Quixus Posted December 6, 2010 Share Posted December 6, 2010 I prefer the Mark IV dreadnoughts over the Mark V. As far as I know GW only sells this Mark as a Venerable dreanought. Are there options in the kit to make it less blingy or do I have to use sandpaper and greenstuff? FW dreads are a bit too expensive for my taste especially if you want options (arms sold separately). Another Question, are any of the FW arms compatible with the Venerable Dread from GW? Link to comment https://bolterandchainsword.com/topic/216530-mk-iv-regular-dreadnoughts/ Share on other sites More sharing options...
BERZERKER! Posted December 6, 2010 Share Posted December 6, 2010 Hi You could kitbash the GW Venerable with a standard dread, use the arms/greaves from the standard and the sarcophagus and torso from the venerable. This is an expensive solution though, but you do end up with a second dread (which you could sell on). As far as i know, the FW arms should fit onto any dread torso, including the chaos dreads. Link to comment https://bolterandchainsword.com/topic/216530-mk-iv-regular-dreadnoughts/#findComment-2581903 Share on other sites More sharing options...
Reyner Posted December 6, 2010 Share Posted December 6, 2010 Here's a guide from the Librarium Link to comment https://bolterandchainsword.com/topic/216530-mk-iv-regular-dreadnoughts/#findComment-2582181 Share on other sites More sharing options...
Quixus Posted December 6, 2010 Author Share Posted December 6, 2010 Thanks for the link, but I already know the tutorial.Unfortunately since I neither have AoBR nor a Terminator Box, this kit bash won't be much cheaper or easier to make than sanding down a Venerable Dreadnought. Even if I acquired the bits, I' d still only have one Arm combination AFAIK (DCCW, Multimelta). As I'm using Codex: Blood Angels the removal of "bling" needn't be that thorough either, since there are no Venerable dreads in the Armylist and decorating armor isn't exactly unlike BA. ;) Does anyone know about the compatibility of the different arms? Link to comment https://bolterandchainsword.com/topic/216530-mk-iv-regular-dreadnoughts/#findComment-2582249 Share on other sites More sharing options...
Reyner Posted December 6, 2010 Share Posted December 6, 2010 All the arms are compatible, except the AoBR dreads arms which don't seem fit to on other dreads. Link to comment https://bolterandchainsword.com/topic/216530-mk-iv-regular-dreadnoughts/#findComment-2582325 Share on other sites More sharing options...
Quixus Posted December 6, 2010 Author Share Posted December 6, 2010 So the FW arms fit (MK IV or V) on the GW Venerable dread as well? That is good news. Link to comment https://bolterandchainsword.com/topic/216530-mk-iv-regular-dreadnoughts/#findComment-2582442 Share on other sites More sharing options...
Lord_Halrian Posted December 8, 2010 Share Posted December 8, 2010 I use the venerable dreadnought kit myself ! Link to comment https://bolterandchainsword.com/topic/216530-mk-iv-regular-dreadnoughts/#findComment-2583726 Share on other sites More sharing options...
Brother Caedrius Posted December 8, 2010 Share Posted December 8, 2010 Forgeworld do 3 types of MkIV dreadnought - Ironclad, Standard and Venerable. All can be seen on the top 2 lines of the following link: MKIV Dreads I'm not sure whether the MKIV weapons fit the standard GW plastic, but the MKV do, I bought several MKV weapons to use my DA dreads as Mortis pattern, perhaps you could ring their customer services and enquire? Link to comment https://bolterandchainsword.com/topic/216530-mk-iv-regular-dreadnoughts/#findComment-2583758 Share on other sites More sharing options...
Quixus Posted December 8, 2010 Author Share Posted December 8, 2010 perhaps you could ring their customer services and enquire?I just sent them an email, I have time. If they don't reply I can still make an international call. [EDIT]That was quick: All the Forge World Dreadnought arms will fit on the Games Workshop Venerable Dreadnought and on the Standard Games Workshop plastic Dreadnought. Yay, Options. Is it just me or do the FW Close combat arms just scream Blood Talons?[/EDIT] Link to comment https://bolterandchainsword.com/topic/216530-mk-iv-regular-dreadnoughts/#findComment-2583764 Share on other sites More sharing options...
Brother Caedrius Posted December 8, 2010 Share Posted December 8, 2010 That's excellent news! I'd just come back to check your reply and offer my services to ring as I'm UK based, but now no longer necessary :( Good luck with your dread finds and please post pics of what you create! Link to comment https://bolterandchainsword.com/topic/216530-mk-iv-regular-dreadnoughts/#findComment-2583909 Share on other sites More sharing options...
Quixus Posted December 8, 2010 Author Share Posted December 8, 2010 Thanks for the offer of support. Guess it will be a project for after Christmas or later. I found this document at GW's site. For my no frills MK IV I'll probably go with helmet 18 or one from the regular squad sprues; fronts 10, 24, 25; greaves 34, 35; weapon arm 58,61/59,62. Most likely Assault Cannon and Lascannon. For a bit of bling the Dreadnought will be fitted with the handlike DCCW with magnetized flamer and stormbolter. Pictures though will be difficult as I don't have a camera. In the not so near future I may buy some more arms from FW. Link to comment https://bolterandchainsword.com/topic/216530-mk-iv-regular-dreadnoughts/#findComment-2584021 Share on other sites More sharing options...
LardO'Blood Posted December 10, 2010 Share Posted December 10, 2010 I took a shoulder pad and glued it on the shaved down sarcophagus front and then glued a piece of credit card I warped around it. Sorry for the bad pictures. http://img46.imageshack.us/img46/776/img1848r.jpg http://img191.imageshack.us/img191/844/img1851h.jpg Link to comment https://bolterandchainsword.com/topic/216530-mk-iv-regular-dreadnoughts/#findComment-2585472 Share on other sites More sharing options...
MagicMan Posted December 10, 2010 Share Posted December 10, 2010 That looks pretty good. You might find a smaller head looks better though, one that will fit into the hole. Maybe file down the side of the helmet? Link to comment https://bolterandchainsword.com/topic/216530-mk-iv-regular-dreadnoughts/#findComment-2585975 Share on other sites More sharing options...
