Tyrannicide Posted December 10, 2010 Share Posted December 10, 2010 The larger one looks better on a power armored leg without any purity seals obscuring it from view. On the models with any leg decoration just use the smaller decals. Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2585508 Share on other sites More sharing options...
amalric99 Posted December 10, 2010 Share Posted December 10, 2010 I prefer the larger symbol, the smaller one looks a bit lost on the greave. Maybe it needs anchoring to the bottom in the same way as the larger one? Great looking Iron Hands though. Do you know what scale the tread plate you are using is? Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2585751 Share on other sites More sharing options...
SCC Posted December 11, 2010 Share Posted December 11, 2010 Looking good Argos, I told you black was the new black! :P The weathering = highlighting technique is pure genius and it looks like you've got the technique down pretty pat already. I also have to agree that the FW decals are a boon to the hobby. I'm interested to hear you say you need to soak them in MicroSol to get them to conform as the FW Raven Guard decals I've been using shape to the pad almost straight away. As for the Tac symbol, I actually prefer the larger one, or perhaps it's simply the placement of it as amalric says. Now the big question - the Greif (or is it MV?) lens - any particular tricks to be aware of? I suck at painting gems and the lenses look boss, I also happen to have found a local model train store that stocks them so I grabbed some to try out but thought I'd ask for some advice first. Starting with the basics - is CA glue OK or will it craze them? Or is plastic cement the way to go? Ditto varnish - do you brush varnish then spray or do you add the lens post varnish altogether? I'm also noticing the lenses have a curve to both sides, do you drill/hollow out the place they'll go a little or use the glue to 'fit' them as such? Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2586549 Share on other sites More sharing options...
Brother Argos Posted December 11, 2010 Author Share Posted December 11, 2010 @ amalric99 : Its the 1/100th scale tread plate. @ SCC : I decided in the end the Large tac symbol looked better ... so I will be going with that I think. For the lenses you must have different ones from me, Mine are flat one side and curved the other. I glue them with minute amounts of thin superglue and cover them with blu-tac when it comes to varnish time ! It was my birthday this weekend, so I got some modelling done :angry: First off I finished the 2nd of my rusty floor bases. I am pleased with the result, especially the oil leak and the "eagle" strip. I got some work done on an Iron Hands chest plate as well ... I used plasticard strip to add a cog pattern around the top and used photoetch circles and washers to create a "valve" on the left. I am hoping when painted black and white it will "pop" quite nicely. In addition two more marines have been prepared for painting ... first off is a simple head and bolter swap. The head is from the IH boxed set and I need to think a bit about painting it before I get started. The bolter is from Forgeworlds new Bolter variants, it looked quite a nice piece so I decided he would have a valuable older model bolter. In addition you can see the shoulder pad I made earlier. This model is a good bit more ambitious, the idea behind him is the "wounded marine" fights on. With his left hand and forarm blown off he can be seen favouring right hand as he tries to fire the bolter with one hand. The shot up from the base (on the right) shows the inside of the blown forearm and you can see the Ulna and Radius bones projecting down, I plan to green stuff up into the socket to show flesh around the bones. This gives me an opportunity to have some blood effects on the base and down the armoured leg, and I am hoping it should look good. His other leg is from the Maxmini.eu bionic set and needs some more work, namely the "shoe" needs extending forward another 1.5mm and I think I am going to use plasticard to make a greave plate which matches the other leg and will go in front of the bionics. As it was my birthday I was lucky to get some Forgeworld Iron hand loot ... so I am looking forward to fiddling around, seeing what I can made using it! Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2587048 Share on other sites More sharing options...
Silber Posted December 12, 2010 Share Posted December 12, 2010 Well, a belated Happy Birthday then. I really like your work. These lovingly crafted individuals are exactly my kind of thing. Keep it up. Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2587088 Share on other sites More sharing options...
Black Hand Posted December 12, 2010 Share Posted December 12, 2010 Okay, I'm rather a fan of that wounded marine up there. It's a great expression of the heroism and general stubbornness of both the SM in general and the Iron Hands in particular. Really top work! Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2587098 Share on other sites More sharing options...
onipunk Posted December 12, 2010 Share Posted December 12, 2010 These are absolutely fantastic, and I'm really looking forward to seeing more of these models. The cog-patterned chestplate look really good, and I think some custom backpacks could go a long way with the force (even something as simple as putting an Iron Hands brass-etch symbol in place of a skull on the pack or whatever). One thing, the bases look great, but I'd like to see some more variation soon, with maybe things like vents in the ground, or loose panels etc. Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2587343 Share on other sites More sharing options...
Brother Caedrius Posted December 12, 2010 Share Posted December 12, 2010 This confused me as I thought I'd replied to this topic and then couldn't find my post! Turns out I replied to the Index Astartes thread! Well here's a repeat: "Superb work! Love all the minor details and etchings - where do you get the small circle and washers? What do you use for the rivets on your bases? Will be following this topic with much anticipation!" :P Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2587360 Share on other sites More sharing options...
Brother Argos Posted December 13, 2010 Author Share Posted December 13, 2010 @ Silber : Thank you ;) @ Dark Link : I have been putting some thought towards the backpacks ... I am still of the opinion I need to do a detailed small sculpt of the IH emblem to make it work. As for bases and new things ... I am waiting for a delivery from Australia ... more to be revealed when it arrives :) @ Brother Caedrius : The small photoetch parts are made by MiG productions .. and useful for so many modelling things! The more I looked at the bionic leg I wasn't happy with it ... it took me a while to figure it out, but in the end I decided it was the lack of "armour/40k-ishness". With the help of some plasticard and photoetch I set out to remedy the situation. The final result was more pleasing to the eye .. and as an unexpected bonus it hid the stubiness of the foot nicely too. To join the "greave" together at the back I glued into place some plastic rod and used two of my photoetch hex bolts to "tie" it all together and keep the IH theme. I finally got round to finishing my first marine, I had needed to do the purity seal and here it is: - You can also see some of the "Rust" pigment used on the boots to blend the model into the base. It was nice to note with a detail shot that the decal arrow and the "chipping" hold up well even at this level of detail. Next up we have a modified bolter where I added a rangefinder attachment to the side using plastic rod, ribbed cabling and some green stuff. The "lens" will go onto the end of the attachment when its been painted. Sharing the photo is the next marine due for painting, made using the bionic legs from the iron hands tactical box set. Finally we have the next finished Iron Hands marine: - Considering the speed of painting they are coming out better than I had hoped :) Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2588006 Share on other sites More sharing options...
Dark Sensei Posted December 13, 2010 Share Posted December 13, 2010 I'm a great fan ! FW leg is a bit oversized I'm affraid, the right leg is longer than the left one but it'll do more than well. DS Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2588042 Share on other sites More sharing options...
Brother Argos Posted December 13, 2010 Author Share Posted December 13, 2010 "the damned artificer" over on Warseer suggested something I had missed ... while working on the plasticard greave on the bionic leg I had neglected to add the all important COG edging ... all I can say is that it was late at night! Here is the new greave with the appropriate edging! In addition there was a request for a picture of the IH brass etch I got at the weekend with a scale reference. I took this quickly as I am about to head off for work! There is a higher resolution version here-> Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2588138 Share on other sites More sharing options...
SCC Posted December 13, 2010 Share Posted December 13, 2010 Coming along very nicely sirrah, very nicely. You've got a very IH vibe here with both the modelling and painting :P Is the greave flat plasticard shaped around the leg or a pipe/half pipe cut to size? Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2588141 Share on other sites More sharing options...
Brother Argos Posted December 13, 2010 Author Share Posted December 13, 2010 Its plasticard cut out and shaped round the leg and glued into place. Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2588144 Share on other sites More sharing options...
SCC Posted December 13, 2010 Share Posted December 13, 2010 Hmm. That seems deceptively easy, I may have to try it for one of my Raven Guard. I have a multiple sets of the IH bionic leg and it would be a nice way to use them for more than one model without the oddity of two guys having the exact same bionic leg...ditto on the arms the IH set came with. Hmm :tu: Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2588150 Share on other sites More sharing options...
Terminatorinhell Posted December 13, 2010 Share Posted December 13, 2010 I love the wounded marine's pose! Can I borrow it? Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2588166 Share on other sites More sharing options...
Brother Argos Posted December 13, 2010 Author Share Posted December 13, 2010 Umm .. of course you can :) Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2588515 Share on other sites More sharing options...
Brother Argos Posted December 14, 2010 Author Share Posted December 14, 2010 Minor update for tonight as I got in late ... All the currently constructed marines and their weapons were undercoated black (who would have guessed) ... I just need to do the weathering work on them tomorrow night! In addition while sitting here I started work on the next base ... I wanted to do some deck plating that wasn't tread plate .. I used squared plasticard and drilled lots of tiny holes to look like corner rivets on steel tiles. I then cut out a hole for a wiring duct and put a photoetch grill over the top. To give the feeling of depth I then cut out the same size hole on a 25mm Gw plastic base and put plastic rod under it .. to look like cables and ducting running along the bottom. Here is a picture of the WIP ... the final version will have smaller cables coming up and resting on the decking, as though someone was working on it. Another long day tomorrow so won't get a huge amount done sadly ... Although I just scored a huge FW order at Bitsandkits.co.uk of old heresy armour ... Very excited about that! Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2589407 Share on other sites More sharing options...
Tyrannicide Posted December 14, 2010 Share Posted December 14, 2010 Argos, you're one of the few hobbyists who has managed to make bases into an art. I look forward to the seeing the new Marines with some paint on, 'specially that one with the cool bionic leg and wounded arm. Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2589426 Share on other sites More sharing options...
Bigger-than-Jesus Posted December 14, 2010 Share Posted December 14, 2010 Looking nice, just one thing that's bothering me slightly about the wounded marine-don't Iron Hands replace their left forearms with bionics? Doesn't matter now either way I suppose, and I could be wrong, but it could be an interesting take on the concept, maybe some funky-looking hydraulic fluid instead of blood and shiny metal other than bone. Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2589472 Share on other sites More sharing options...
onipunk Posted December 14, 2010 Share Posted December 14, 2010 The base looks real good, and how is it ordering from Bits and Kits? I've been tempted by them a few times due to their larger range, cheaper prices and the fact that they have stuff in stock compared to Bitzbox. Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2589501 Share on other sites More sharing options...
Brother Argos Posted December 15, 2010 Author Share Posted December 15, 2010 @ Bigger-than-Jesus : The weakest point on the arm would be the interface between Bionic and flesh ... thats why I chose that position on the arm to show the break. @ Dark Link : I would recommend them highly ... I use them whenever I need anything "bitz"-like and they deliver quickly and efficiently. the only delay I ever had was down to the Royal Mail. Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2589751 Share on other sites More sharing options...
Dorns Padawan Posted December 15, 2010 Share Posted December 15, 2010 Brother Argos: Legendary stuff sir!!!!! Absolutely love the base with the square plasticard & grill cover! The SM are coming along very nicely indeed, how many layers of paint do you add ofter base coating? Very clever stuff with the conversions, can't wait for the next update!!!! Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2589793 Share on other sites More sharing options...
onipunk Posted December 15, 2010 Share Posted December 15, 2010 That's good to know, Argos. Can't be too careful when buying online, can you? Keep up the great work. Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2589979 Share on other sites More sharing options...
Brother Caedrius Posted December 15, 2010 Share Posted December 15, 2010 I use both Bitzbox and Bitsandkits, I generally find Bitzbox a bit quicker on their feet getting the order to me, although Bitsandkits stocks more stuff and postage "can" be cheaper providing you alter it in checkout :P Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2590359 Share on other sites More sharing options...
Brother Argos Posted December 17, 2010 Author Share Posted December 17, 2010 Here are some pictures of tonight's work ... I only used a single light to take the pictures, should have used the 2-3 I normally used but its 1am and I am too tired to get them out. Here is the current work on the new base ... still need to work on the rust and blood (from the wounded marine) ... Once again I am pleased with the look of the Forgeworld Decals .. and with the shadows the bionic leg looks a little dark (needed more lights), but you can see further down its is quite bright. The bionic leg is now not shaded and you can see the "pistons" etc that make up the Maxmini.eu bionic leg, it was too dark with just boltgun, so I added some brass and mithril silver. In this picture if you look carefully you can see the bones protruding from the remains of the arm ... Once the figure is glued to the base, I will deal with the blood pattern on the floor. Lastly the view from behind ... the Tactical decal felt so start I ran a dark "filter" over it and added some scratches running it down it .. I like all the results, but this figure is pushing 5hrs now and beyond the limits of what I wanted to spend on a rank and file figure, so I need to finish it off quickly and move on. The good news is that I have a handle on painting bionics now and should be able to do them quickly next time. Link to comment https://bolterandchainsword.com/topic/216363-space-marines-iron-hands/page/2/#findComment-2591510 Share on other sites More sharing options...
