NExOBLIVISCARIS Posted August 10, 2010 Share Posted August 10, 2010 im putting a 10 man sternguard squad in my army and so far i have 10 guards with a sargent that has a power fist and melta bombs what else is good on them? Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/ Share on other sites More sharing options...
vharing Posted August 10, 2010 Share Posted August 10, 2010 I run a squad with 2-3 combi meltas and 2 heavy flamers. I play mostly against nids. It is good against both MCs and swarms. Loaded up in a rhino or LRC it can kick a lot of a**. Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2484993 Share on other sites More sharing options...
Massawyrm Posted August 10, 2010 Share Posted August 10, 2010 Run 9 instead of 10, then put them in a pod with a Sanguinary Priest. Combi-plasma and Plasma Cannons for loadouts. They are magnificent. Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2485038 Share on other sites More sharing options...
the jeske Posted August 10, 2010 Share Posted August 10, 2010 10 with 6-8 combi meltas . combat squading one the turn they land . not bad in alfa strike builds , because they pop two tanks each. sadly BAs cant play with 2x10 4 melta 4 plasma build. Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2485050 Share on other sites More sharing options...
WarpWhisper Posted August 10, 2010 Share Posted August 10, 2010 Don't put melta bombs on a p.fist sgt unless you're going to be facing a lot of stationary Land raiders; in almost all cases making three power fist attacks is superior to making that single melta bomb roll. Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2485131 Share on other sites More sharing options...
NExOBLIVISCARIS Posted August 10, 2010 Author Share Posted August 10, 2010 i was thinking about dropping the stern guard for a full vanguard squad with 4 power weapons because the rest of my army is dante,2 sanguinary guard squads, a priest and terminators and i was planning on deep striking dante with a priest and and some guards, poping a transport with 2-3 infernus pistol shots then assualting the ocupants with the vanguards in the same turn they both deep strike plus the priest would be close enough to give the squad the bonuses. sound good? Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2485194 Share on other sites More sharing options...
Brother-Captain Devlonir Posted August 10, 2010 Share Posted August 10, 2010 i was thinking about dropping the stern guard for a full vanguard squad with 4 power weapons because the rest of my army is dante,2 sanguinary guard squads, a priest and terminators and i was planning on deep striking dante with a priest and and some guards, poping a transport with 2-3 infernus pistol shots then assualting the ocupants with the vanguards in the same turn they both deep strike plus the priest would be close enough to give the squad the bonuses. sound good? One problem: Once Dante join's the Vanguard, the squad looses heroic intervention. Yes, veterans loose their veteran skill when the most veteran living space marine in the universe joins them.. Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2485240 Share on other sites More sharing options...
toaae Posted August 10, 2010 Share Posted August 10, 2010 i was thinking about dropping the stern guard for a full vanguard squad with 4 power weapons because the rest of my army is dante,2 sanguinary guard squads, a priest and terminators and i was planning on deep striking dante with a priest and and some guards, poping a transport with 2-3 infernus pistol shots then assualting the ocupants with the vanguards in the same turn they both deep strike plus the priest would be close enough to give the squad the bonuses. sound good? One problem: Once Dante join's the Vanguard, the squad looses heroic intervention. Yes, veterans loose their veteran skill when the most veteran living space marine in the universe joins them.. It's just an issue of balance. Besides, he didn't say Dante was joining the vanguard. I bolded the part were he stated Dante was running with a Sanguinary Guard. It seems his plan is to use the Sang Guard and Dante to pop open a transport, and use the Vanguard to assault the people inside. Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2485249 Share on other sites More sharing options...
NExOBLIVISCARIS Posted August 10, 2010 Author Share Posted August 10, 2010 yes what he said plus they sanguinary gaurds have the banner so with my current army set up i would charge the occupants with 25 S5 I5 power weapon attacks. with only 5 guys in the squad. i was thinking of adding more to Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2485524 Share on other sites More sharing options...
JamesI Posted August 10, 2010 Share Posted August 10, 2010 How do you get 25 power weapon attacks? Is this from the Vanguard? (I probably just misunderstood your post). Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2485599 Share on other sites More sharing options...
NExOBLIVISCARIS Posted August 10, 2010 Author Share Posted August 10, 2010 they have 2 standerd +1 for the pistol and cc weapon +1 for charging and +1 for the chapter banner that will be near by with 5 vangaurd that all have power weapons. Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2485621 Share on other sites More sharing options...
Brother-Captain Lucius Posted August 10, 2010 Share Posted August 10, 2010 He gets 4 on the charge and then + 1 for banner Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2485625 Share on other sites More sharing options...
Morticon Posted August 10, 2010 Share Posted August 10, 2010 Best you lads be reading the rules again. Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2485634 Share on other sites More sharing options...
Brother-Captain Lucius Posted August 10, 2010 Share Posted August 10, 2010 I was just about to say it had to be in the own squad Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2485636 Share on other sites More sharing options...
NExOBLIVISCARIS Posted August 10, 2010 Author Share Posted August 10, 2010 why, whats wrong with this plan Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2485637 Share on other sites More sharing options...
SnorriSnorrison Posted August 10, 2010 Share Posted August 10, 2010 Vanguards do not have access to the Banner, and the Sanguinary Guard don´t receive the +1 attack for pistol + cc weapon as their weapons are two-handed. To get them 5 attacks, you should have the Sanguinor around. Back to topic: I think the best Sternguard setup is a 5-6 men squad, powerweapons and jumppacks all around, descending from the sky and charging the enemy. Or just call them Vanguard. While the Sternguard might be effective, I still think that they don´t really fit to the aggressive nature of the Blood Angels. Sure, you can pod them and blow up whatever comes your way, but you will probably lose that unit afterwards....a circumstance that I find unacceptable. Well, at least for fluffy games. Snorri Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2485653 Share on other sites More sharing options...
JamesI Posted August 10, 2010 Share Posted August 10, 2010 NEx, the banner does not provide +1 attack to nearby units, just to the unit carrying the banner. Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2485669 Share on other sites More sharing options...
NExOBLIVISCARIS Posted August 10, 2010 Author Share Posted August 10, 2010 Sanguinary Guard don´t receive the +1 attack for pistol + cc weapon as their weapons are two-handed.To get them 5 attacks, you should have the Sanguinor around. i know that, the guards are going to pop the transport then the vangaurds (who have +1 for close combat and pistol) charge the survivors. and i know the vangaurds dont get the banner plus i just re read the rules for the banner that was my mistake. just have to add more gaurds then. i'm just going to drop the sterngaurd and go all jump packs Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2485673 Share on other sites More sharing options...
BLACK BLŒ FLY Posted August 11, 2010 Share Posted August 11, 2010 I agree with Snorri's assessment. The good thing is you have lots of options with the new codex so have some fun and knock yourself out. :P 0b :) Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2485788 Share on other sites More sharing options...
jeremy1391 Posted August 12, 2010 Share Posted August 12, 2010 1 sarge combi melta power fist 3 combi melta 4 combi flamer 1 heavy flamer 1 sang priest combi melta rhino i have run thi a few times against my buddies eldar and they are rather nasty. Link to comment https://bolterandchainsword.com/topic/208272-good-sternguard-setup/#findComment-2486793 Share on other sites More sharing options...
