father Rik Posted May 30, 2010 Author Share Posted May 30, 2010 What's wrong with Seth's eviscerator?!? And yeah, I had considered that as an option - using the DC thunder hammer hilt. That was all I could really come up with, granted for the relatively little thought I'd put into it. Any other suggestions? Link to comment https://bolterandchainsword.com/topic/202851-modelling-eviscerators/#findComment-2417914 Share on other sites More sharing options...
Lestat Posted May 30, 2010 Share Posted May 30, 2010 You could extend a chainsword be carefully cutting the tip off and adding another chainsword's blade part to the top. I have seen this done with Marines but to get a chunkier feel, you might want to try using the chaos ones for this. Link to comment https://bolterandchainsword.com/topic/202851-modelling-eviscerators/#findComment-2417952 Share on other sites More sharing options...
Raven Angel Posted May 31, 2010 Share Posted May 31, 2010 Check these out http://www.games-workshop.com/gws/common/x...p;mHeight=627px http://www.games-workshop.com/gws/common/x...p;mHeight=627px Link to comment https://bolterandchainsword.com/topic/202851-modelling-eviscerators/#findComment-2418190 Share on other sites More sharing options...
