TopKat Posted August 12, 2010 Share Posted August 12, 2010 My DA scouts are the metal models (circa 2000, give or take a year or so). I know a scout with a missile launcher is available in plastic, but is there a metal version of a missile-armed scout out there? If not, have any of you master modelers done this particular conversion, and if so, can you share pics and/or a tutorial? Thanks! Link to comment https://bolterandchainsword.com/topic/208412-metal-scout-with-missile-launcher/ Share on other sites More sharing options...
chromedog Posted August 12, 2010 Share Posted August 12, 2010 There WAS a metal scout with missile launcher available. He was down on one knee, firing the launcher (you can copy the pose with the plastics). It was released before the plastic scouts came out, and would be "direct" and/or collectors only through GW these days. Link to comment https://bolterandchainsword.com/topic/208412-metal-scout-with-missile-launcher/#findComment-2486920 Share on other sites More sharing options...
Vandiyan Posted August 12, 2010 Share Posted August 12, 2010 I have two metal scouts that have been converted to hold missile launchers. I do not have any pics atm, still getting my stuff back from overseas. Yet when I do get the chance to I will put up pics. What you will need: - Metal Space Marine Scout with Bolt Pistol and Close Combat Weapon. - Plastic Tactical Space Marine Missile Launcher w/ arms. With a razor saw cut the arm (Or arms) completely off. Next glue the plastic missile launcher arm onto the scout and adjust as needed. As well as the other arm if desired. You may or may not need green stuff for this just to fill in the gaps. I didn't and my models came out great. =D I will get pics up asap. Hope this is enough for now. Link to comment https://bolterandchainsword.com/topic/208412-metal-scout-with-missile-launcher/#findComment-2487443 Share on other sites More sharing options...
Fister Posted December 4, 2010 Share Posted December 4, 2010 I have a a bunch of metal scouts including the one with the missle launcher, that is unpainted, that I would be willing to part with Link to comment https://bolterandchainsword.com/topic/208412-metal-scout-with-missile-launcher/#findComment-2580427 Share on other sites More sharing options...
Deus de Mortalis Posted December 5, 2010 Share Posted December 5, 2010 Here are a couple pictures of a metal scout with missile launcher I bought on Ebay. I have heard that it was only available through GW mail order. http://img822.imageshack.us/img822/7264/1002624t.jpg http://img230.imageshack.us/img230/5948/1002623.jpg Link to comment https://bolterandchainsword.com/topic/208412-metal-scout-with-missile-launcher/#findComment-2580842 Share on other sites More sharing options...
jerry Posted December 15, 2010 Share Posted December 15, 2010 What I used was a steel legion missile launcher arm on the heavy bolter scout,the fit was good very little conversion.Looks more along the lines of a steroid induced RPG. Link to comment https://bolterandchainsword.com/topic/208412-metal-scout-with-missile-launcher/#findComment-2589659 Share on other sites More sharing options...
