FF151 Posted November 15, 2010 Share Posted November 15, 2010 Hey Guys, I have a chaplain from 2000 or earlier that is in Terminator armour and has a banner post. I am fairly new to this hobby and wondered what paper you guys have used to make your own banner? Should I use card stock? Any tips on this would be most appreciated! FF Link to comment https://bolterandchainsword.com/topic/215129-creating-my-own-banner/ Share on other sites More sharing options...
breng77 Posted November 15, 2010 Share Posted November 15, 2010 depends on how good an artist you are. Can you do good artwork on a small banner, If so cardstock is pretty good. I usually use Shrinky dinks, they let me do artwork larger and then shrink it down to fit (I'm not that good at free hand). Link to comment https://bolterandchainsword.com/topic/215129-creating-my-own-banner/#findComment-2562845 Share on other sites More sharing options...
Solid Zaku Posted November 15, 2010 Share Posted November 15, 2010 I know a lot of people cut up soda cans and use them, since they're fairly malleable things...just watch those sharp edges. Link to comment https://bolterandchainsword.com/topic/215129-creating-my-own-banner/#findComment-2562899 Share on other sites More sharing options...
Hemal Posted November 16, 2010 Share Posted November 16, 2010 Sheet tin is good, as is greenstuff depending on your GS skills (tip is to roll out the GS between two sheets of cling film..). Paper is equally valid - I normally spray to seal it up initially or paint with watered down paint, and then spray varnish the sheet Link to comment https://bolterandchainsword.com/topic/215129-creating-my-own-banner/#findComment-2563288 Share on other sites More sharing options...
Kinzel Posted November 18, 2010 Share Posted November 18, 2010 ahh that tincan idea is awesome. I am gona try that next time I want a banner. I've tried before using tissue (and regular) paper coated in white glue and /or superglue and it doesn't come out that nicely for me. Also tried this modelling putty I've got ( can't get GS here sadly :/) and it was far too brittle when it was so thin. Also palyed around with tinfoil (aluminium foil I suppose really) and it was too soft to keep it's shape. I think I might print out a banner and stick that to a thin piece of metal from a can. best of both worlds. Cool flowing shape of the tin banner with the detail and ease of an accurate printed banner. Link to comment https://bolterandchainsword.com/topic/215129-creating-my-own-banner/#findComment-2565393 Share on other sites More sharing options...
