bushman101 Posted November 29, 2010 Share Posted November 29, 2010 I always take a Predator in my lists, but find they don't do much. I'm usually taking a AutoCannon with either of the sponson choices, but don't seem to do much versus armor. Is it worth the points to take the TL Lascannon? Maybe I should ditch the Predator all together for another choice? The Vindicator seems tempting, but I'm afraid of it being useless due to one Weapon Destroyed result Link to comment https://bolterandchainsword.com/topic/216052-need-help-with-predator-loadout/ Share on other sites More sharing options...
Zeller Posted November 29, 2010 Share Posted November 29, 2010 Many mechanized lists favor the Autolas predator in quantaties of 2-3. Aside from the low visibilty at sponson height it's an effective setup. Link to comment https://bolterandchainsword.com/topic/216052-need-help-with-predator-loadout/#findComment-2575424 Share on other sites More sharing options...
Redfinger Posted November 29, 2010 Share Posted November 29, 2010 What else is in your list? Preds w/ autocannons are primarily a light av and horde control platform, the sponsons are so low to the ground that generally there are LOS issues w/ the sponsons. Have your tried dreadnoughts? a dread w/ twin-linnked autocannons puts out 4 twinlinked str 7 shots @ 120 points, this is not bad suppression fire, offers duality and can threaten upto av 13. I would not suggest taking less than 2, then when you concentrate fire your now getting 8 shots per target and producing better chances of nuetralizing the target. I you want to be purley anti av with your preds, then twinlinked LC's is the way to go with a HK, no sponsons though. Going back to the dreads though supporting them w/ dev ML squads is a great source of anit av as well. Ashton Link to comment https://bolterandchainsword.com/topic/216052-need-help-with-predator-loadout/#findComment-2575426 Share on other sites More sharing options...
Claws of Corax Posted November 30, 2010 Share Posted November 30, 2010 A vindicator can still be used to Ram after a weapon destroyed (and can be effective) Personally I have killed 2 monoliths in a game like this (until my opponant got tired of the thing and focused on it) For Predator options; a Baal Pred with Assault Cannon is effective (4 chances of Rending (someting to think about)) Brother Claws Link to comment https://bolterandchainsword.com/topic/216052-need-help-with-predator-loadout/#findComment-2576023 Share on other sites More sharing options...
