Ash Tekka Posted June 30, 2010 Share Posted June 30, 2010 I bought a bag of bits and theres some older looking metal bits in there that I'm not sure what they look like. I don't have access to my camera currently so I will try to describe them as best as I can: 1) backpack for a space marine with two large wings coming off each side that are metal looking not feathery. 2) a things I think might be old missile launchers as they have like a clip full of missles 3) looks like a heavy bolter but looks like it might attach on the outside of the shoulder 4) 3 items that I think might be las cannons: all three mount over the shoulder. one is longer barreled and has a front grip with a small hand shield/long trigger cant tell what that might be. the other two are smaller versions of that same item. 5) last item is a long dragon looking thing with an open mouth and only two front legs...I don't even think this is a warhammer item... I'll try and get pics tonight but figured I'd post it up here to see if anyone can help with jsut my descriptions. Link to comment https://bolterandchainsword.com/topic/205420-need-help-identifying-old-bits/ Share on other sites More sharing options...
Brother Rathul Posted June 30, 2010 Share Posted June 30, 2010 Do you have any pictures? Those whould really help identifying the items you mentioned. Link to comment https://bolterandchainsword.com/topic/205420-need-help-identifying-old-bits/#findComment-2450418 Share on other sites More sharing options...
chenley Posted June 30, 2010 Share Posted June 30, 2010 2) a things I think might be old missile launchers as they have like a clip full of missles More then likely 1st or 2nd edition missile launcher, if its metal most likely 2nd edition, otherwise 50/50 chance its 2nd edition. 3) looks like a heavy bolter but looks like it might attach on the outside of the shoulder shoulder mounted heavy bolter for a marine is my guess. 4) 3 items that I think might be las cannons: all three mount over the shoulder. one is longer barreled and has a front grip with a small hand shield/long trigger cant tell what that might be. the other two are smaller versions of that same item. probably are lascannons, but without pictures, can not tell for sure, and weather or not they are plastic or metal, of course a couple of them could be ork versions. Link to comment https://bolterandchainsword.com/topic/205420-need-help-identifying-old-bits/#findComment-2450430 Share on other sites More sharing options...
averykess Posted June 30, 2010 Share Posted June 30, 2010 I bought a bag of bits and theres some older looking metal bits in there that I'm not sure what they look like. I don't have access to my camera currently so I will try to describe them as best as I can: 1) backpack for a space marine with two large wings coming off each side that are metal looking not feathery. That sounds like a Necromunda Yeld Spyrer backpack http://www.games-workshop.com/gws/catalog/...dId=prod1740000 or a Sisters of Battle Seraphim backpack http://media.photobucket.com/image/sob%20s...e/seraphim2.jpg 2) a things I think might be old missile launchers as they have like a clip full of missles Does it look like the left-most of the 3 featured marines on this page? http://www.solegends.com/citrt/rtb01marines-01.htm 3) looks like a heavy bolter but looks like it might attach on the outside of the shoulder 4) 3 items that I think might be las cannons: all three mount over the shoulder. one is longer barreled and has a front grip with a small hand shield/long trigger cant tell what that might be. the other two are smaller versions of that same item. For 3 & 4, are any of these close? http://www.solegends.com/citrt/rt103marinehvywpns.htm 5) last item is a long dragon looking thing with an open mouth and only two front legs...I don't even think this is a warhammer item... It could be a citadel dragon or the orc wyvern. look at the dragon pages here: http://www.solegends.com/citcat88/index.htm I'll try and get pics tonight but figured I'd post it up here to see if anyone can help with jsut my descriptions. Link to comment https://bolterandchainsword.com/topic/205420-need-help-identifying-old-bits/#findComment-2450435 Share on other sites More sharing options...
Ash Tekka Posted June 30, 2010 Author Share Posted June 30, 2010 All the parts I listed are metal if that helps. I won't be able to get pictures until tonight at earliest. I'm sitting at work sorting the bits right now. I have a bunch of plastic ones that are different colored plastic and are smaller. I think those go to that space crusade or whatever it was called. And somehow I think I have a little space ship from something... Link to comment https://bolterandchainsword.com/topic/205420-need-help-identifying-old-bits/#findComment-2450436 Share on other sites More sharing options...
maverike_prime Posted June 30, 2010 Share Posted June 30, 2010 2) a things I think might be old missile launchers as they have like a clip full of missles3) looks like a heavy bolter but looks like it might attach on the outside of the shoulder 4) 3 items that I think might be las cannons: all three mount over the shoulder. one is longer barreled and has a front grip with a small hand shield/long trigger cant tell what that might be. the other two are smaller versions of that same item. the old Second Edition Heavy weapons were ALL shoulder mounted. Based on your descriptions they could be 2nd edition Heavy weapons, but with out pictures that's a shot in the dark at best. Link to comment https://bolterandchainsword.com/topic/205420-need-help-identifying-old-bits/#findComment-2450446 Share on other sites More sharing options...
Ash Tekka Posted July 1, 2010 Author Share Posted July 1, 2010 Ok that solves the weapons. How about the winged pack or the weird dragon thing? You can see them in this pic: Dragon thing is at the top, backpack is bottom left. Link to comment https://bolterandchainsword.com/topic/205420-need-help-identifying-old-bits/#findComment-2450470 Share on other sites More sharing options...
Venerable Jazzman Posted July 1, 2010 Share Posted July 1, 2010 The backpack is a Necromunda Spyrer Yeld backpack http://www.games-workshop.com/MEDIA_CustomProductCatalog/m2120021_99060599142_YeldSpyrer_873x627.jpg can't tell what the dragony thing is without a better pic, sorry. My Fantasy-fu is weak :D Link to comment https://bolterandchainsword.com/topic/205420-need-help-identifying-old-bits/#findComment-2450800 Share on other sites More sharing options...
chromedog Posted July 1, 2010 Share Posted July 1, 2010 Do the heavy weapons look anything like these? If so, that makes them the 2nd ed SM heavy weapons. ALL heavy weapons (except for the eldar, who had hover platforms back then too) back then were shoulder mounts. Doesn't matter if they are chaos, loyalist or ork. http://www.solegends.com/citcat9x3/c92396marines-02.jpg Better pic of the lascannon, heavy bolter and missile launcher on the long fangs page. http://www.solegends.com/citcat9x3/c92393bclawslongfangs-02.jpg Link to comment https://bolterandchainsword.com/topic/205420-need-help-identifying-old-bits/#findComment-2450827 Share on other sites More sharing options...
maverike_prime Posted July 1, 2010 Share Posted July 1, 2010 I don't recognize the Dragon bit. Granted I haven't played Fantasy in anywhere near as long I've played 40k but I'm generally pretty good at IDing what army a given piece comes from at least. It's too small to be one of the previous Dragon model kits. It doesn't have the heavy scales to be the older Hydra model. I don't recall the Lizardmen using anything in the form of a dragon like that. I can't do any better then a half guess with out a better picture. It could be a tail bit from one of the older Dragon Models. Link to comment https://bolterandchainsword.com/topic/205420-need-help-identifying-old-bits/#findComment-2450867 Share on other sites More sharing options...
fivepointedstar Posted July 1, 2010 Share Posted July 1, 2010 dragon; looks like a dragon charoit front piece from fantasy. possibly high elf Link to comment https://bolterandchainsword.com/topic/205420-need-help-identifying-old-bits/#findComment-2450958 Share on other sites More sharing options...
fivepointedstar Posted July 1, 2010 Share Posted July 1, 2010 dragon; looks like a dragon charoit front piece from fantasy. possibly high elf Link to comment https://bolterandchainsword.com/topic/205420-need-help-identifying-old-bits/#findComment-2450959 Share on other sites More sharing options...
fivepointedstar Posted July 1, 2010 Share Posted July 1, 2010 dragon; looks like a dragon charoit front piece from fantasy. possibly high elf Link to comment https://bolterandchainsword.com/topic/205420-need-help-identifying-old-bits/#findComment-2450961 Share on other sites More sharing options...
fivepointedstar Posted July 1, 2010 Share Posted July 1, 2010 sorry pc glitched triple posted Link to comment https://bolterandchainsword.com/topic/205420-need-help-identifying-old-bits/#findComment-2450972 Share on other sites More sharing options...
Ash Tekka Posted July 1, 2010 Author Share Posted July 1, 2010 Those pictures are EXACTLY the weapons I have. I think I ended up with 3 lascannons, I have one exactly like in that pic then the other two are just a wee bit smaller but still look the same. Those necromunda guys a weird looking. Geuss I can always hack up the pack to make something custom out of it. Thanks a bunch guys. Link to comment https://bolterandchainsword.com/topic/205420-need-help-identifying-old-bits/#findComment-2451073 Share on other sites More sharing options...
Leonaides Posted July 1, 2010 Share Posted July 1, 2010 Thats because those Necromunda guys are actually wearing Tau-made armour. Go figure - tau manage to make suits of armour that kick gluteus maximus in close combat. THanks the Emperor that they never sue them themselves... Link to comment https://bolterandchainsword.com/topic/205420-need-help-identifying-old-bits/#findComment-2451178 Share on other sites More sharing options...
Venerable Jazzman Posted July 2, 2010 Share Posted July 2, 2010 Geuss I can always hack up the pack to make something custom out of it. Noooooooooo!! Use it as a jump pack for a Librarian or a Captain. etc. Or sell it/swap it with someone who'd use it. You can bend it carefully so it wraps round a figure better, looks a lot less "Magnificent Men in their Flying Machines" if you do so. I'm using one on my Mephiston, still have one for another project. http://img.photobucket.com/albums/v110/fatjazzer/meph1.jpg Link to comment https://bolterandchainsword.com/topic/205420-need-help-identifying-old-bits/#findComment-2451748 Share on other sites More sharing options...
