Casting question
So question: Can anyone point me to a tutorial for resin casting that lists the types and names of materials it uses? Specifically a tutorial that will use material that is suitable for model building? I'm not looking to copy any of the GW stuff, but rather some of my own developments. You know, those things that you can do right once, maybe twice but then you realize you need to do it 40 times sort of thing. I've found a couple tutorials on Youtube, but they never mention anything involving glues or acryllic based paints. In fact most of the ones I've seen talk about using spray paint to paint the final item. So I donno how well they're work with GW paints or being attached to plastic and pewter models. Thanks for the help.
https://bolterandchainsword.com/topic/220289-casting-question/
i have had the same trouble finding tutorials that answer the questions im looking for. i had to go out and experiement myself. just so happens my first run was two days ago. i am on the mission to make 100 nurgling bases.
i started with the somewhat cheap allumilite rubber mold starter kit. it was like $15 US. its not a bad kit and the bases are starting to get better with the more runs im doing. ill list some key notes for you that ive found ot myself and what friends have told me.
1-the faster the resin sets the more bubbles youll get
2-mixing a bit extra resin is better than not having enough. i tried to conserve what i was using the first couple of times and ended up with 2 castings that i had to make extra resin for and now the cast definately looks like i made two pours on the one model.
3- be aware that bubbles form after the resin heats up and a toothpick softly prodded in the areas that the bubbles would get caught up in while rising up to your fill opening will help this. again refering to my first note the slower the cure the less bubbles.
4-when making the mold make sure theres good beefy walls to the mold like at least 1/2 inch or 1-2 cm. with rubber moulds youll end up needing to bend and flex the mold to get the model's small protrusions out of the recessed areas of the mold.
5- do not make one part rubber molds with models that have large protrusions ie... very extended arms, weapons, spikes or anything that will stick far out to the side or towards your fill opening or you would be able to pull the model from your rubber mold without damaging either the mold or model.
6-to cast models that have spread legs or extending arms or stuff youll need to model in a joining piece so the cast wont trap the model. here is a quick diagram
http://i10.photobucket.com/albums/a130/hammered187/mold.png
the red areas are the part youll need to model extra which can be cut out after you make the cast but will allow you to make most models like this with a 1 part rubber mold
