Kassill Posted August 24, 2010 Share Posted August 24, 2010 OK, so I was going to use a Devastator ML I still had on sprue to start my Long Fangs pack. SO , I located said Dev sprue, clipped off all the missile bits, and then realized, I didnt have the right top part of the arm, so I went back and looked, and looked, and looked and couldnt find anything that would have gone with the missile arm! So, at first I just thought, well maybe it fell off in a box some wheres... But then, I started to look at pics of the Dev sprue, and I dont see ANY bit that would do what was needed to use the Missile Arm!?!?!?! Is it there? Am I blind? If you dont know what Im talking about, look out a Tac marine missile. The whole right arm is one piece right? Imagine not having from the elbow, to the shoulder. That is the bit I am missing. Link to comment https://bolterandchainsword.com/topic/209156-kit-question/ Share on other sites More sharing options...
Xeonic Posted August 24, 2010 Share Posted August 24, 2010 The Dev ML is a bit more elegant than the tac launcher, on the sprue the piece you're looking for is IIRC, a single shoulderpad and upper arm bit. Check your bitz box for a shoulderpad with upper arm in it and that should be what you need...alternately, a shoulderpad, spare arm(hacked off at the bicep), and a bit of GS will cover for it nicely. You can see the bit in the sprue collection sticky in this forum, but it just looks like a filled in shoulderpad. Link to comment https://bolterandchainsword.com/topic/209156-kit-question/#findComment-2495352 Share on other sites More sharing options...
Maarg Posted August 24, 2010 Share Posted August 24, 2010 The missing part of the arm you require is part of the shoulder pad. If you have a look at the inside of the shoulder pad you will see a notch wher the missile part of the arm will fit. Link to comment https://bolterandchainsword.com/topic/209156-kit-question/#findComment-2495353 Share on other sites More sharing options...
Kassill Posted August 24, 2010 Author Share Posted August 24, 2010 Thanks guys. After looking over the sprue again, I still dont see it, so it must be lost to the warp of my unorganized boxes :) Guess I will go the route of making my own for him. Link to comment https://bolterandchainsword.com/topic/209156-kit-question/#findComment-2496307 Share on other sites More sharing options...
