Captain Elarix Posted January 13, 2011 Share Posted January 13, 2011 Hey, Im painting a drop pod, and as the title above says how do I paint burn marks on the drop pod like it just dropped in from space? -Captain Elarix Link to comment https://bolterandchainsword.com/topic/219301-burn-marks-question/ Share on other sites More sharing options...
winterdyne Posted January 13, 2011 Share Posted January 13, 2011 I use a mix of techniques - oil staining, black drybrushes and / or black pigment powders. Link to comment https://bolterandchainsword.com/topic/219301-burn-marks-question/#findComment-2615944 Share on other sites More sharing options...
Captain Elarix Posted January 13, 2011 Author Share Posted January 13, 2011 Ok, I'll try that out. Thanks -Captain Elarix Link to comment https://bolterandchainsword.com/topic/219301-burn-marks-question/#findComment-2616012 Share on other sites More sharing options...
Captain Darvaleth Posted February 2, 2011 Share Posted February 2, 2011 When I'm trying to get a burnt effect (mostly on gun barrels) I just wash it with devlan mud twice over the whole "burnt" area, then, closer to the source of heat, use badab black washes until I get the desired effect. Reaaaly easy. Link to comment https://bolterandchainsword.com/topic/219301-burn-marks-question/#findComment-2644388 Share on other sites More sharing options...
BROTHER UNGOLIANT Posted April 14, 2011 Share Posted April 14, 2011 try forge world weathering powder theres a few methods on how to use powders but i find neat from the tub is best, and just dry brush it on ,or you can mix it with acril varnish but this is tricky another method is mixing it with blue wash dont worry the black hides all the blue, and the powder drys to an ultra matt finish. but be warned this only works if you dont handle your mini mutch no good for gameing for example or if you varnish after painting cheak out gallery my screaming hornets and see the results. Link to comment https://bolterandchainsword.com/topic/219301-burn-marks-question/#findComment-2724500 Share on other sites More sharing options...
