Chalice or narthecium
I think that the written description of the Blood Chalice in the 'Dex states that the Nartecium contains a small shard of one of the 10,000-year-old chalices that contained Sanguinius's blood. So a narthecium on it's own should be fine. If you really want a chalice, there is one in Space Hulk as well as Corb's, but otherwise I am stuck for ideas.
Really they should not have Narthecium's but Blood Chalice's as this is what the codex says they have. The Space Hulk Chalice is too big IMO for a power armoured marine and only really works with a Sang Priest in Termi armour. For my HG Sang Noviate I use one of the smaller propultion chamber's from the Sang Guard's single cylinder jump packs for the top, and the bottom of a chainsword for the bottom. Turned out alright.
Unless you're running a successor chapter then you can't really use the chalice right?! For instance, my chapter's Sanguinary Priests all wear robes. I just say that they're woven with small pieces of Sanquinius' robe (kind of like the shroud that the SoB had/have). I say, use what you like. If you want your "Chalice" to be a Narthecium, the so be it. :D
I always thought the literal chalices looked silly. How does one retrieve the geneseed of a fallen brother with a cup? I've modeled mine with nartheciums so far and plan to continue doing so.
Either are definitely an option if you ask me as both show status as an apothecary/priest. One just looks a tad goofy and impractical.
It's definitely not necessary, and the Death Company box comes with lots of shoulder pads that have the chalice in them.
If you want to have a chalice though check out Maxmini.eu ...I cannot give them the most glowing recommendation, quality control wise, but they did take care of me. Here is my priest with chalice:
