Br0ther Rafen Posted October 23, 2010 Share Posted October 23, 2010 Hi Guys I need some help qith Magnatising my Dread Do you guys know what's the best size for the job? Link to comment https://bolterandchainsword.com/topic/213711-magnatisin-my-aobr-dreadnought/ Share on other sites More sharing options...
ShinyRhino Posted October 26, 2010 Share Posted October 26, 2010 I use K&J Magnetics' D41's for all my Dreads. A pair of these are strong enough to hold even metal arms to a Dread's body. Link to comment https://bolterandchainsword.com/topic/213711-magnatisin-my-aobr-dreadnought/#findComment-2545682 Share on other sites More sharing options...
Shadow Captain Corveus Posted October 26, 2010 Share Posted October 26, 2010 Hi, I use 6mm diameter by 2mm disc magnets like these: Linky These are strong enough to hold Dreadnought bits on tightly, so that you don't accidentally knock the arms off! They do however require you to use greenstuff to stick them to the arms and torso (Games Workshop deliberately made the AoBR and ordinary Dreadnoughts slightly different so that you can't just use the bits from the more expensive one on the cheaper AoBR body!) Yeah, these are the ones I use! Hope this helps... :) Link to comment https://bolterandchainsword.com/topic/213711-magnatisin-my-aobr-dreadnought/#findComment-2545683 Share on other sites More sharing options...
ShinyRhino Posted October 26, 2010 Share Posted October 26, 2010 These are strong enough to hold Dreadnought bits on tightly, so that you don't accidentally knock the arms off! They do however require you to use greenstuff to stick them to the arms and torso (Games Workshop deliberately made the AoBR and ordinary Dreadnoughts slightly different so that you can't just use the bits from the more expensive one on the cheaper AoBR body!) An appropriately-sized drill bit works wonders. Drill a hole INTO the body, and recess the magnet instead of gluing it to the side. You have to lop the attachment nub off first. Link to comment https://bolterandchainsword.com/topic/213711-magnatisin-my-aobr-dreadnought/#findComment-2545685 Share on other sites More sharing options...
Shadow Captain Corveus Posted October 26, 2010 Share Posted October 26, 2010 An appropriately-sized drill bit works wonders. Drill a hole INTO the body, and recess the magnet instead of gluing it to the side. You have to lop the attachment nub off first. The AoBR dreadnought's arms have nothing to drill into though. They're completely hollow, I just filled them in with greenstuff and then proceeded to drill into that. Link to comment https://bolterandchainsword.com/topic/213711-magnatisin-my-aobr-dreadnought/#findComment-2545701 Share on other sites More sharing options...
