fivepointedstar Posted July 27, 2010 Share Posted July 27, 2010 for captian the lightning claws are 15pts each is that right. because a TH is 30pt also and is one handed? why is it so much for twin claws? Link to comment https://bolterandchainsword.com/topic/207397-lightning-claws-cost/ Share on other sites More sharing options...
Forgefather Vulkan Posted July 27, 2010 Share Posted July 27, 2010 Well lightning claws are 15pts each and a pair are cheaper than 1 TH and you be the bonus +1 A because you've got 2... Forgefather Link to comment https://bolterandchainsword.com/topic/207397-lightning-claws-cost/#findComment-2473832 Share on other sites More sharing options...
fivepointedstar Posted July 27, 2010 Author Share Posted July 27, 2010 in c:ba the points cost said exchange bp/bolter for lightning claw 15pt. exchange ccw for LC 15pts same as a power weapon that 30pt. for that id rather take Th, and get a PP, or IP for 15 extra. see im confused Link to comment https://bolterandchainsword.com/topic/207397-lightning-claws-cost/#findComment-2473839 Share on other sites More sharing options...
JamesI Posted July 27, 2010 Share Posted July 27, 2010 Well, if lightning claws were cheaper than power weapons, no one would take power weapons. Lightning claws on a captain with I5 and then add furious charge to that is really good (probably not as good as a reclusiarch overall, but for a solo character can kill a ton) Link to comment https://bolterandchainsword.com/topic/207397-lightning-claws-cost/#findComment-2473841 Share on other sites More sharing options...
fivepointedstar Posted July 27, 2010 Author Share Posted July 27, 2010 so is it better to give a captian the pair rather than one because of the cost. Link to comment https://bolterandchainsword.com/topic/207397-lightning-claws-cost/#findComment-2473869 Share on other sites More sharing options...
Forgefather Vulkan Posted July 27, 2010 Share Posted July 27, 2010 in c:ba the points cost said exchange bp/bolter for lightning claw 15pt. exchange ccw for LC 15pts same as a power weapon that 30pt. for that id rather take Th, and get a PP, or IP for 15 extra. see im confused It says that you can exchange your bolt pistol/boltgun for a lighting claw (15pts) and your chainsword for one too (+15) making it 30pts for the pair Forgefather Link to comment https://bolterandchainsword.com/topic/207397-lightning-claws-cost/#findComment-2473965 Share on other sites More sharing options...
Drachnon Posted July 27, 2010 Share Posted July 27, 2010 A pair of lightning claws indeed costs the same as a thunderhammer, I'm not sure what is more effective though. Obviously against vehicles the hammer is better but in normal combat the claws ability to strike first can be very nice. Link to comment https://bolterandchainsword.com/topic/207397-lightning-claws-cost/#findComment-2473991 Share on other sites More sharing options...
Andrew_Beck Posted July 27, 2010 Share Posted July 27, 2010 still captain with Jp and Twin THs is muss have. fly around and shout "Let the hammer fall" anytime he charge/kill something. Link to comment https://bolterandchainsword.com/topic/207397-lightning-claws-cost/#findComment-2474000 Share on other sites More sharing options...
Grey Mage Posted July 27, 2010 Share Posted July 27, 2010 so is it better to give a captian the pair rather than one because of the cost. You give him the pair because otherwise you only get his base attacks. Thunderhammers cost 60pts to get that second attack. So its alot less of a deal if you look at it like that. Link to comment https://bolterandchainsword.com/topic/207397-lightning-claws-cost/#findComment-2474062 Share on other sites More sharing options...
JamesI Posted July 27, 2010 Share Posted July 27, 2010 If I had a captain with a lightning claw, the other arm would also be a lightning claw unless I wanted a storm shield. Link to comment https://bolterandchainsword.com/topic/207397-lightning-claws-cost/#findComment-2474140 Share on other sites More sharing options...
Grey Mage Posted July 27, 2010 Share Posted July 27, 2010 If I had a captain with a lightning claw, the other arm would also be a lightning claw unless I wanted a storm shield. My friends Flesh-tearers captain has 2xLC and regularly kills 3-4 marines on the charge. Wich is enough to make sure his combat squad can take the victory most of the time. Link to comment https://bolterandchainsword.com/topic/207397-lightning-claws-cost/#findComment-2474196 Share on other sites More sharing options...
fivepointedstar Posted July 28, 2010 Author Share Posted July 28, 2010 sounds about right. now ill have to model him with two lc's, and a bike. thanks Link to comment https://bolterandchainsword.com/topic/207397-lightning-claws-cost/#findComment-2474718 Share on other sites More sharing options...
