stefdeathwing Posted January 1, 2011 Share Posted January 1, 2011 just wondered if anyone can give me ideas how to base some recently purchased terminators. they are the ones from the latest edition of space hulk, but im going to doing them in Deathwing scheme.. would love any ideas you guys have and also web addresse where i can purchase stuff from for the bases.. :sweat: Link to comment https://bolterandchainsword.com/topic/218373-ideas-for-basing-terminators/ Share on other sites More sharing options...
winterdyne Posted January 2, 2011 Share Posted January 2, 2011 Removing the Space Hulk basing is tricky - on the ones I'm doing at the moment, I simply clipped back the base so it'd fit on a standard 40mm round base, and smoothed it in with greenstuff. Then it's just sand / grit before painting, as per usual. Link to comment https://bolterandchainsword.com/topic/218373-ideas-for-basing-terminators/#findComment-2604420 Share on other sites More sharing options...
Br0ther Rafen Posted January 2, 2011 Share Posted January 2, 2011 alternitavly, you could just glue them straight on to the 40mm base, and then glue sand, etc, over the base, to keep it nice and simple. Link to comment https://bolterandchainsword.com/topic/218373-ideas-for-basing-terminators/#findComment-2604608 Share on other sites More sharing options...
Brother Nihm Posted January 2, 2011 Share Posted January 2, 2011 alternitavly, you could just glue them straight on to the 40mm base, and then glue sand, etc, over the base, to keep it nice and simple.This is what I would do, just make sure to cover up the gaps with flock/basing material and make sure to make it look as natural as possible, like say, stacking small rocks on one side and smoothing out the gaps on the other. Link to comment https://bolterandchainsword.com/topic/218373-ideas-for-basing-terminators/#findComment-2604611 Share on other sites More sharing options...
winterdyne Posted January 3, 2011 Share Posted January 3, 2011 When I fitted them, there was a fair amount of overhang. Unless you're planning on having them removable at any point, I'd clip back the base a bit to get a smoother result. Link to comment https://bolterandchainsword.com/topic/218373-ideas-for-basing-terminators/#findComment-2605207 Share on other sites More sharing options...
Montuhotep Posted January 3, 2011 Share Posted January 3, 2011 If you're careful about it, then a razor saw will work well - though do be careful, I had one of mine snap off at the ankles! Link to comment https://bolterandchainsword.com/topic/218373-ideas-for-basing-terminators/#findComment-2605261 Share on other sites More sharing options...
Doghouse Posted January 3, 2011 Share Posted January 3, 2011 What I did was a little gs slope around the edges of the space hulk bases then just put sand over the top. Link to comment https://bolterandchainsword.com/topic/218373-ideas-for-basing-terminators/#findComment-2605348 Share on other sites More sharing options...
Tanhausen Posted January 3, 2011 Share Posted January 3, 2011 When you say stuff for the bases.. what do you have in mind? If you're thinking sand, vegetation and similar, real life is your friend. I have a zillion bits of rock, small branches and similar that I pick up in the most unthinkable places! If you want something more "industrial" or "space hulk" thing, I'd suggest doing your own bases with some steel net (like the ones you use to cover pipes so they don't clog) and small bits of plumbing PVC pieces. Hope it helps! Link to comment https://bolterandchainsword.com/topic/218373-ideas-for-basing-terminators/#findComment-2605364 Share on other sites More sharing options...
stefdeathwing Posted January 6, 2011 Author Share Posted January 6, 2011 thanks for all your ideas, was thinking of doing a space hulk theme to them but may even go for stone floor effect ... Link to comment https://bolterandchainsword.com/topic/218373-ideas-for-basing-terminators/#findComment-2608909 Share on other sites More sharing options...
UltraRich Posted January 6, 2011 Share Posted January 6, 2011 Here are my ultra SH termies. There are a few pics of how Ive got around the issue with the bases as they are all wip My SH Termi Thread Link to comment https://bolterandchainsword.com/topic/218373-ideas-for-basing-terminators/#findComment-2608920 Share on other sites More sharing options...
cathar the great Posted January 7, 2011 Share Posted January 7, 2011 Both Scibor Miniatures and MicroArt make pretty cool bases. You can also find a lot of great tutorials and inspiration on Massive Voodoo Link to comment https://bolterandchainsword.com/topic/218373-ideas-for-basing-terminators/#findComment-2609453 Share on other sites More sharing options...
stefdeathwing Posted January 7, 2011 Author Share Posted January 7, 2011 Here are my ultra SH termies. There are a few pics of how Ive got around the issue with the bases as they are all wip My SH Termi Thread those termies are fantastic (even though they are smurfs ) definatley given me lots of ideas. like the way you have painted the blue, might use that recipe for my librarians... Link to comment https://bolterandchainsword.com/topic/218373-ideas-for-basing-terminators/#findComment-2609758 Share on other sites More sharing options...
