Grey primer
ac4155
The only company that does primers of that i know of, other than Games Workshop, is army painter and have heard that they can go on a bit thick.
If you use short controlled bursts you should be fine with Army Painter. It goes on a bit thick initially, but as it dries it loses its volume and generally looks like any other primer in the end.
https://bolterandchainsword.com/topic/209387-grey-primer/#findComment-2497928
I use Tamiya grey for models that are going to end up being a light color, and GW chaos black in a can for those who aren't. I tried the Tamiya white, but never had much luck with it, always got a better finish out of the grey.
What about metalic end colors, specifically something like Grey Knights or Iron Warriors.
My first thought is that the grey would be a better foundation but is that true?
https://bolterandchainsword.com/topic/209387-grey-primer/#findComment-2501310
Armory makes a grey primer that is fairly nice, though it seems a bit sensitive to humidity and temperature. Krylon makes a grey primer that works wonderfully for me for colors that I want to use grey for. I like it because it is just a little darker and seems to 'desaturate' colors, lending it to what I feel is sometimes a more realistic look. It looks really good on tanks and more gritty looking finishes. As for metallics, I'm not really fond of going straight over it, I really thing metallics look best over a dark base. Although if you wash over the primer with a diluted dark brown or black first, then do your metallics, it kind of almost gives you some built in highlights.
https://bolterandchainsword.com/topic/209387-grey-primer/#findComment-2501686
